Yoter8600 started following Shack Grounding/Bonding
I know this has been discussed and just read a 3 page discussion but it did not answer my question. I am setting up my shack with GMRS and Ham. I understand the grounding and bonding but have a bonding wire routing question. My home was built in 1972 and the service ground from the breaker box connects to the copper water pipe inside the house where it goes through the concrete in the basement. That line runs 5’ under the ground. My grounding rods are about 40’ away on the end of the house. Can the wire for bonding the service ground and mast ground rods be run through my floor joists? It will also pass close the duct for my heat registers. Is that an issue? I read a post somewhere that said not to but have only seen that once. I can’t go in front of my house or I would have to tear up a lot of asphalt and concrete. Going all the way around the back to the front would be about 150’ and pass close to my gas line and gas meter unless I go further out in the lawn. A second question. Should that bonding wire run directly from rod to service ground or can I run it from rod to bonding box where my lightning arrestors are then from the box to the service ground? Been doing a lot of reading and get more confused as I read more. Can’t find anything that really covers my situation.
big difference between HYT and Hytera. Yes HYT is manufactured by Hytera but as a different enity. HYT radios and software are down low in quality and options. HYT is basically another Baoefeng.. Hytera produces commercial stuff competing with Motoroloa and are actually good radios.. And yes, Hytera, like most Chinese companies, have stolen technologies, most notably from Motorola to win some dominance in the U.S. Lots of school districts and low budget cities and counties used Hytera Radios until Motorola sued them for stealing their technologies. However, that doesn't stop me from latching onto their repeeaters, which are pretty damn nice.
you live in Montqna
WRUE951 reacted to a post in a topic: Ebay banning certian radio equpment sales
Yoter8600 joined the community
Sweet, I'll have to give it a try.
wayoverthere reacted to a post in a topic: Radioddity DB20G
SteveShannon reacted to a post in a topic: Radioddity DB20G
That would do it. It doesn't say anything about recreational use, but they probably don't sell enough for that purpose to be worth shipping them.
The search terms you use can make difference. I've been looking at Dell and HP workstations with dual CPUs and I get different listing depending on what I type into the search bar. Same thing with GMRS Repeaters.
SteveShannon reacted to a post in a topic: guest
They can give you two but you must really must need the second one. They are getting very pis*y-as*ed about people getting multiple DMR ID's, and don't need them. DMR can only handle a max of about 16 million ID's. If they don't clamp down on people getting a bunch sooner or later those will run out. I don't see that happening any time soon but you do have to watch out. I believe you can use your DMR ID for P25 as the CCS7 ID. I haven't looked at this in a long while so I could be wrong on this part. While you're there you can also apply for an NXDN ID too. I have both so I'm covered for all three modes. DMR: 3122951 NXDN: 765
WRWP781 joined the community
I had no idea. Thanks for the heads up. I edited my post.
Northcutt114 reacted to a post in a topic: guest
MarkInTampa replied to WRUE951's topic in General Discussion
There are still lots of Hytera radio's on eBay, search for HYT instead. Ebay search results for "Hytera radio" showed 304 results but for "HYT radio" shows 4,700+. -
gortex2 reacted to a post in a topic: Ebay banning certian radio equpment sales
Have they updated chirp for the db20g/anytone at779uv? Last I saw, work on that was stalled. That said, I *think* the setting to change is under the "function setup" in their wonderful software...look for "Up VFO/MR" and "Down VFO/MR" items, if they're available in the GMRS proflle. Mine are both set to MR, and mine consistently start up on the memory channels. That said, mine are unlocked and being used as inexpensive ham radios, and as far as I remember, the unlocked profile opens up more settings not available in the GMRS profile. (And yes, I dug out my programming laptop and the radio I have with my travel stuff to pull a live profile to look at the settings)
SteveShannon reacted to an answer to a question: Need help contacting a repeater with a Midland 115 mobile radio
SteveShannon replied to WRUE951's topic in General Discussion
I still get plenty of gun parts. Maybe you have a setting set somewhere that filters them out. -
Where have all the GMRS Repeaters gone?
wayoverthere replied to TNFrank's topic in General Discussion
For your Phoenix batch, are they offline as in tried using them and no luck? Or not showing up in the listings? The listings here will drop a repeater to "stale" if it hasn't been updated in awhile (1 year, I believe), and you have to turn on the "show stale repeaters" option in the list/map to see they're still there -
There use to be 4 or 5 repeaters that were in the Phoenix area that I could hit, now I only see one, Phoenix 650 as being up and running. What's happened to all the GMRS Repeaters? Here's a list off of RepeaterBook. There's only 20 Repeaters and 3 of them are down so that leaves 17 for the entire State of Arizona.
H8SPVMT replied to WRUQ683's question in Technical Discussion
First do a, "Factory Function" (reset) on the Midland and then re-enter all the pertaining setup fields like: Rep - select "ON," etc. Set "TALK" - OFF Now go to CH.Rp 17 (467.600) and listen for someone to communicate on it. Personally, I would wait on putting the privacy tone in until I actually hear the repeater operating myself. Then input the privacy tone 90, if that is what you need. -
This guy has a good video on programming the DM-1701. According to the video "Private" will only TX to the radio you selected. Also, you're only allowed one I.D. so I don't think they'd give me more than I'm allowed.
Might be eBay overdoing their restriction of listing items then. Not like they are known for going overboard on listing restrictions. At one point you could buy almost any firearm part available on eBay that didn't have a serial number. Now you can't find a listing for a childs nerf gun if the word gun is in the listing. Moto may have said no more Hytera, and while they were at it claimed the software in any Motorola was non-transferable and they couldn't be sold either. I haven't looked at what you are talking about, but I don't really have a frame of reference to know what it was to compare it to. It's hard to say what eBay is doing. And the Motorola thing may not have anything to do with the lack of Hytera listings on eBay. But it makes the most sense.
WRZC582 joined the community
Go to the repeater site. It’s the same log in as this site it but you have to do it separately. I use the map so I can see where they are, type in your area and click on the repeater and it’s info will come up. You can also click on “repeaters” and click “near me” or enter what you like.
Check out the repeater map and then contact the owners of the ones you want to use.
You probably clicked the website button twice after thinking the first time it did not go through...
How can I find out what repeaters are available in my area, and the information zi need to be able to use it.
@Northcutt114 just an FYI as I’m sure you are unaware and I’m sure your intentions were good but it is against the sites rules (found here) to post repeater information (especially tones on a private repeater) to the forum site. The forum is public while the repeater site info is reserved for members. You can link to the repeater and if the guest is a member they can see the info, but you shouldn’t post it here. Private content. Do not post sensitive information such as repeater PL/DPL (also known as privacy or CTCSS/DCS tones) tones outside of the Private Discussion forum. This is to protect sensitive information from being picked up and indexed by search engines such as Google and Bing. Also, do not post any personal information about our members, including but not limited to, their home address even if it is publicly available by searching online
WSJV482 changed their profile photo
I can't speak for others, but my repeater is marked private and I've never denied an access request so far. It's just got unlisted tones (input and output different to make blind searching a bit more difficult). I try to respond to all requests within 2 days maximum. OTOH, I sent access requests a month in advance to 3 repeaters in another state I was going to visit. One took 2 months to respond and I still haven't heard back from the other two 5+ months later. Putting up a good, solid repeater can run up considerable expenses, depending on your choice of equipment. So controlling who uses it is reasonable. Particularly since anything going out over mine (at least) gets my license Morsed out after. I monitor my repeater's output frequency without tone, so I get to hear my repeater's traffic, other repeaters in the area, and simplex traffic. There's a bunch of afternoon traffic (presumably FRS) from local schools calling for buses to come in and also to alert the office that a parent is waiting to pick up a particular student. In the evening there's often the same two guys on another private repeater using the same channel that I'm on (unavoidable in an urban environment, though they're far enough away that I need to use a roof antenna to hear that repeater). They never ID and the repeater doesn't break in to ID, although it IDs at the end of their conversation. They talk about mundane stuff each evening for a few hours. Tonight it was burgers and Doritos. I have no interest at all in reaching out to them to discuss rules, etiquette, etc. - they're registered on someone else's private repeater and it's up to that repeater's owner to enforce any rules / etiquette. My average repeater user with a handheld will never hear them - they're too far away. Live and let live... I'm going to be setting up an open GMRS repeater for a friend in the Mojave Desert either this fall if I'm recovered enough from surgery to do the lifting and hauling, including running 500' of 8/8" Heliax up the side of a mountain in the Nopahs, 1050' AGL, otherwise next spring. The coverage for that should reach from parts of Death Valley to well south of Dumont Dunes (elevation is king!). Just don't get me started on antenna grounding in solid rock in a desert... This should let the duners order pizza well before they make it it to the nearest pizza joint - when I was up on top of the mountain doing site planning last fall, during radio checks with my 8W handheld I had some duners ask me if I could let the pizza place know their order. Out there, GMRS repeaters are a public benefit - the local landline carrier (ATT) has completely abdicated and you can't get phone service, and extended power outages are common - in fact, Southern California Edison just got power back on yesterday after a nearly 4 day outage.
I think only they will be alerted but anyone on the same Timeslot and frequency (and possibly color code) will hear you.
