Its very possible that the wider configuration of the original notch was reducing power output more than the rated <‐1dB. 70w minus 1dB is about 55w. -2dB would be 44w. Figure the meter probably isn't perfectly calibrated, you probably had -2dB of insertion loss with the wider notch, and -1dB with the more narrow notch. The receive side was/is probably the same. However, -2dB vs -1dB is not really noticeable to the user, even though its measurable. It sounds like the second duplexer they sent you was tuned much, much better that the one that came inside the repeater.
WSIP782 joined the community
SteveShannon reacted to an answer to a question: Where to spend budget?
SteveShannon reacted to a post in a topic: Storm chasing using mobile GMRS?
Majik reacted to an answer to a question: New to GMRS Loving It So Far, Looking for Advice on Mobile Setup
I still go outside during sever weather so I can make accurate reports to the Sky Warn Net. But I sure am not going to go chasing any storms. And I will head for cover if I see a tornado heading my way.
If it gets you the distance and clarity you want, it's a good setup. "Good enough" is a valid concept. -
WRTB747 started following SteveShannon
There may even be one or more on this forum who has participated in it. A long time ago. When I was they were younger and more reckless.
WSIU478 joined the community
WRTC928 reacted to a post in a topic: Storm chasing using mobile GMRS?
WRTC928 reacted to a post in a topic: You just got your GMRS license, now you want your own repeater?
Good information. See? I knew somebody here could answer that question.
There's a company that makes custom lengths of 7/8" heliax to order. Their prices seem pretty reasonable when I looked, but might still break your budget. I'd go with the best cable you can get for the main run. Use whatever connectors the antenna uses (no adapters at the antenna end). Then a lightning protector. Then 400 ultraflex to get into the house and to a base station, or a single adapter to a skinny coax with the matching ultraflex on one end and SMA-F (usually) to connect to a hand-held being used as a base station. My preference for outdoor connectors (and in general, actually) is N connectors. I wrap the completed, tested connector assembly in Scotch 88 electrical tape and then slide one of the heat-shrink tubes from a local Home Depot/etc. underground splice kit onto it and shrink it. That makes it watertight (you don't want water getting into your nice new cable). The heat shrink tubing and hot melt glue inside it will make a watertight seal, and the electrical tape means the connectors won't get gunked up with glue if you ever have to go into that connection again. This way you can upgrade your antenna at a later time without worrying about your cabling robbing power. If you use a commercial installer (not on your budget) you should get a PDF or hardcopy of an SWR sweep across your intended working range. Otherwise you can probably find someone with a SW-102 or similar to give you power and SWR readings. At the other end of the spectrum (pun intended) you can go all-out. My plan is 7/8" heliax from the lightning protector to a 20' mast on the roof, then a DB420-B (if the price ever becomes sane again - prices have tripled and Andrew is quoting 4-5 month lead time) antenna . The ground field is eight 8' long ground rods 16' apart connected with a continuous length of #4 copper and bonded to the power entrance. From the lighting protector to the repeater inside the house, I'll be using 400-class ultraflex. If you were in the NYC area, I'd give you a short reel of LMR600 - I end up with anywhere from 50' to a few hundred feet I can't use, on giant (table-size) reels. This is stuff left over from other RF work where LMR600 is preferable. That stuff is so thick and stiff that I made a walking stick out of an N connector on a length of LMR600. It was the end of the day and a storm was rolling in, so I just put connectors on the too-long cables to connect them to the protector bank. 2 days later I came back and cut the lengths down to the proper size, hence the leftover.
Lscott reacted to a post in a topic: SGQ-450D Duplexer - Tune-up and Review
LeoG replied to WRTC928's topic in Equipment Reviews
Ya, I have one of those 97S repeaters. More of a bug out repeater. -
WSEN940 reacted to a post in a topic: GMRS setup info/advice
WRUW493 replied to WRTC928's topic in Equipment Reviews
Sounds good LeoG. I fear that Retevis made a mistake when they upped the TX power. They either didn't have enough isolation in the duplexer, or choose to allow more insertion loss to get a high isolation. Either way is makes for poorer RX sens. I hope I'd dead wrong though and it's good. According to the spec sheet, the 97S is 0.20uV, which comes out to -121dBm. Many years ago when I worked on a project that had a full duplex radio I modified it (in a kludgy way) with a 1dB NF preamp and custom bandpass filter to protect the low NF preamp. The resultant RX sensitivity was about -123dBm, which is as low as you can go in the real world on a 25KHz channel BW. So the -121 of the RT97S is pretty darn good for a "mere" consumer grade repeater. - Yesterday
Charcoal6304 joined the community
WROJ459 joined the community
WSIU872 joined the community
One fellow regularly hits 200 miles. Then again he is a legend in his own mind.
Well I was wondering about that but never asked the question. Since the wideband was tuned flat(ish) I was wondering if it might restrict the power. Just another compromise when doing this type of system I guess. Was pretty shocked to see 70 watts out of the transmitter. Thought maybe 60 at the most. Hopefully the receive will give me the same boost as the transmit.
Jaay replied to coryb27's topic in General Discussion
I'm sorry you're experiencing the grief that you are, in your area. I Wish I could share some of the diversity of the folks here. Most of our Hams are discussing future antenna projects, current projects, ways to help the younger crowd get started with their stations, and even our local Gmrs guys are discussing antennas, tech projects and ways to improve their hobby ! A growing number of our hams are becoming licensed for Gmrs, and vice versa, with our Gmrs crowd seeking out classes for their Tech and General licenses. Most behave and conduct themselves as adults, and try to help fellow operators. -
My local club is blessed that the local radio station has allowed us to put our repeaters at their tower sight. The reasons they are doing this is the fact that we are a non profit organization so its a tax write off for the radio station. The other is the owner supports amateur radio. We still have to have a licensed and bonded person to climb the tower to do any maintenance and we have to pay for our portion of the electric bill each month. We also had to put our own building up (shed) to hold all of our equipment. We are also responsible for any and all maintenance of our equipment to include antennas, coax, etc. Again we are very fortunate that the radio station allows us to use their tower free of charge. There is a real good chance that we will have to move all of our stuff if the radio station ever sells. As mentioned, finding an abandoned tower is not going to happen. They all belong to someone. Finding a tower owner that will let you use a tower for free is not very likely to happen either. Then there is the cost of antennas, coax, repeaters, other associated parts and supplies that will be needed. I sure would not bother installing a Midland or Retevis repeater on a commercial tower. Coax is another story. If the tower has any height then you are looking at more than 100 feet of coax which means you are going to want to use 7/8" or larger Heliax cable. And don't bother trying to install consumer grade antennas on a tower. As good as Comet and other brands are for consumer use at home, they will never hold up installed up high on a commercial tower. You will be paying someone to climb the tower to replace the antennas every few years. Commercial repeater antennas are not cheap.
I'm excited to hear how it goes. An additional 8w out was unexpected, but a plus, for sure.
Didn't you know that watching tornadoes is an outdoors spectator sport here in the midwest?
OK Boyz and Girlz, here we go. I opened up the Btech RPT50 repeater to remove the original wideband duplexer First thing I did was check the output wattage from the transmitter. The power supply was set at 13.8 volts and it was putting out 71 watts into the duplexer. Had 42 watts out of the duplexer. And not the best SWR on my 50 ohm dummy load. Right at the edge of spec. I turned the voltage down to about 11.5 volts and it showed about 65 watts out. Probably the lowest I can get it. Then I swapped the original wideband duplexer for the one that Marc so graciously tune to a single frequency for me (600). I relabeled it so some future person doesn't think it's wideband. I should probably strip the other frequencies out of the channel selection also. And I tested it and got about 48 watts from it. I said what the heck and boosted the voltage a bit and got it to put out 50 watts. I haven't put it back into service yet, soon. And testing won't be done until it cools off from the 98ºF it currently is. Says it's going to be low 70s tonight. Probably be to excited to test things at midnight, so likely around 10 or so I walk my route. Of course I'll key it up on the way home, at home on the base and try an HT from inside the air conditioned house. LOL Most of the duplexers I looked at said "40-80 watts (50 watts)" so hopefully I don't melt this one. The replacement was accepting the 71 watts without blinking and the original had the power supply set for 12.5 volts which is about 67 watts into the duplexer.
WSIV518 joined the community
The attached file is an example I did to do a hex edit hack on a Kenwood NX-411 code plug to get on the Ham 33cm band. The radio programming software wouldn't allow the entry of the frequencies. How to Hex edit Kenwood code plugs - 20241011.pdf
You need to get a windows hex editor. Then you can load in the binary file and edit the specific memory location. https://en.wikipedia.org/wiki/Hex_editor https://www.av-rd.com/knowhow/data/hexedit_archivists-1.html
SteveShannon replied to coryb27's topic in General Discussion
Good edit! -
GreggInFL replied to coryb27's topic in General Discussion
Reminds me of shooting at the range. There are some long-range rifle shooters who consider clays (trap/skeet/sporting clays) to be beneath them. "I shoot at 1,000 yards. What's a long clay shot, 50 yards? Pfft. Too easy." I'd love to get him on the skeet range with a ringer, a 14 year-old girl who recently hit 197 out of 200 at a national tournament. -
Well I am actually going to find that out tonight. I have a Btech 50w repeater and it has a wideband duplexer in it and soon I will be changing that out for a single channel tuned duplexer. The receive should be more sensitive. The receiver will be the same, but the desense should be much less with the >-85db vs the >-45db of the wideband duplexer -
True. Well OK, but the RX sensitivity at the antenna connector is what matters. Do we know anything about how good or not that is? ps: yes IM, Adjacent Channel etc matter in some installations too -
KC8JXA started following Here with another TK880 issue and Programming a Kenwood TK-880: Getting started
Checking first, are these lines of data/code that I am modifying? And thanks for the reply.
UncleYoda replied to coryb27's topic in General Discussion
I have experienced what Marc described, but I learned to avoid them so it has no impact on me. If they are becoming less common it's mostly because the old farts are dying out. Adding to what Marc described, a lot of HAMs want to only have meaningless social chat, which is not what I got radios for. I deleted all the nearby repeaters from my channels because I'm fed up with these people. I asked about joining a club in my hometown and was told no, to start my own. After I moved I went to the nearest club meeting and was mocked for only doing 2m (and 440). I've asked about starting nets twice and was turned down. Gave up on ARES when they made training and deployment as criteria. Skywarn was moved to a repeater I won't use because of policy. Really nothing left for me on HAM. GMRS turned out to be disappointing as well, but I monitor it more now than HAM. Back on topic, there is a new GMRS repeater only up 30ft but the owner wants to link to a node (did he miss all the brouhaha?). Same frequency used by other repeaters that likely overlap his area. From what I recall the linked system owner shut down so I don't know why this is even still available. -
Or I got luck and got one that was fairly accurate. I have two of them and they both read the same for power and SWR. I had one on my home base and when I got the new one I swapped out to see if it would read the same. It did, so I didn't even swap them back. Just took the older one and it'll go into my shop setup.
