For those that don’t think the FCC will enforce anything.
WRTC928 replied to warthog74's topic in FCC Rules Discussion
It wouldn't surprise me at all if they threw that charge into the pot when taking action against someone for being an ass and/or interfering with government communications, but as a stand-alone charge? I'll believe it when I see it. -
WRTC928 reacted to a post in a topic: For those that don’t think the FCC will enforce anything.
WRTC928 reacted to a post in a topic: What did I do wrong?
I'm pretty sure the Anysecu WP9900 and QYT KT-9900 are the same radio, and the BTech 20V2 is the GMRS version of it. I consider it a decent-but-not-amazing radio for the price. TBH, 25 watts is plenty for almost all of my needs. I have a TYT TH-9800D in the car, and I almost always run it on 12 watts. I've hardly ever bumped it up to 35 or 50, and even then, it usually didn't make a difference. Yes, I do understand the quality difference between CCRs and some of the "big name" products, but I'm just a hobbyist. Nobody is going to die or even lose any money if my radio doesn't work. I'm willing to take a hit on the quality to get the form factor I want. In December, I ran a WP9900 on a trip from central Oklahoma to Branson, Missouri and hit 2 meter and 70 centimeter repeaters all along the way without difficulty, which is really all I use a mobile radio for. In the house where I have plenty of room, I run an AnyTone AT5888UV III tri-band unit and I'll probably end up changing out the TYT in the car for one as well. On the roof of the car, I have enough ground plane to run a tri-band antenna. If I decide to install a CB, that will require another antenna, but I'll deal with that if I decide to do it. My problem in the truck is that I have crap for ground plane and I can't get a tri-band antenna to work well on 2m, 1.25m, 70cm, and GMRS, so I've resorted to three antennas and three radios. I have a AnyTone Graces CB with all the controls in the handset feeding a dedicated CB antenna, A QYT 7900D tri-band radio running as a dedicated 1.25 meter unit with a dedicated 220 band antenna, and a TYT TH-9800D for GMRS, 2m, and 70cm on a Diamond "Super Gainer" antenna. I'm planning to remove the TYT and mount the QYT on the seat bolt pedestal mount, then put the WP9900 back in for GMRS, 70cm, and 2m. I can't find a 1.25 meter radio with all controls in the handset or a removable faceplate, but the QYT is really tiny and should be minimally intrusive on the Lido mount. I suppose I could use a tri-band radio and a diplexer to a 220 and a 140/440 antenna, but TBH, that requires as many pieces of equipment as I have now and my current solution is inexpensive and modular. I agree with the clean, low profile aesthetic. I also have to take into account that I have a single-cab truck and I don't need a whole bunch of bulky stuff taking up what space I have and being climbed all over by a 65 lb dog. I'm convinced there is some degree of "snob factor" in ham radio equipment, but it's also true that a lot of hams are trying to get more out of their equipment than I am. Perhaps someday I will be too, and perhaps then I'll "move up" to a more expensive radio. And there's certainly something to be said for a radio that doesn't blow out the finals if you key up on a too-high SWR. So, yeah, prestige plays a role, but there's more to it than that, at least for some hams. But I really do believe many hams like the look of a whole bunch of radios crowding the passenger compartment.
This is true if they have multiple FRN's
I can verify what Steve said. Some amateur band radios that have been modded/unlocked work fine on GMRS while others don't work as well. My MARS Modded Icom IC-2730 does not do as good of a job on GMRS as my unlocked TYT radios. Remember, radios are like potato chips, you just can't have one or two.
Im not sure you can determine someone doesn't hold a license using this method. I only have two licenses under the FRN that my Amateur and GMRS licenses are under, but I have multiple FRNs. And unless you know what names are associated with my other FRNs, you're not finding them.
WRYZ926 reacted to a post in a topic: Wouxun KG-UV980P impressions
It’s possible for a person to hold different FRNs. GMRS.app will (I believe) find a person who holds different licenses under different FRNs. It appears to look at the address rather than just the FRN.
Everyone has to have a FRN number no matter if they hold a MGRS license, amateur license or multiple licenses. That's why I looked him up using his FRN. And according to the FCC database, he does NOT have an amateur license, he only has a GMRS license. If you go to the FCC website and look up a GMRS call sign, it will not show if they hold any other licenses. If you use the Advance Search and search by FRN then it will show all licenses held by that person the FRN is registered to. That website showed two different GMRS call signs, the last name, middle initial and location are the same but the first names are different. The first call sign is his and the other is listed as possible match.
WSII811 joined the community
You can also use this website to see if a GMRS licensee is also a ham: https://gmrs.app
you mean after all that hype he is a Ham
WRUE951 reacted to a post in a topic: What did I do wrong?
wyattearp477 joined the community
WRXB215 reacted to a post in a topic: BTECH GMRS-20V2 20W IP67 GMRS Mobile Radio-Can I listen to HAM traffic?
WRUU653 reacted to a post in a topic: Recommendation on a mobile with removable faceplate
WRUU653 reacted to a post in a topic: Wouxun KG-UV980P impressions
WRUU653 reacted to a post in a topic: What did I do wrong?
WRUE951 replied to WSIK420's question in Technical Discussion
.I've got 22 HT's 15 are brand new in the box... Mostly Baufangs When i got hooked on Hytera HT's i quite playing with the Baufangs. I still like my Wouxuns -
WSIJ227 joined the community
Bogieboy01 replied to WSIK420's question in Technical Discussion
Not knowing what your locale presents for terrain, i live in the fingerlakes region of NY, and have a mix of plains like and some more hilly terrain, but my mobile setup is an anytone 778uv, with a cheap ghost antenna (stubby) on a mag mount on the back end of my subaru forester next t the stock fm radio antenna, and i can hit the local repeater 30 miles away with no issues. My "base" unit is also an anytone 778 uv, with a cheap amazon "6 db" pl239 mount antenna mounted on a ground plane on the end of a 10ft piece of conduit screwed to the side of my apartment building LOL and that can reliably hit the local repeaters from 25 mi away as well... the mag mounts do make things significantly easier on the cars, aside from what car washes you can use...LOL -
MSnow replied to WSIK420's question in Technical Discussion
I have tons of radios, when I caught the bug i started getting everything that came out and seemed awesome. Unfortunately most of that is marketing. Here is what I found. When it comes to GMRS radios none of them are as good as the Wouxon radios, for mobile the KG1000g plus. The MXTA25 is one of the best if not the best antenna you can get it really is amazing. With that said if your not mounting it with a ground plane like the middle of the roof you would be better off getting a ground independent antenna. Comet has the GI series coming out they are primarily designed for vehicles that are not made of steel, but will work well for fender mounts. The other options that are good are to get old commercial radios like Kenwood, Motorola, or iCom. Hope it helps. -
Majik replied to WRKW444's topic in Equipment Reviews
Yes, and you only get GMRS channels. No VHF/UHF scanning or VFO tuning. -
Majik replied to WSIK420's question in Technical Discussion
50W is a lot and generally overkill to hit local repeaters. And in many cases, you won’t get enough amps to the radio to really sustain 50W. I’d say 25W mobile radios are more than plenty. And if you still need a little more range (?), try a higher gain antenna with a better ground plane position. IMHO -
WRYZ926 replied to WRKW444's topic in Equipment Reviews
The downside to the Midland GMRS radios with everything in the hand mic is that you can only program them through the radio. There is no option to program them using a computer. -
Question about iCom ID-5100A and Repeater Tones
WRYZ926 replied to cmranch's question in Technical Discussion
I have a IC-2730A that has had the MARS Mod done. The TYT TH-7800 and TH-8600 both do better on GMRS compared to the IC-2730. The unlocked TYT radios have better receive and transmit audio on GMRS. -
I looked him up by FRN and the only FCC license he has is a GMRS license.
Can’t vouch for this myself, but recently found this guy that sells a head detachment kit for the AT-778UVII (which is a great budget 25W mobile radio.) https://www.ebay.com/itm/255048462858 I may try this later. If I do, I’ll post my results. -
I, too, shopped forever to find a small ~25W mobile radio with a fully integrated mic or a remote/detachable head. The 20V2 is about the only thing there is in that category, but I was off-put by the reviews and the 20W limit. I ended up with an AnyTone 778UVII 25W mobile radio. This thing is great! And I also recently discovered there are folks out there that have successfully detached the faceplate and ran a cable from it back to the radio unit. There’s an Aussie selling a kit for that on eBay. Might do that later, but for now I’m pretty happy with this thing.
Majik changed their profile photo
WSCK241 joined the community
Majik joined the community
WSIM645 joined the community
WSHA318 replied to cmranch's question in Technical Discussion
your better of getting the IC-2730a with mod to access GMRS RX-TX , I am able to use it. -
GreggInFL replied to WSIK420's question in Technical Discussion
I'm new to this also and went through the same progression, i.e. HT to mobile, with the expectation of eventually adding a base station -- maybe a repeater at some point. All this would, obviously, require lots of equipment and a modest stack of bucks, especially with more than one vehicle in the household. I've satisfied all of my use cases and spent a total of less than $150. How? By making everything portable. I have a 25W mobile radio and a small 3dB mag mount antenna. The radio plugs in to the cars' cigarette lighters so nothing is hard wired. I can move it between the cars and bring it inside to use as a base station. As I type it's sitting behind me in a closet atop a pizza pan hitting a repeater that's about 30 miles away. Hell, I could use it on my fiberglass boat but I don't want to explain why I have a pizza pan on the bow. Is this top-notch gear? Nope, but it works very well for me. I'll eventually upgrade (probably the antenna), but for now everything is working everywhere, and I haven't drilled a single hole. Oops, forgot the new inside power supply, so let's call it $200 total. -
WRQC299 started following What did I do wrong?
Gusto00si joined the community
allanbegg joined the community
WRVB562 joined the community
