WSJP885 joined the community
WRTC928 replied to marcspaz's topic in General Discussion
Repeaters are cool, but you don't need a repeater to get more farz from lowband than you currently can with GMRS UHF. For some settings like ranching/farming operations, you might be able to replace a repeater with a single base unit. The antennas might be too long to be practical for handhelds, but they'll be shorter than CB antennas, so mounting them on vehicles and equipment should be simple. It's possible the radios would sell well even if repeaters were slow to come online. -
I have several of the 3,800 mAh batteries and they have enough juice for 24 hrs or so. That big battery should provide plenty of talk time. I have several radios that use the same battery. Maybe I'll buy one eventually.
Raybestos reacted to a post in a topic: Dear Mr President Trump...
It's a power supply, not an inverter. An inverter takes DC and changes it to AC. Good chance the power output will be a bit lower. Probably won't matter that much though. Unless your normal signal is going through obstacles such as trees.
WRTJ370 replied to marcspaz's topic in General Discussion
After reading these comments I feel like a majority of the people think the public hobby sector of radio has enough of the spectrum. Maybe we should petition to take some away from all the services like ham gmrs/frs and murs so they don't take up as much of the spectrum. 6 meters has been great this year so I'm not opposed to this proposal but have you tried 11 meters? It's free and has been open almost every day this year and people run big power there all day long,10s of thousands of watts and nobody bats an eye. Just don't link your gmrs or ask for lowband I guess -
yup.. could be a chrger too. Some people with big linears use chargers for whatever reason.
The more I think about this I think maybe you’re not really talking about an inverter but rather a 15 amp switch mode power supply, 110 volts AC input and 12.9 volt dc output. Is that correct?
lburbank joined the community
personally, I don't use networked repeaters.. Although i've had plenty of opportunity as there are quite a few out there, I shy from the practice because its not legal.
Welcome. Sounds like you’re doing everything right.
WSJI201 changed their profile photo
I have 3 of them, all work fine. I just make sure I take the battery off to charge it.
Will it lower your output power? In my experience, it often does. Will it lower it enough to matter? In my experience, no.
Hey y'all I'm about 48 hours fresh into my GMRS license so please bear with me as I likely touch the third rail. Although I plan on spending 90% of my time on simplex there's a few spots in my area where I'll be graciously utilizing my local repeater. Within my short time with a license I've discovered that several of my states largest repeaters are connected. Double edged sword because I've actually chatted up a bunch of people all over my fairly gigantic state today. It's been pretty awesome, really nice people and I could totally see myself nerding out on the network. The other side of that sword is that I've read over and over again that GMRS traffic is slow to non existent these days. Not that I was happy about that, but as I was looking to mostly try and communicate with my wife and daughter a handful of times a week with this that actually sounded kind of nice as that was a chunk of the appeal to the whole family license. It's not that either of them would mind as everyone I've heard on the radio has been nothing but polite and G rated, but then I also don't want to be ruining other people's good times with my seven year old checking in with me here and there. So tl;dr the entire state network is awesome but now I feel like using a local repeater feels a lot less local. Trying to be vague as I'm certainly not looking to put a spotlight on any particular area but just wanted to see what the thoughts were amongst the crowd here. I've been lurking for a couple months and the community seems awesome so thought I'd seek opinions. PS, I'm obviously really green in this space so please fill in the likely canyon-sized holes in my knowledge if I'm missing something. I have transmit and receive tones of my local repeater programmed but still get everyone.
It really depends on the design. It probably will still be enough. Just hook it up and see.
A lot of power supplies have an adjustment for the output voltage that ranges up to 15%. Does your supply have an adjustment? Post the model power supply and where it came from and we may be able to help you find an adjustment screw or give you better advice on what to do. I
I bought an inverter for 110v to Dc 15 amp for my 20 watt mobile. When I plugged it in it shows 12.9 volts. Will this lower my output as the vehicle outputs 13.8 volt.
207 joined the community
Can the Anytone AT-878-UVii still be unlocked for GMRS?
WRUE951 replied to WSJL659's question in Technical Discussion
As of last April. Yes -
Wow, check out this big bruit battery from Baoefeng and the price. https://www.baofengradio.com/products/battery-5200mah-bl-5rhplus-usb?utm_source=Klaviyo&utm_medium=email
WSEI546 joined the community
BoxCar replied to marcspaz's topic in General Discussion
The FL DOT was a big user of low band VHF but found the supply for new mobile radios dried up. Their last supplier, some 10-12 years ago, was Midland. Before that I believe it was GE and Vertex, -
SteveShannon replied to WSJL659's question in Technical Discussion
Adam, When you use the CPS for the radio there’s one place where you can set the range of the radio. What choices do you see there? That should answer your question. -
nokones replied to marcspaz's topic in General Discussion
I'm not sure what happened to the hundreds of the conventional (non-simulcast) GE Master IIs that were taken out of service several years ago in California and what make stations that replaced them a few years ago. The replacement stations may take a while until they are taken out of service because of migration to 700 MHz system. Also, there are almost a hundred Micors Simulcast and about 50-60 Quintron Simulcast stations that were taken out of service. However, these simulcast stations do not have the local CTCSS encoding modules for these stations because the CTCSS was centrally generated from the control point. Good luck in trying to obtaining the parts. These stations were not repeater stations. The mobile inbound (voted audio) traffic was rebroadcasted from the control point and the receivers used a separate antenna than the transmitter antenna with vertical separation. The stations were either 39, 42, 44, or 45 MHz transmitting stations. A lot of cavities and intermod panels had to be used -
WRUE951 replied to marcspaz's topic in General Discussion
right now relatively easy and kind of cheap. I'm sure everyone will be building repeaters but if this approves current off the shelf will be just that. "off the shelf' Gone.. Like Mark says, the duplexers are giants and i remember a time whan they were thrown away as junk.. I can lithely remember Placer County tossing them after trying to give them away.. Those days are gone. Now you can't find them. -
The mystery of the MXT-400 that can ....Talk Around Feature
H8SPVMT replied to H8SPVMT's question in Technical Discussion
MIDLAND AI said: "When you enable the Talk Around function, it only affects the individual channel you’re on—not all channels at the same time. It uses that channel’s RX/TX frequency and its stored Privacy Tone settings, so you can chat directly if the repeater’s out of reach." And if that is the case, I don't think the problem is with my setup. I am inclined to think it is the repeater then. -
Turn off the Music (or tones) on Startup
OffRoaderX replied to steved52's question in Technical Discussion
You can't. -
marcspaz replied to marcspaz's topic in General Discussion
This is almost all there is in the amateur community. If people want it, they will spend the money and find a way. Also, I doubt any companies will tool a new radio for low-band GMRS, because most HF amateur radios already transmit on all of these frequencies. I guarantee you, if the market opens, damn near every HF amateur radio manufacturer will spend the very few dollars needed to have their engineers write new code to limit existing radios to the low-band GMRS specs. The duplexers are pretty big... about 86" tall. However, the bigger they get, the easier it is for a DIYer to make one.
