CoffeeTime reacted to an answer to a question: No Matter What The "Experts" Say You Simply Can't Do This With A PL-259
gortex2 reacted to a post in a topic: GETTING READY FOR DMR IN MY VERY NEAR FUTURE
gortex2 reacted to a post in a topic: Unlisted GMRS repeaters
TerriKennedy reacted to an answer to a question: Swr change.
WSIF274 joined the community
FishinGary reacted to a post in a topic: Well that was a surprise
aaschrage8793 reacted to an answer to a question: CTCSS/DCS baofeng Uv-5g Pro
SteveShannon replied to tcp2525's question in Technical Discussion
Seriously, why not? They are not that much different to install than PL-259. In fact with these M&P connectors you don’t even need solder: -
GrouserPad reacted to a post in a topic: Fixed Station vs Base Station?
Podrius joined the community
WRCR724 replied to tcp2525's question in Technical Discussion
I prefer beignets. -
Maybe the repeater owner passed away and no one surviving knows anything about this site?
GrouserPad replied to tcp2525's question in Technical Discussion
Agreed, and I could replace a pl259 in the field with a soldering iron and a sharp knife. I personally could not do that with an N type. -
In only two characteristics is the PL-259/SO-239 system slightly better than the N connector: ubiquity and durability. A person can break an N connector, but it requires a certain carelessness. By ubiquity, I mean that I think I could find a PL-259 and SO-239 connector anywhere in the world. I don’t have the same level of confidence in the N connector anywhere. However, in every other conceivable characteristic, the N connector is superior, especially for UHF. -
So yes this will work just fine with 2 radios. When you add a 3rd+ it won’t work and you would need to go to the same tx and rx tone. As for others hearing you. If they don’t have tones set yes they can here everything your saying. Tones keep other people out of your conversation they do not make it so others can’t hear you. No tones here’s everything.
WRUU653 reacted to an answer to a question: Swr change.
MasonSandeWSIF334 joined the community
I’d still prefer a good ol’ pl259 connector myself. And just replace it at 3 year intervals. The 259’s hold up for years and years on some of the toughest heavy equipment in horrid conditions and transmit cb just fine. -
I haven’t successfully been able to change any privacy tones in channel mode on a uv5g pro. Hella frustrating. My uv5g’s won’t save anything I set into them from the keypad menu. I have heard deleting the channel, going to vfo, typing in the freq and entering the tones, then saving this vfo info into the save channel slot it can be done via radio keypad. . . Just heads up if maybe you’re trying to do it through the actual channel menu on the radio not in software.
SteveShannon replied to aaschrage8793's question in Technical Discussion
Yes, using cross tones/codes will work that way. I don’t know of any benefits to doing that, but yes. Anybody nearby, listening on 462.550 with no tones or codes, can hear anything that is transmitted by either radio. -
I don't understand what you are trying to accomplish with cross codes. No transmission is private unless it is encrypted. As you stated, anyone. not having a receiver code will receive and understand what is being sent. The only way to have a true, private conversation is either with two tin cans connected with string or on cell phones. NOTHING is private in shared spectrum.
aaschrage8793 started following CTCSS/DCS baofeng Uv-5g Pro
So this is my Question RADIO 1 (462.5500) Tx: DCS code Rx CTCSS tone RADIO 2 (462.5500) Tx: CTCSS tone Rx: DCS code Theoretically, if they both use the same CTCSS/DCS tones/codes in that recieve/transmit pattern... it would work correct? It seemed to be working on mine unless the radios just bypassed my selection and was transmitting with no tones/or codes because the software won't allow me to do this? We tried at 3.5 miles out and still could Tx/Rx each other also. I would think this combination works fine. Also, when using tones/codes unless someone is using a scanner (wide open) or is receiving a strong signal from us and their radio is on 462.5500 without those Tx codes programmed into their Rx they wouldn't hear it correct? And or maybe they would hear it with a strong enough signal and a mixture of squelch being set low enough or a weak signal and squelch at 0?
aaschrage8793 joined the community
My wife tolerates my radios and ham activity because her favorite uncle was a ham. Computer stuff and tools, any tools, on the other hand, are her favorite things in the world including stuff we aren't allowed to talk about here. I spend money on that stuff and she is happy.
KG-1000G Plus 50W or BTECH UV-50X3 Tri Band 50W?
AdmiralCochrane replied to WRPL862's topic in Equipment Reviews
That's one of my everyday radios. -
some 30 odd years ago i mounted a NMO UHF antenna in the center of a MasterCool Swamp Cooler sitting on top of a 3 story building... Worked good and the antenna is still mounted where i left it when i left that job.
We don't have roof rights to anything else. We had to pay a one-time charge for the run of the cables across the roof and the roof penetration, plus annual inspection and any necessary maintenance. It is also the highest elevation on the roof (unless we were to construct a tower, which a) isn't needed and b) would be prohibitively expensive). If this was for a GMRS project, then getting additional elevation would have been worthwhile. But for GPS we have a good view of the sky and the cellular extender antenna has line of sight to antennas of several carriers. The L-channel was already there and provided a convenient mounting point for the antenna brackets. The cellular antenna is actually between the two units, while the GPS antenna is attached to the piping side of the mini-split but is comes with an ultra-flex N pigtail which we then connect to the LMR600 and put thick heat shrink with adhesive on the inside over the connection (as we did with the connection on the bottom of the cellular antenna). The unit to the right is top-exhaust and apparently defunct, and our mini-split has the antennas mounted on the inlet side, not the exhaust side, of the coils so they're not getting baked.
WRYZ926 replied to tcp2525's question in Technical Discussion
Oh I can feel my blood sugar levels spike just looking at that photo. Why tease a diabetic like that. Outside of just stocking one type of connector and keeping the prices and inventory down, there is absolutely no reason to use PL-259/SO-239 connectors for any VHF/UHF radio when N Type connectors are better. While N Type connectors are definitely more weather resistant, I still wrap them just like I wrap PL-259 connectors out of habit. -
It's always a trade off when determining what type of coax to use. For the average person setting up a base station where the coax run is 50 feet or less then LMR 400 and equivalent is fine. Just like every type of antenna is a compromise. Go with what works best for your situation and that also fits your budget. Not everyone can afford LMR 600 or 1/2" Heliax cable.
WSHF752 joined the community
Nice job, but I'm not sure why you would mount the stuff to a mini-split. Not good in my opinion.
tcp2525 replied to tcp2525's question in Technical Discussion
If you can get me a baker's dozen of these magnificent French Crullers you got a deal!!! There's absolutely no legitimate use for the SO-239 and PL-259. -
It's a trade-off between cost, ease of installation, performance during operation, and a bit of everyone's different opinions thrown in. At work, I ran two 200-foot runs of Times Microwave LMR600 between the roof and our basement office. One was for a cellular repeater antenna (this pre-dated the pre-registration requirement, by the way) and the other was for a GPS antenna. I had to put a 10dB attenuator between the indoor lightning arrestor and the Wilson cellular amplifier or I'd overload its front end. The General Dynamics box the GPS antenna went into was perfectly happy with the GPS signal level. All the connectors were ordered from Pasternack, as were the LMR600 stripper and crimper. I have a leftover piece of LMR600 with an N connector on the end that I use as a walking stick. OTOH, my entire (large) collection of home-use connector adapters cost less than two of the Pasternack LMR600 connectors. It's a trade-off between price, performance, and personal opinion. My repeater is currently using some no-name super-flex 400 (they can't call it LMR because that's a trademark of Times Microwave) to its temporary antenna. If the Commscope / Andrew fiasco ever starts producing antennas again, my DB420-B will be connected to the entry point lightning arrestor using 7/8" heliax with N connectors. My grounding consists of eight 8' long copper-clad steel grounding rods, 16' apart, with one end tied to the electrical service ground. The whole run from service ground to the antenna lightning arrestor is one continuous piece of #4 stranded copper with green insulation jacket except where the jacket was shaved to connect to the grounding post clamps, electrical ground, and lightning arrestor ground terminal. Forgive the non-GMRS pictures, but they do show good (to me, at least) cable installation practices... You can't see the outdoor lightning arrestors as they're at the point where the cables are about to go through the roof penetration.
TerriKennedy replied to tcp2525's question in Technical Discussion
I'll vote for that, except for handhelds. My nomination for "worst connector ever" is the large NMO. There's insufficient thread engagement on both the inside and outside threads of the large ring, the flats for tightening the large ring are on the wrong side, I have no idea what they thought putting the waterproofing O-ring where it is would accomplish, its impossible to tell if everything has a good connection until you key up and check the SWR, etc. And I had to wait weeks for an NMO to N adapter because I refused to stack a NMO-to-SO-239-to-PL-259-to-N adapter string. I'm actually thinking of changing the VHF/UHF connectors on my DG-503 power / SWR meter from SO-239 to N just to get rid of the adapters. The HF side can stay as SO-239. I'm not sure I'm going to like what I see when I open the case, though. My SW-102 already has N connectors. -
You will get a baker's dozen if you can get all the radio manufacturers to start using N Type connectors on all HVF/UHF/GMRS radios. -
Definitely, only if they are chocolate chip. Do I get two cookies if I get Amphenol to stop making PL-259s? -
Socalgmrs replied to tcp2525's question in Technical Discussion
Ok? Do you want a cookie?
