tcp2525 reacted to a post in a topic: Using The Correct Tools For The Job Are Always Essential!!
WSHH887 replied to tcp2525's topic in General Discussion
Fortunately my work never involved more than 220. A lot was DC control power and 120 that was relay controlled to the equipment. But an old electrician gave me some advice early on. Have two sets of tools. One for electrical and the other for everything else. Keep them in separate tool bags and never mix them. I always bought the best tools I could afford. Retired now I still keep my electrical tools segregated from my others. Old habits die hard if you follow them, you will too. -
TrikeRadio reacted to a post in a topic: Found a hidden repeater
GrouserPad reacted to a post in a topic: Fixed Station vs Base Station?
I guess the gps would be something I’d be interested in hearing about also. I believe this would be the first we have seen this in a GMRS mobile. Does it rely on the phone app for this or does it operate on its own?
artsal joined the community
Too bad that it doesn't come with a bluetooth mic with the display. Wonder if such a mic will eventually be available.
WRUU653 reacted to a post in a topic: Found a hidden repeater
blastco2 reacted to a post in a topic: BTech GMRS-50PRO 50W Mobile
WRUU653 reacted to a post in a topic: Fixed Station vs Base Station?
SteveShannon reacted to a post in a topic: Using The Correct Tools For The Job Are Always Essential!!
A Fixed Station is one that's been repaired. /s
Ya ya. Just what I need. More toys
LeoG started following Found a hidden repeater
By accident. Apparently there is a 625 repeater that I know about, but he also has a 600 repeater I didn't know about. My repeater operates on 600 with a PL of 100 and apparently his is on 103.5. I can trigger his repeater on occasion when I key up. I noticed when I keyed up the other repeater would activate and it's a much stronger signal than mine. It would block out mine for a second before it released. One day I moved my TX PL and found it was only 1 click up from what I was using. Not sure if my radio PL is wobbly or the selectivity of his repeater is lax. Either way I've decided to change my PL to stop the interference.
You ought to invest in a NANO VNA. Good to have your tool box arsenal.
Interesting that it was demonstrably affected by temperature. At very specific temps. At 26ºF the problem would go away. As the temp approached and exceeded 32ºF the problem would return. Certainly sounds like a water problem to me. Cables were professionally made, doesn't make them infallible of course. All connections were tight and secure. All connections were triple sealed. 2 wraps of self fusing tape and electrical tape on top. It's not like this is my first foray into electronics, electrical or radio. Until I do some RF testing on both the coax and antenna I can't say what exactly happened. All I know is it was broke. I replaced the two components it could possibly be, and now it ain't broke lol.
WRUU653 replied to tcp2525's topic in General Discussion
I would add make sure what you think you’re testing is what you think it is before putting that meter on it also. I got called out for a blown fuse on 4160 three phase. Each leg supplied a group of transformers and the electricians (not our company) thought the high side was 480… they opened up the back, one guy put the probes on while the other held the 600 volt rated meter. They both lived but they both went to the burn ward. Be safe and pass on stories where things can go wrong so the newbies may learn and hopefully avoid bad mistakes. -
Socalgmrs replied to tcp2525's topic in General Discussion
For 12v dc the best investment a mechanic or hobbyist can make is a power probe. Testing grounds, relays, giving power or ground to something. -
WRYZ926 replied to tcp2525's topic in General Discussion
It will only hurt for a little bit - until you either trip the breaker or pass out from the pain. I've zapped myself with everything from 12 V DC to 480 V AC three phase. 120 is the worse since it wants to hold onto you. Generally (but not always) 220V and above will throw you off. I got hit with 480V three phase when testing a contact. The relay went bad and it was getting the full 480 across it. I had my left hand on the metal cabinet when it hit me. It instantly threw my hand off the door. One of the worse shocks I got was when working on a 36 V DC golf cart. I got zapped by the full 36 volts from 6 high amp 6 volt batteries. I was testing the big resistor that controls the speed and accidentally got my left forearm across all three terminals on the motor. I had to grab my left arm with my right hand to pull my arm off the motor. I won't go cheap when it comes to tool needed for electrical work. All of my screw drivers and some pliers are all rated for up to 600 volts. And I definitely won't use those pen testers. -
tcp2525 replied to tcp2525's topic in General Discussion
Don't get me started on those pen testers. I always tell the new guys to NEVER rely on them. If you insist on using one you better check using your meter. 277v and 480v is so unforgiving. -
That is the beauty of the 87, it's such a joy to use. I always thought the clamp was such a neat accessory. -
Yeah they can be finicky, I trust them to tell me something is hot, I don’t trust them to tell me it’s not. Klein has certainly made some money off of me over the years too -
I’d put my money on the latter. But at least exercise is supposed to be good for you.
WSHH887 started following Using The Correct Tools For The Job Are Always Essential!!
Still prefer Klein. And I have never trusted those pen type devices to see if a circuit is live. I do have one old Fluke meter. All it measures is 129 or 240 voltage. It must be close to 60 years old now. -
I agree that good tools are a joy to use. Like radios it seems I can never have enough. As for Flukes I have the Fluke 16 and Fluke T5 1000. Before I retired I used to have the 87, the 376 FC with the flexible clamp (that was a nice meter) and a 771 milliamp clamp on (usefull for 4-20 controls). All good meters. -
Yea obviously, but how do you know a neighbor is calling from his house versus his car? (You have to respond to even ask.) All this rationalizing is useless. therefore.... (wait for it).
Ah, the classic 87, it never goes out of style nor will it ever be discontinued. Don't remind me about clamp meters. My dumb ass left my old favorite Fluke ampprobe where I was working and didn't remember I forgot it till the next day. Needless to say somebody got an early Christmas gift. I bought a new one, it gets hooked to my belt. I ain't making that mistake twice. -
WRYZ926 replied to WRPL700's topic in Amateur Radio (Ham)
Some sad hams hate on other amateur license holders especially the old curmudgeons that had to write essay answers on their tests and had to pass the CW code portion too. They feel that since they had to walk up hill in 2 feet of snow both ways to school that everyone else should have to do the same. - Yesterday
bobb99 joined the community
OffRoaderX replied to WRPL700's topic in Amateur Radio (Ham)
I have been assured by "some people" that this is a lie, this never happens, and it is impossible - and if you spread these vicious lies you are a racist or a nazi, or "too dumb to pass the test".. -
WRQI583 replied to WRPL700's topic in Amateur Radio (Ham)
All I had to do is make mention of having a GMRS license on 2 meters. The attitude that came off of the Hams just about dissolved my speaker. Needless to say, I quit talking on ham. I hop on Ham on a rare occasion to check into a net or something but my days of having conversations is probably over. I got this same attitude over making mention of an experience I had on CB radio. Just say the name of another radio service and the most vile hatred oozes out of some Hams. -
I'm still using the Fluke 73 III that I bought 25 years ago. It does most everything I need it to do. I have a new Klein clamp meter for amperage reading when needed -
SteveShannon replied to tcp2525's topic in General Discussion
I have the 117 and really like it. Of course I wanted the 87 but I couldn’t justify the price difference.
