wayoverthere reacted to a post in a topic: Connected to a Repeater over 75 miles Away! How?
wayoverthere reacted to a post in a topic: How do you add a repeater to the database?
Destro reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
Destro reacted to an answer to a question: Connecting radio to headset for listen only
Yup, this ^.
Northcutt114 reacted to a post in a topic: Some DMR questions.
I don't know whereabouts you are in Arizona, but the majority of major metropolitan police forces are encrypting their radio traffic. I'd check before I spent any money on a radio to scan.
Arlie joined the community
I had the same issue. AFAIK the feature just does not function. Hopefully this and the squelch tail will be addressed in a firmware update.
You only add repeaters you own! Use Favorites for marking existing ones you're interested in. (This is a common newbie mistake, so putting it here for others that may see it.)
WSHV293 joined the community
WSHH887 started following Connected to a Repeater over 75 miles Away! How? and Shack Grounding/Bonding
On grounding in general. When water pipes were either galvanized or copper, it wasn't uncommon to ground your houses electrical system to that. In a lot of cases here the meter is located in the parkway an the pipes ran underground for a fair distance. So grounding wasn't an issue. But, the use of plastic/non conductive materials has resulted in some older homes being repiped and loosing their earth ground. Regardless of what material you use for grounding it's simply wiser to use copper grounds rods driven to the depth required by local codes. Another thought, it's probably better to ground your radio equipment separately from your 120 VAC system.
WSHH887 replied to 3cRadio's topic in General Discussion
I have to concur that line of sight makes a huge difference. I live on a peninsula that sticks out far enough into the pacific ocean that I can pick up a repeater in Chula Vista, Ca. That's pretty close to 200 miles. It isn't always happening, but some times. It actually took me a bit of detective work to figure out where it was. I was flat amazed. But, I sit on top of a hill and there are no obstructions between me and the repeater. I have that repeater programmed just the novelty of it. -
WSIF744 joined the community
I think the title says it all.
I just thought I would stop by and post a quick hello since I am new to this. I got my radio all installed and got my license from the FCC. Now it time to play and have fun here in the wet western Washington (Puyallup).
jfelter joined the community
And we are using encryption on some of the Talk Groups.
WSJT853 joined the community
Where have all the GMRS Repeaters gone?
wayoverthere replied to TNFrank's topic in General Discussion
Pulled up the repeater page for 725SHAWBUTE, and there's a comment there from another user a month or so ago about the repeater being down. Looks like they've had interference issues with a business repeater in the past, and someone causing issues as well, between the comments and the thread below. https://forums.mygmrs.com/topic/7946-soooo-rip-shawbute-i-guess/ Edit: saw him weigh in on the other thread, so maybe @nokones has some more recent info on status of the local repeaters? -
That would be fantastic, Steve. Generous as usual. Thank you. Let me get the software up and running and I'll check back.
Gregg, I would be happy to help put together a codeplug for you/with you. You can listen to DMR on amateur radio.
You're lucky because you can use encryption too. Keeps the scanner kiddies away.
You need a codeplug specifically configured for your DM-32 and the DMR repeaters in your area. Since the DM-32 is relatively new and each radio's codeplug is different (except for OpenGD77, which are interchangeable), you need to contact some Ham or Ham Club in your area that has a DM-32 and has written a codeplug. When I was "younger" I used to look forward to these challenges to help strangers; now not so much, especially for radios that I have little or no respect for.
Got it. Thanks.
Here is a bit of audio from the testing on 8/29/25. BOBGMRSRADIORANGETESTS(EDITED).mp3.e56741ddf04e15cbf25a7008b3a045de.mp3
In the DMR mode the Part 90 Industrial/Business Radio Service
First before investing in any kind of radio for P25 monitoring, particularly for public safety, you want to make sure it's not encrypted. If it is you're hosed. You won't find any way to break the encryption normally used. Second it's not a trunked system. Some radios will NOT scan trunking systems unless they are registered/affiliated. That's can't happen without the system administrator of the system authorizing your radio on it, which likely 99.999% of the time won't happen. There are some ways to do what is called a "non affiliated" scan. It usually means some way to spoof the radio to think it's really on the trunking system. I have a buddy who managed to do that with some XTS2500's on 700/800 MHz to monitor his local PD. He's lucky they don't encrypt. It's usually the first item above that spoils the idea of monitoring.
Sorry, I wasn't clear. You stated you have Motorola DMR radios but don't have a HAM license. So on what service are you using those radios?
With the exception of CB Radio, FRS, Marine and Aviation in the United States, and IMS Spread Spectrum, I believe all services require some type of Station or Operator license.
I have a Baofeng DM-32UV, still in the box. I intend to configure the analog side for GMRS. I'll RX only on the digital side for now, but would like to know what I should be listening to. It's not a matter of how to program it, it's a matter of what to program, i.e. what should a DMR newbie be listening to? Is there a recommended beginner code plug?
