  2. I just emailed the owner. just to see what he says.
  3. Still not getting any response from the repeater itself....
  4. I would buy a pre tuned antenna if just starting out in radio. It will be much simpler and easier for you. A good antenna analyzer or NanoVNA is a must if you are going to properly tune any antenna. There are plenty of free online calculators and phone apps for figuring out the lengths of different types of antennas. A friend has a big roll of solid core 75 ohm cable that he uses for making 2m, 70cm, and GMRS j pole antennas. It's not difficult with knowledge and the proper tools to include analyzers/NanoVNAs. I will say that there is a bit of a learning curve with a NanoVNA. A good antenna analyzer won't be cheap. I have made a few wire antennas for the HF amateur bands but I could not have done it without an analyzer or NanaVNA.
  5. How close are they to each other. You might be experiencing desense. Make sure you separate the two radios by about 50 ft or so and try again.
  6. Here is my findings. I have setup an HT programmed via CHIRP with two different tone settings for this REPEATER: WRPB502 WX4DAB REPEATER 1 set with TSQL 123.0 REPEATER 2 set with TONE 123.0 Second Radio is on GMRS CH15 which is received on REPEATER B clear... but cant transmit back out of REPEATER 2 or 1 to Second Radio.... Any thoughts?
  7. Microwave ovens are faraday cages. You can always put your phone into a faraday bag and then into a microwave. I don't suggest turning the microwave on while the phone or bag are inside. Faraday clothe, just like any other type of clothe, will have holes in the weave which will let some RF pass through. Ideally one would want to use the tightest weave faraday clothe and place that inside a metal container. Ideally one would remove the battery also. But most modern smart phones do not have removable batteries without having to disassemble the phone.
  8. Probably why an EMP bag will let high frequencies through at strong signal levels. The bags are designed for a dc generated pulse.
  9. Today
  10. The higher the frequency the shorter the wavelength and the smaller the opening that can penetrate.
  11. I like making my own wire antennas for ham radio and I have an antenna analyzer and a nanoVNA which both help with tuning (interchangeably-you don’t need both). It’s one of the more rewarding aspects of amateur radio, and tuning an antenna that is designed to cover the range of frequencies to a specific frequency such as for GMRS is straightforward, but there’s a learning curve for the process and the tools. Like many hobby projects it can be very frustrating if you don’t have a mentor close by.
  12. Thanks for the responses guys. I think now it is just easier to buy one. I might try to tune one eventually just to get the experience. Looks like there are a couple with good reviews on Amazon.
  13. Let us know how that goes.
  14. Thanks for all the input! Oh, and if you are a DAD, Happy Father's Day in advance!
  15. Yes I use CHIRP for programming my radios.
  16. I have one of those as well.
  17. now you got me thinking.. Tomorrow i'll break one out stick my HT in one and see if i can talk with it from an other radio..
  18. Trying to get us a Repeater
  19. I have a metal box with overlap and metal taped edges that my vehicle still detects the fob thru. The chip signal amplifiers are pretty strong. For improved security I took the battery out of the fob and now the chip has to be within a half inch of the start button.
  20. Yesterday
  21. Chirp has been instrumental in helping “unlock” certain GMRS radios that come from the factory locked down to satisfy FCC requirements. The Baofeng UV-5X(G) comes to mind
  22. That would be a lot of hugs. I'm 1 of five boys and all of us are married, plus five grandkids.
  23. Hugs for Days !!
  24. i have some from Nest that claims to be military grade. Big enough to hold a HT with antenna. These are more designed for EMT protection with i would think would work against cell phone detection.
  25. 1) NO 2) You would be able to transmit on non-GMRS frequencies but still have the convenience of having the pre-programmed simplex and repeater channels.
  26. There's no advantage; you could just get a UV5R.
  27. Has the UV-5G been unlocked and what's the advantages to doing so? I'm just wondering.
  28. What would be a good source?
