SteveShannon reacted to an answer to a question: New to gmrs
How many times are you going to post the same question?
WSJI655 joined the community
..we will reserve judgement for now. With a UV9g, you dont need to think about the offset - these are the basic steps: Put the radio on the correct REPEATER CHANNEL - Probably listed as either "Repeater 20" or Channel 28 Go into the Transmit CTC menu and enter the tone IGNORE/REMOVE the Receive tone as it is optional and at this point its only going to add to your confukulation Be sure to save all your changes (you may need to resort to the manual) Push the talk-button and talk, let go of button and listen for the Kerchunk/Static back from the repeater, or someone responding If it doesn't work then either you have the wrong channel, the tone is wrong, you are not close enough to the repeater (just because you can hear it does not mean it can hear you) or the repeater is down/broken/offline. The fact that you said you "have the offset" leads me to surmise that you've done it wrong.
Since the uv9g is a GMRS radio it is pretty hard to mess up. Some things to think about: Are you close enough to the repeater? If you know the general location you could move closer to it until you are sure you are actually opening the repeater. Have you tried simplex with another radio to make sure your radio is transmitting? Is there traffic on the repeater? I'm sure you have double checked your RX/TX tones but you might want to leave the RX tone off if the repeater has one so you can hear all the traffic on that frequency. I'm sure others will chime in with things I didn't mention. Don't give up.
I'm new to gmrs and can't connect to the repeater. I'm trying to connect to 462.675. I'm running a uv9g and have the offset and the ctcss tone put in as listed on mygmrs.com but nobody can hear me. Is it user error or radio error?
WSJD714 joined the community
I'm new to the radio communications game. I had some training in service for it but gmrs is a different beast. I'm running a uv9g and think I have everything set correctly but nobody can hear me. I've got the +5 offset and the ctcss for 462.675 but I'm not getting anything back.
WSED611 joined the community
Especially if they’re related …
SteveShannon reacted to a post in a topic: New to GMRS
..this section of the forum is so dead, I didnt even know it was here.. Anyway.. I just setup my Spec5 Trekker Bravo, so, i'm IN !
I'm sure I seem like a broken record to the people here, but pay attention to the FCC's restrictions on power and bandwidth. They exist for a reason; some FCC desk-jockey didn't just pull them out of his ass. Exceeding authorized power and bandwidth can cause your signal to "spill over" to an adjacent frequency or stomp all over someone on the same frequency, thus interfering with someone else's enjoyment of the airwaves. Radios which are compliant with Part 95 Subpart E (GMRS regulations) typically have the limits "baked in", but lots of people use amateur radios on GMRS frequencies. That's technically a violation of FCC regulations, but I don't care and neither do other reasonable people. For that matter, as far as I can tell, neither does the FCC. However, ham radios often (usually?) can be programmed to exceed the power, bandwidth, or both authorized on GMRS frequencies, and I do care if someone is crushing my signal. Hams are taught to use the lowest power output that will work for your purpose, and that's a good practice for every radio service. Just be a decent human. Be polite. Don't curse, be intentionally offensive, or otherwise act like a jackwagon. My rule is that if someone seems to take offense at something I've said, I just drop it. There are other channels to talk on and other people to talk to. If someone is being an a-hole, move your conversation to another frequency or use CTCSS/DTCS codes so you don't hear them. Periodically take a break in your conversation in case someone else wants to use the frequency, especially if you're on a repeater. There is no such thing as privacy on a radio. CTCSS/DTCS codes can keep you from hearing other people, but they won't keep other people from hearing you. Don't discuss your sex life or where you hid the house key.
Here is another example of how changes in the atmosphere effects UHF radio waves. My bother and I both have Allstar nodes and both were set to the same frequency and PL tones. These nodes only put out about .05 to 1 watt of power on transmit. And we have our radios set to 5 watts or less when using the nodes. We are 19 miles apart and 5 watts is normally not enough for us to hear each other. The other day there was a storm cell in between us and we could hear each other. My brother was using his Allstar node to talk to guys in Texas. I could hear him but not the other people. He could also hear me when I was using my node. The storms and low cloud cover was bouncing the 5 watt signal 19 miles. Granted neither one of us had a very strong signal as the signal strength meters barely moved, but it was enough of a signal that we could hear each other. We both ended up changing the frequency that our Allstar nodes use to stop this from happening.
AdmiralCochrane reacted to a post in a topic: "Illegal" radios
xtremeterrain joined the community
AdmiralCochrane reacted to a post in a topic: Transmitting Power Limits
wrci350 reacted to a post in a topic: "Illegal" radios
It's the strange ones that are most fun to play with. Imagination is the spark that fuels fun.
WRTC928 replied to SvenMarbles's topic in General Discussion
Me too. Mine was KAFU2984. I have no idea why/how I still remember that. -
That’s generally correct. From 95.335(b): b) Revoked or withdrawn certification. In the event that the FCC revokes or withdraws a grant of equipment certification for a type of Personal Radio Service transmitter, existing transmitters already in service may continue to be operated unless and until the FCC determines otherwise and gives Public Notice of that decision.
TimThib joined the community
WSIB276 joined the community
Ask a question and the strange people come out to play...... LOL
WSEF598 joined the community
I foolishly assumed that once a two-way radio is no longer typed accepted or certified for a specific service, that radio may continue to be used. On the other hand, manufactures and venders can no longer sell those radios for their original intended service, even though they can still be used,
Yes.. LJ...
No
WSHH887 started following What comms are you running for utvs , WARNING!!! , Midland MXT 575 mod for mid level power and 3 others
I haven't been able to get on the forum much lately other than to do a quick scan. So, I apologize in advance to all who take offense to my poking the bear. But I have lost toke, er time, to make up for.
Gee, is Dan around here somewhere?
Really, is anything after a CJ really a Jeep?
I don’t know the answer, so my reply is dumb, but your question was not dumb.
10-4
There are no dumb questions. Only people with huge egos trying to feel superior by making you think the question is dumb.
Mission? I haven't been on one of those since 1972. Didn't like what people who didn't like me were doing.
Ex-military or police? Real people only say that on TV.
Probably not allowed here, but I find gunfire generally tends to drive those folks away. Not in their direction mind you.
