https://www.cobra.com/products/performa-radio-programming-cable One of what I thought was its advantages just vanished; it requires a special programming cable and not just any old USB-C will do.
GMRS Radios For Rescue And Recovery In Iran
WRTC928 replied to tcp2525's topic in General Discussion
I can't think of any reason it wouldn't work, but I can think of all kinds of reasons it wouldn't be allowed. - Today
WRUE951 replied to tcp2525's topic in General Discussion
I don't think Iran ever did depend on the U.S. for anything electronic.. China and Russian has been their main supplier and that doesent appear to be changning anytime soon.. -
WQUU855 joined the community
WSIW835 joined the community
WSGN725 changed their profile photo
WSGN725 joined the community
mb523 reacted to a post in a topic: Off Roading
Yes. If you don't have a flat metal surface to use as the ground plane then you need to use a non-ground plane type. Examples would be on a fiberglass boat or some people have off road Jeeps with a plastic cap or cloth cover for the cab. Generally no.
Lscott reacted to an answer to a question: Just one more antenna question
Other than one might look slightly better on paper, there's no real world advantage of one over the other in real world use. Too many other variables come to play such as mounting considerations, feed line, and the position of the stars on any given night. Best to install what works best for you intended use and not dwell too much over what the "experts" say.
Bow reacted to a post in a topic: GMRS Radios For Rescue And Recovery In Iran
• Me • 2021 Taco TRD Offrroad • Depends on the group, but usually GMRS 17 or some FRS channel that works for everybody • Old Mill Creek Rd and Ben Fly in Hickman County, TN.
Antenna mount for 2025 Jeep Gladiator Mojave?
Lscott replied to WRTC928's topic in General Discussion
I have an SG7900 with the UHF mount too. I guess I should stick it on the roof rack and see how well it works. It might surprise me like the CA-2x4SR and NR240CA did. -
WRUE951 reacted to a post in a topic: Password Expired Notice ???
Bow reacted to a post in a topic: Calling all AR-152 owners...
This affected everyone and I don’t believe it was related to our length of membership.
Kind of a weird notice. I’m curious what the time out factor is set at.. I’ve been here close to four years and that was a first. I went to my profile and changed it there and used the same password.
WSHH887 started following Password Expired Notice ??? and Repeater permission
Ignoring requests could also be a nonconfrontational way of telling you NO. As an alternative, you could look up the owners call sign on the data base. That includes their mailing address. Then, horror of horrors, send them a letter. It worked before all forms of electronic communication and still works today unless... https://www.youtube.com/watch?v=PU5xxh5UX4U
There was a fairly serious data breach not long ago. One of the other forum I'm on put that on the opening screen to force folks to change their passwords.
gnig218 joined the community
Thankyou guys sofar. I I am getting help from my friends from talk2me.us in the gmrs department. Thankyou for responding to my text
WRXB215 reacted to an answer to a question: Programming
WSIM797 joined the community
I've been waiting a month for two. I don't think this site is very active these days, or so it seems. Maybe no one is responding to requests anymore. Who knows? lol
I talk 90 miles with a J-Pole for a remote portable repeater mounted on a fibergalss RV. Just as good as my Midland whip mounted on my truck roof.. Performace wise and depending on they type of no ground plane antenna, there is no difference.. Some no-ground plane antennas peerform pretty bad, just as some ground plane whip... Do some research on your antenna choice and see if you can get some perfoamce tips
LeoG started following Password Expired Notice ???
Go to your membership account and change it from there if you worry this is a information grab from a 3rd party trying to steal your information. I changed mine through the pop up and so far nothing nefarious has happened.
meekhotglass joined the community
WRUJ840 joined the community
Other than one not needing any metal to act as a ground plane, no.
I don’t know. Only Rich can answer that question.
I haven't had to change my password ever since I joined the group and now, I'm not sure why we all off a sudden we need to?
WSIU940 started following Question re: grounding for lightning protection
WSIU940 replied to WRTC928's question in Technical Discussion
Yes. WRKC935 hits the nail on the head on all counts. It is also important for the radio system to be bonded in case there is an electrical short between the radio system conductors like antenna cable and any hot conductors of an electrical system. The only way some breakers can sense a fault when a communications line become energized is if there is a return path back to the electrical panel that is bonded to the neutral conductor. The breaker cannot clear the fault without a return path. The earth is a poor conductor and is not an effective fault current return path. Ground fault circuit interruptors (GFCI) sense an imbalance of current on the hot and neutral conductors. If the difference is around 5 milliamps or so, the GFCI trips. This is why a GFCI doesn't need a ground wire to work. It senses when current is being drawn by other sources and that current isn't returning to the source (electrical panel). -
WRWN765 joined the community
*Solved * AnyTone 5888UV Initial Chirp Programming Error
WSIU940 replied to WSIU940's question in Technical Discussion
I also noted something else peculiar with this radio as well. If your right channel is set to a VHF frequency and you tune in to a UHF frequency on the left such as a weather band frequency, the radio shows that it can receive the UHF signal but the volume of that signal is practically mute. It doesn't matter which side is set to main, the audio does not change. In order to hear clear audio, both sides either need to be in UHF or VHF. the radio cannot scan both at the same time it seems. Does anyone know of a setting that may affect this or is the radio just not able to tune into both UHF and VHF simultaneously? -
WSIV598 joined the community
That's my understanding. There's a lot of weather between a sunny day and a full-on direct lightning strike, so we want to protect against as much of it as we can. -
Ah, okay. The wire isn't really carrying a current in the usual sense. Good. 8 gauge wire is a lot cheaper than 4 gauge.
