OffRoaderX reacted to a post in a topic: New to 5W Handheld
I would add some clarification on this, if you are using a type accepted 5 watt hand held GMRS radio you won’t have any issue using channels 8-14. The radio will be programmed to reduce wattage on those channels from the factory. Type accepted GMRS mobile radios won’t transmit on those channels.
gijoe981 joined the community
WRUU653 reacted to a post in a topic: New to 5W Handheld
WRUU653 reacted to a post in a topic: How Will having gmrs help me
By obtaining a license and creating an account here it gives you access to repeater information. You are given permission via the fcc to use more power when transmitting and use of radios with removable antennas to use better antennas and the ability to transmit through repeaters. If you just want to listen you can do so and none of those things matter and no license is needed. You can hear repeaters as the tones are only needed to transmit through them. You can buy good scanners or any radio and equipment you like. The license is just for transmitting and as @SteveShannon recommends no license needed for FRS and all channels are the same. Nothing wrong with enjoying radio as you choose.
Getting 50 watts actually out of repeater
TerriKennedy replied to WRYD530's topic in General Discussion
That's either a very mis-tuned duplexer or a broken one. I'm using an EMR 526-4 on my repeater, tuned to .700 by a dealer. Other than being huge, heavy, and looking like an out-of-control party at a steamfitter's convention it does an amazing job. N connectors on input and output (and I assume throughout, but I'm not checking because I might throw the tune off). -
Do you have family where it would be helpful to chat while one of you is outside the house? You can use it as an intercom, like the old Nextel iDEN phones. The advantages are that it works if the cell towers are down, radios can be purchased for far less money than cell phones, and one license covers your entire family. The disadvantages are that it doesn't have coverage as good as cellular if you have tall buildings or hilly, wooded terrain and there's no privacy. They can also be used for some types of communications during some types of emergencies. I'm qualifying that because it isn't suited for the hardcore "prepper in a bunker" types, but as an example we had a water main break on a main road here earlier this week, and someone in an apartment building overlooking the new sinkhole and geyser was providing real-time updates, while the city just sent out a generic alert and ended the day with a boil water advisory. People were asking how congested various alternate routes were and getting answers. There may also be repeaters in your area that you can use to increase your coverage. You can find candidates here, although you'll need an account to access the details. You can also find people who are interested in chatting, though it may take some effort and since GMRS is for personal use, the first people you hear may not be interested in talking to you. Near me, I have two guys who seem to mostly debate the merits of Doritos and hamburgers. OTOH, if it isn't for you, it isn't for you. No pressure to do anything you're not interested in. Lots of people just listen.
WRUU653 reacted to a post in a topic: Net Control = Control Station?
I never did understand the whole duck on the dash thing. I don't want anything on the dash that could go flying around in an accident, even a rubber duck. Nice job on the radio install. The 2730B is nice as the black screen is easy to see in all light conditions.
WRYZ926 reacted to a post in a topic: Radios in my Jeep
RoadApple reacted to a post in a topic: How Will having gmrs help me
RoadApple reacted to a post in a topic: Radios in my Jeep
Just get an FRS radio. No license is needed to talk and you can listen to all of the same channels.
RoadApple started following How Will having gmrs help me
If all you plan on doing is using a radio or scanner to listen, you do not need a license and there would be no benefit. If you want to talk, you need a license.
The only FCC rule restriction that comes to mind would be that you cannot use a 5W GMRS radio on channels 8 thru 14. Those channels are restricted to 0.5W which is common for most FRS radios. If you can set your radio to low power, you might be ok, but most 5W radios, even at low power, would probably still exceed the 0.5W power limit. That being said, if you were to transmit on those channels with more than the permitted 0.5W of power nobody would likely know or even care.
WSJT904 joined the community
When I recently got my HAM license I got an invite to join the ARRL buy the cost of the yearly dues were too much. There's a local club that's closer to my price range that I'd like to join though.
I got a hit on Shaw 725 a couple days ago. I wasn't expecting it but I tried it to test a radio I'd just programmed and got a return from it. There's not that many GMRS Repeaters in the Phoenix area, it'd be ashamed if we lost one. On the other hand we're covered up in 2M/70cm HAM Repeaters here in the Valley which is a good reason to get your Amature License.
larsks joined the community
WRQC413 joined the community
Seems like there is always the tendency to make things more complicated than the really are.
My RT-900 gets 6.82w on 1.25M. For $25 bucks it's a heck of a nice radio.
WRZR615 joined the community
Maybe your tune is a bit off. Doesn't take much.
Noted, I may need to visit that facet
I have the similar XLT 100 watt duplexer, DP-GMRS-100R and it has less than a 1.3dB loss through the duplexer. I think the difference is it's in a rack case and has N connectors instead of 239s. I saw almost no difference between the 3 duplexers I have from the output of my repeater.
My kids likes the ducks and my oldest likes to trade ducks so they stay.
Soooo... I might have a duplexer for sale, Justa sayin....
FYI, the Duplexer I am/was using which gave me 24W from a 47W input is the DP-GMRS-100 by XLT.
Update: I contacted Radioddity about the TYT TH-9800. explained my issue. I have had this gear for over a month but they replied that they would replace it. I am not surprised due to the reputation of this particular machine BUT they did act fast with no pushback, as least for now. Thank you again for all of your input to lead me to not keeping a piece of gear that doesn't work. As a newby, I would have kept it and eventually trashed the $ amount paid.
Get those stupid ducks off the dash! That's an embarrassment to real Jeepers!
WSCN925 started following SteveShannon
How to Update DMR-1701 to Open GD77 on Windows 10 pro
WSCN925 replied to WSCN925's question in Technical Discussion
Can you remote in to program it? -
WRZN509 joined the community
I've done a lot of solar power station/panel reviews on my YouTube channel. I "preach" solar to anyone who'll listen. We get a lot of sunny days here in Arizona so it only makes sense to use solar power.
Picked up a Jeep a few months ago finally got the radios installed. Icom-2730a (Black) for the ham stuff. Antenna is a Larsen 2/70B Motorola XTL5000 with W3 head for the GMRS, Ham P25 and FD stuff. Antenna is a PCTEL (B)MWU4002S I used the fender mounts by Topsy.
Well, I'm not doing show and tell. You are wrong about the equipment. It does not have to be a desktop type rig, i.e. a true base radio; mobiles and handhelds in a house, garage, radio shack, office, etc. with an external antenna on a pole, roof, chimney or in a tree are base stations. That's what they mean by fixed location, and notice they always refer to base station not base radio. My DB20G can be setup as base station, mobile station and portable station. Even my UV5G can be a base station.
