Lscott reacted to a post in a topic: Transmitting Power Limits
Just curious: why is the DM-32 preferable to the $50 DM-1701, which can be flashed to OpenGD77 firmware?
SeaScholar changed their profile photo
WSJF722 started following rdunajewski
Hello…a newbie here…former Marine Band VHF Channel 16 Commercial Fishing Vessel owner…first responder, scanner tracker for wildfires in SF Bay Area…Early warning, evac orders during 2015 Valley Fire, Tubbs Fire, Kincaid Fire and so on through 2018…pre Watch Duty app…with early HAM reporting and, scanner monitoring, twitter fire group reporting on VLATs from McClellan….etc With wildfires increasing in danger, I work with wildfire mitigation advisors, I am GMRS licensed now…will be taking HAM licensing test soon, assessing equipment buys, will be joining the local GMRS wildfire and emergency network that is already established since the wildfires almost a decade ago. Doing radio as data towers tend to shut down with loss of power…I have solar battery back up. i appreciate the help and info I have already received from others here and from recommended radio stores
SeaScholar joined the community
BoxCar replied to SvenMarbles's topic in General Discussion
Mine was all numbers - 793-8-------- -
SteveShannon reacted to a post in a topic: Transmitting Power Limits
I assumed that kind of setup (microwave or otherwise) was on a dedicated portion of the spectrum, outside GMRS, but I guess that does not have to be the case. Have I ever mentioned that this is a great forum?
WSJI804 joined the community
The MOU between the FCC and ARRL only support monitoring of amateur radio operators. https://www.arrl.org/files/file/Volunteer Monitor/2019 ARRL MOU - final 3-12.pdf
SCADA, telemetry, dedicated (but not private) communications. And yes, because the 467 main channels are allowed for Fixed Stations, duplex is easily accomplished. One example would be to use radios for a dedicated communication system between a house and a barn. Lift a handset and use it just like a telephone.
WSIY922 started following Antenna Woes
Alright antenna gurus, I need some help. I have a wouxun KG-1000G and im using a midland low profile NMO coax with the UHF connector on the other end that comes apart for easy routing. I have a couple different antennae I’m trying out and I noticed both had identical SWR readings. About 2.5 on 467.650 I got a little frustrated messing with it and took the antenna all the way off and keyed up with the NMO mount bare. It gave me THE SAME SWR reading. About 2.5. What the hell is going on here? I checked and made sure my mount is grounded (about 0.5 ohms) and everything else seems to be in order. Any advice??
Ever see fixed microwave stations? Same thing. One place communicating with another on a consistent basis would be my best guess. In lieu of telephone lines.
amaff reacted to a post in a topic: Transmitting Power Limits
Well this may be another thread to start but I am curious about the FCC Volunteer Monitor (VM) Program being a formal partnership between the Federal Communications Commission (FCC) and the American Radio Relay League (ARRL). hhhmmm HAM enforcers only? I wonder.
Yep, even though not explicitly stated, that would be the only option.
The wording from the FCC doesn't specify radio type, just "any station at a fixed location." So HT or mobile (or base of course) can be set up that way, as in external antenna on pole, chimney/roof, or tree.
And I see it's fixed station to fixed station only -- no HTs, mobiles, base stations or repeaters. Huh. Use case(s)?
Also, Fixed Stations are allowed to transmit on the 467 MHz main channels which are otherwise reserved for transmitting to a repeater.
SteveShannon reacted to a post in a topic: "Illegal" radios
I'm good. These conversations are giving me some info/questions I didn't even know I might need (even though I have no idea what it's about). Continue on. BTW...I already got what I needed here!
Thanks. You just saved me several hours.
Ouch.
WSJF788 joined the community
mdsnk01 joined the community
A fixed station transmits and received from another fixed station. It doesn't talk to mobiles or HTs. Usually they have line of site towers so 15 watts is usually more than enough for good communication.
OffRoaderX reacted to a post in a topic: Meshtastic
WRYZ926 reacted to a post in a topic: Transmitting Power Limits
WRUU653 reacted to a post in a topic: Transmitting Power Limits
WRUB230 joined the community
TrikeRadio reacted to a post in a topic: Call Sign Use w/Family Members
Remember you asked. https://forums.mygmrs.com/topic/4835-fixed-station-what-does-that-mean-to-fcc/
saw your first video on it... looking forward to seeing a bit more as your get to show off the way it works!
TrikeRadio reacted to a post in a topic: Meshtastic
I'll bite. What is a "fixed station" and how does it differ from a base station?
WSJI326 joined the community
Actually, this works out.. Gonna give one to my brother, he was getting ready to order one.
LeoG started following Cheap & Easy Remote (WiFi) Control Repeater Switch
LeoG replied to WRUE951's topic in General Discussion
Well 100% reliable as long as you have internet. -
You got the pair for less than $50 each. Heck, even if you didn't have any use for two, you could sell one to a friend for $70 and you'd both get a good deal.
