  1. Yesterday
  2. LeoG
    CT 625 GMRS
    They had a net going on? News to me.
  3. WSIK532
    CT 625 GMRS
    Thanks I appreciate it very much. im listening to the check-in now.
  4. I here a net check in for the CT area.
  5. dit dit dot dot dit dot dit dit dot dot
  6. I found the thread where I posted my power output results with the Q10H. It is in this thread. about the 935G https://forums.mygmrs.com/topic/9435-kg-935h-power-results/#comment-98687 I tested mine on high power and not ultra high. I always forget that the Q10H has the ultra high setting. 2m - 4.43 watts 1.25m - 2 watts 70cm - 5.9 watts 6m - 1.5 watts GMRS - 3.5 watts MURS - 1.5 watts I have never used or tested the ultra high setting on my radio. As Steve mentioned, 1-1.5 watts is not going to make a difference.
  7. The difference between 4 watts and 5.5 watts is only discernible on a watt meter. It’ll make no difference to range. Just make sure you get the features that you want.
  8. It looks like the KG Q10H is the one I'm going to buy. At 5.5 watts for GMRS, that's the way to go.
  9. WRUU653. Thanks so much for posting those results. You made my day. BTW, I lived on the Central Coast for 33 years... Atascadero. Moved to ID 3 yrs ago.
  10. That would be greatly appreciated. And thanks for the response.
  11. I will have to find the other thread where I posted the output power levels on all band with my unlocked Q10H. From what I remember, they are similar to what @WRUU653 posted.
  12. Yep, using the same playbook again.
  13. Really? Remember this?
  14. LeoG
    CT 625 GMRS
    I contacted him for you. We'll see what happens.
  15. WSIK532
    CT 625 GMRS
    So is there any other way of contacting the owner besides FB, thats kind strange to only use that as a means of communication. I haven't had great success getting my access to my account since it was disabled in Nov of last year. I don't use it much so I was a bit confused as to why. So if there is any other way to request access please let me know, thanks
  16. Here were my results KG-Q10H 2m - 4.5 watts 1.25m - 2.9 watts 70cm - 6.5 watts 6m - 1.1 watts GMRS - 5.5 watts MURS - 4.6 watts also, while similar they are not the same. The Q10H doesn’t do CB.
  17. Probably to make sure the president doesn't get credit for quelling the riots.
  18. No point in trying to have an intelligent conversation with a name-caller!
  19. go back an read my orginal question. in the meant time.. i'm ignoring your crazy azz
  20. Rather than call you names, I will simply point out that no one on this thread, including you, has reported hearing “Los Angeles rioters on GMRS!”
  21. The sheriff didn't do a 180. If they had been in charge from the start it would have been squashed quickly. Totally different mindset between LAPD and the L A County Sheriff.
  22. it doesent stop them from sharing collective information with other agencies like the FBI and DOJ.. I have noticed that LAPD and LA County Sheriff did a 180 take for whatever reason on enformcing the riots. They are actually arresting people like crazy right now.. More than likely becasue the cheif was getting heat for not standing up for hois men and women.
  23. Has anyone done an output power test on an unlocked KG Q10H that will do GMRS? I'm curious to know if the power level of an unlocked Q10H is significantly lower than the Q10G. It would be nice to have the Q10H, but not at a significant power loss for GMRS. The Yaesu HT's with the MARS mod take a significant hit, so I'm wondering if unlocking the KG's will do the same. Also, are the H and G actually different radios or is it just a matter of selecting a MODE to accommodate the H or G? Thanks
  24. Here's the problem with that scenario. This is Los Angeles (I am a life long resident) where currently LAPD and most other police agencies no longer try to arrest criminals. There are lots of reasons why, but basically the citizens voted for this. So even if they can identify a criminal, unless it's a murder(and then it's iffy) the cops don't even bother to respond.
  25. WTF are you talking about?? do we have another SOCAL on our hands
  26. Just as I suspected: hardly a credible source for anything “political”
