OK, I'll give that a shot. Glad you didn't have to walk all that way Randy And there it is. Hard to believe after pressing those buttons randomly that it never showed itself. So there is a trick.
TrikeRadio reacted to an answer to a question: TD-H3 transmitting but not showing up on SWR meter
No, it's not a trick. According to page 40 of the user manual, after switching to VFO mode by pressing the 6/Mode button, then press the 2/Mhz button to direct-enter your frequency. ...and, i just confirmed this works with the KG-1000G+ in my office right next to me... I was going to try it on my Bathroom KG-1000G+, but that's all the way down the hall.
^ Good to know. Thanks.
Rhon or Universal Towers seem popular.
GreggInFL started following Let's talk antenna masts
Let's talk about a tilting/tipping base for a mast. Any recommendations?
Socalgmrs reacted to a post in a topic: KG-1000G plus VFO tuning
WSAN859 joined the community
LeoG started following KG-1000G plus VFO tuning
So far I have been able to figure out a way to change frequencies to the VFO other than using the knob or up/down arrows which is painfully slow. With the XS20G+ you just use the keypad on the mic to enter in whatever frequency you want. So far the only way I can see to program frequencies is to use the CPS and program it with your computer. Am I missing some trick?
LeoG replied to hxpx's question in Technical Discussion
I think they know they have this problem and really don't care because it's easy sending out a new radio that costs them a dollar or two to make than it is to have QC testing these things. With the advantage that people will just shrug it off and either not report it or just buy a new one without complaining. If you plan on being cheap (like me) and buying these inexpensive radios you are going to have to expect a couple of duds here and there. But with a responsive company like this it's just a bit inconvenient and somewhat frustrating to have to go through the process of swapping them out. And it's not even a swap out, they just send you a new one and don't care what you do with the old one. Usually they receive just fine so set them up as scanners. - Today
GreggInFL reacted to an answer to a question: TD-H3 transmitting but not showing up on SWR meter
hxpx replied to hxpx's question in Technical Discussion
Just as a quick update: I contacted TIDRadio about it and they sent me a new unit. Confirmed the new one outputs 5W with a dummy load and a 771 antenna. If nothing else, their customer support was pretty responsive and got this handled in a reasonable timeframe. -
Lscott reacted to a post in a topic: Marine VHF
marcspaz reacted to an answer to a question: Amature bands VS. GMRS Range
For what its worth, with both VHF and UHF, you can greatly extend communications well beyond the traditional LOS on the regular bases with the two stations involved being a bit 'over the top' for a typical Amateur or GMRS user. For example, if you have a 9 element or 11 element high-gain yagi on a 50' tower at both stations, you can reliably communicate 100+ miles with a 50w radio on VHF, and 60+ miles with a 50w radio on UHF / GMRS. If you happen to have your antenna somewhere comfortably above the average terrain, your station can talk even further. This is because the additional height above ground extends the LOS range a bit, but the magic is in the yagi antenna. Not only is the high-gain antenna able to pull more scattered energy out of the sky with greater efficiency, the fact that the beam is focused in a specific direction reduces the amount of random noise it pulls from the atmosphere. This allows the antenna to perform significantly better compared to a vertical antenna with the same gain as the yagi, for example. By reducing the total number of photons the antenna reacts to, you essentially improve the Part Per Million ratio in favor of the signal you are receiving. My radio club used this principle in combination with a propagation method called Sporadic-E (reflecting a signal off the E Layer) to talk over 1,500 miles on VHF, from Virginia to Texas. Our club had a stacked beam array and a 1,500w amplifier located on a mountain ridge in VA at 4,400+ feet and the Texas station had a similar setup in the western part of Texas, on a ridge line at about 6,000 feet. We were also running a UHF station with a similar configuration that same week. We contacted a station over 450 miles away. Though I don't remember the specifics of where the other station was for the UHF contact. Anyway, I guess the moral of the story is, while refraction off the ionosphere isn't an option for mid to upper VHF or UHF... if we get creative with location, antenna and available forecasts of atmospheric conditions, we can bend or even break the commonly accepted LOS rules with our base stations, control stations and fixed stations. We just need to leverage physics a little better.
SteveShannon reacted to a post in a topic: Comet 712EFC -- no ground plane radials
GrouserPad reacted to a post in a topic: Wouxun KG-1000G+ Audio isn't loud enough....... due to placement of radio
Stainless steel and aluminum won't interact as much as carbon steel and aluminum will. Though you do take the chance of galvanization anytime you mix any type of steel and aluminum. I use to hate working on vehicles with aluminum rims when previous owners/repair shops would not use anti-seize on the rims. The aluminum rims would seize to the steel if one did not rotate tires on a regular basis.
marcspaz reacted to a post in a topic: Marine VHF
Inductive coupling! It's fascinating, but also frustrating when you're trying to tune a mag loop, you get it "perfect", then move your hand away and your SWR shoots up.
most antennas i'm aware of use aluminum for the radials and it's mouting and use SS for the actual antenna mouting hardwae, wo what you report makes sense.
The aluminum tube that hides the coax and mounts to their 2 struts is aluminum, so are the struts. The U bolts that secure the antenna to the mast are SS also. I assume most masts are some sort of steel but there are aluminum masts out there. So there can be some dissimilar metal issues over time between the aluminum and SS components. SS is much better over time in the weather than aluminum is. Time will tell.
Mine doesn't go over 1.02 across the whole band including the 467 repeater channels.
no arguments on the quality or performance of the Comet Antenna..in fact im a bit impressed they arent taking shortcuts in material quality...
You should spend a little time and google this topic and possibly re-read my comment. Yes VHF marine radio is significantly affected byt the inoosphere, is it common, No but yes it does happen just as it does with Broadcast TV. Is it common at UHF NO.. You may want to go back and retract your statement, "30 Mhz will NOT reflect off the ionosphere". That my friend is defiantly incorrect. BTW, i wasn't calling you Bud. I was more currious if you were drinking BUD. Meanwhile here is a little bit you may find on a Google Search: How the Ionosphere Affects Marine Radio: High Frequency (HF) Radio: Marine radio communication often uses HF bands, which are susceptible to ionospheric effects. The ionosphere can reflect HF radio waves, allowing them to travel long distances, sometimes even around the world. Ionospheric Disturbances: Solar activity, such as solar flares and coronal mass ejections, can disrupt the ionosphere, leading to reduced or even blackouts of HF radio signals. Absorption and Refraction: The ionosphere can absorb radio signals, especially during periods of increased ionization density, and it can also refract (bend) radio waves, altering their path. Long-Range Communication: The ionosphere's ability to reflect HF radio waves is crucial for long-range communication, as it allows signals to be transmitted over distances beyond the line of sight. Daytime vs. Nighttime: The ionosphere's characteristics vary during the day and night. At night, the ionosphere can be thinner, allowing for more efficient reflection of radio waves, which can enhance long-distance communication. VHF and Higher Frequencies: While HF radio is strongly influenced by the ionosphere, VHF and higher frequencies usually penetrate the ionosphere and are more commonly used for ground-to-space communications. However, there can be exceptions, such as Sporadic E (E-skip) propagation, where VHF signals can be reflected by the ionosphere during certain seasons.
The stainless steel radials aren't screwing into aluminum. Even if it were, it's a non-issue anyway. Nothing to worry about. Just buy the antenna, assemble, mount and enjoy for many years.
I'll be traviling to from that area in two weeks.. I'll keep my ears open too. Yes, either DMR or TRBO
I have never used a Comet antenna so i can't attest to their product. I have read good things though. I do find it odd they would use stainless steel radials compared to aluminum, mostly because of cost difference of material and the low cost Comet sells at. Is Comet also using a stainless steel base for the radial? if so, there wouldn't be an issue with dissimilar metals.
OK, Marine VHF is at 160Mhz. I said that hams use 145 Mhz which talks right through the Ionosphere to satellites. No reflection. Try to be nice, Nope. Ain't your BUD, so here it is straight. Anything ABOVE 100 Mhz for certain and most anything above 30 Mhz will NOT reflect off the Ionosphere. Which is what you said, which is incorrect. SO VHF TV on any of the upper channels and mostly on the lower VHF channels doesn't skip, reflect, DX or whatever you were referencing. Marine VHF also doesn't do that. Hence the reason that HF comms were required on ships over a certain tonnage by maritime regulation. And the reason that we had MORSE CODE requirements in ham radio for the amount of tie we did. Now that GPS and satellite systems are in place and required on ships, the HF radio requirement is gone. And BTW. When TV went digital, it quit being VHF all together. There are no VHF (below 300Mhz) TV channel allocations any more. https://www.antennasdirect.com/hdtv-station-list.html Look at the list and it will show the station channels are NOT where the claim to be and instead have moved to the UHF band and only claim to be on the original analog channel position. Bud
That's true, but the Comet radials are stainless steel, and so are my temporary substitutes. Comet apparently doesn't think the stainless steel/aluminum interface is a problem. It may be a slightly different composition of stainless steel, but I doubt it's enough to cause problems before Comet sends me some. Meanwhile, I'm doing some testing and trial runs. At any rate, Comet isn't kidding when they say "pre-tuned". SWR < 1.2:1 across the entire GMRS band.
I'll have to listen for those. Thinking either DMR/Trbo, or P25 as likely possibilities.
nugget joined the community
I get that.. I brought up 'Broadcast TV' in my comment as a reference to Marine VHF because Broadcast TV is VHF. Most of us know VHF Broadcast TV reacts to skip off the ionosphere like VHF Marine radio and UHF TV does not, so it was a reference. His first line comment 'Not Sure Thats Right' and the rambling after was a bit boggling.. Thats all.
