  2. Of course they will "improve" this radio. Their business model demands it. Not saying this won't turn out to be a very nice radio at an affordable price, but.... In 12 months an updated version will be available with some of the features you want, but not all. In another 18 months a newer version with even more features and capability will be released. That hamster wheel of "improvement" and release of "updated" radios will continue to spin indefinitely. But manufacturers will always stop short of giving us exactly what we want. I may be wrong. But I suspect it would not be too hard for BTech to build new radios with all the capability, bells, whistles and unicorn features we all crave right now. But then how would they get us to repeatedly spend hundreds and hundreds of dollars every year on new radios when we could just get we wanted in the first place and use it for a decade. LOL I'm sure it goes the same for all our other friends in China who manufacture radios. And, would probably hold true if an American company started manufacturing budget style GMRS radios. Kind of joking....But kind of not.
  3. I thought you hated Midland..
  4. I just logged in without any issues.
  5. Today
  6. I can definitely believe that. But transmitting on one H3 while receiving on the other H3 doesn’t affect the final transistor(s) (the output transistor) on the receiving radio.
  7. I've been unable to login to CORES. Have others had luck this past week?
  8. A mag mount Midland ghost antenna may be the best bet. You can move it easily or it will get nocked off vs breaking. And you can buy 4-5 of them for the price of a heavy duty one. You can get creative with placement depending on the skid steer as well.
  9. I have had my H3's trigger my GFI in my bathroom.
  10. Looks like a nice option for my vehicle. I have limited space, so a remote mount unit like this would work well for me.
  11. Love mine too. I'm up to buying 14 of them. Had 2 bad ones that were replaced without issue. I have 6 of them that I can use and the rest given away to family and friends.
  12. OP what route did you go and how is it working??
  13. I really like the h3 as well. It’s a Fantastic “beater” ht and one of of mine has been a beast taking all kinds of drops and falls and still working great. Loud speake and significantly Better RX than baofengs and easy menu editing.
  14. They have had some spotty quality control, unfortunately. I really like mine, I have 4 of them. All tested good. But there are some that seem to just show up broken. A programming error where you couldn't transmit would get you the "YOU CAN'T DO THAT DUMMY" beep when you key up. If it's not doing that, and it's just outputting 0W, then yeah, they're probably NFG.
  15. Thanks guys I did multiple factory resets. Switched to gmrs mode with factory programming and no output wattage. Did the same with ham mode as well no output wattage there either. Kinda at a loss at that point and just sent them back. Super weird. They worked good out of the box. But subsequent resets did not fix them. (tested into a dummy load)
  16. I thought it was one that's been neutered
  17. Does anyone here know about 'Battleship by Radio"? I heard some people playing the other night and it sounds fun! I'd like to get more information.
  18. When I was an electrician in 1980, I bought a new Fluke hand held digital multimeter. It worked perfectly until about 2 years ago, when it was inundated with saltwater in a flood. I found it several days after, soaked/rinsed with fresh water, then 90% alcohol, but when it dried out, all the control buttons were fused with corrosion. Total loss. I bought a bench model Fluke DMM among some other used test equipment about 20 years ago. It was at least 10 years old when I got it. It too worked perfectly until about six months ago. I turned it on and the display was crazy and it would not respond to the controls. Have not yet decided what to do with it, I may send it back to Fluke because a direct replacement is over $1k. Meantime, I bought another new Fluke hand held DMM. As with the other Fluke instruments, it was pretty expensive, but if it provides the same level of service my other two Flukes did, it will outlive me by a decade or two.
  19. Yes, good test equipment will last a very long time. Still using an old Fluke 87 (no series III or white backlight here). Leaking LCD crystal around its display.....and believe it or not, a metrology tech put the main knob on in the wrong position, had to correct that myself. (My personal fluke ended up in the work pool as it looks like many others.....has happened with a Motorola XPR7550e radio as well). Black gasket broke, so electrical tape seals the gap in places.....but still accurate and great for use in dark corners of electrical cabinets or floor board of cars. Some co-workers bought the cheaper Kelin Tools multimeters, only to find they lacked a backlight. The old expensive Fluke 87 continues to do the job (suspect mine is 30 years old or so). By once, cry once. Get good gear.
  20. I think Steve nailed it.. Programing error. Factory reset try again.
  21. Umm. As much as a can’t stand h3 radios I’d bet something else is going on. Normally I see a 50% fail rate not 100%. I agree they may have gone into ham mode some how so they won’t tx on gmrs or something similar in the programming. I’d reset everything and make sure they are both in gmrs mode then try again with programming. Maybe just dial up a simplex in vfo mode and see if they can communicate. I’ve never had any radio blow anything when tx,ing very close to one another.
  22. Being within a couple feet of another should have no effect on the finals. I bet that something with the programming resulted in inhibited transmit.
  23. Thanks I will try them.
  24. Purchased a two pack of h3’s. Checked their power output when I opened them both were about 4.4 watts. Connected them to the antennas, and programmed them with chirp for local repeaters. Radios Wouldn’t connect to repeaters, I checked the power output and nothing. Tried the other h3 from the same pack. Nothing. wow. I’m scratching my head trying to figure out if something I did fried them or if this just happens with these cheaper ht’s? Can keying an ht next to another one fry both of them? I have 3 other cheap ht’s that work perfectly yet these two died instantly after the initial power meter test. I try not to ever key a radio when it’s within a couple feet of another one but if I’m being honest I did do this on these by accident but I’ve done this to my other ht’s a time or two and they all work fine to this day. sent them back. Hope these h3’s aren’t super fragile and pop their finals if they get any sort of rx overload from a close transmitter but that’s the only thing I can think of that might cause this?!? I would think this could damage a RX section of a radio not the transmitter section no?
  25. Fortunately my work never involved more than 220. A lot was DC control power and 120 that was relay controlled to the equipment. But an old electrician gave me some advice early on. Have two sets of tools. One for electrical and the other for everything else. Keep them in separate tool bags and never mix them. I always bought the best tools I could afford. Retired now I still keep my electrical tools segregated from my others. Old habits die hard if you follow them, you will too.
