Well, the radio is going back to Amazon. I'm not going to try to fight with it to get it to work with the CPS. I've tried a couple different cables, installed drivers, did everything I could think of including trying other CPS programs but it just won't read. If I can't read it I can't program it. I'm going to go with my first choice, the RT-4D and see if that'll work. If it doesn't then it'll go back too.
Change My Mind - I Don't Need Permission to Use Your Repeater
OffRoaderX replied to marcspaz's topic in General Discussion
The fact that the FCC has not enforced it in the last 15 years says otherwise. -
WRUU653 reacted to a post in a topic: Connected to a Repeater over 75 miles Away! How?
WRUU653 replied to marcspaz's topic in General Discussion
(1) Shall determine specifically which individuals, including family members, are allowed to operate (i.e., exercise operational control over) its GMRS station(s) (see paragraph (c) of this section); 3) May disallow the use of its GMRS repeater by specific persons as may be necessary to carry out its responsibilities under this section. Kind of seems like they are. That’s my take on it for whatever good it may do. -
Ok, so the CPS isn't reading the radio. I tried my chipped cable(which I'm told isn't going to work with a digital radio) and the factory supplied cable. I installed the drivers for the standard USB programming cable but the odd thing is that the CPS doesn't give me the option of a COM Port to pick from. Normally I use COM5 but there's no picking the COM port so I just get an error message and can't connect to the radio. The cable IS pushed in all the way and short of unplugging everything usb from my computer I have no clue as to what to do. Any ideas?
Being a newbie, I apologize. I'm here to learn and my comments were out of place. Hopefully i can continue to visit this forum and learn.
LeoG replied to marcspaz's topic in General Discussion
Well, travel the 3300 miles and bring it on -
yes -
OffRoaderX reacted to an answer to a question: QYT K8900 KT ?
WSDB758 joined the community
LeoG started following Change My Mind - I Don't Need Permission to Use Your Repeater
Maybe I might come and hunt you down because I'm a crazy MFer Is that the chance you want to take? The airwaves are free to listen to. In most cases they are not free to transmit on legally. Using someone else's property without permission isn't right. Like borrowing someone's car without permission. You are using their hardware. If I recall all you have to do is address the problem of someone abusing your repeater and then after that it's not really your issue with the FCC. At best you can shut it down but that's usually reserved for a malfunction, not a crazy person trespassing on your hardware. There is literally nothing you can do to prevent them from using your equipment other than my opening statement. Switching frequencies and/or tones will only delay someone hell bent on using it. - Today
I Don't Need Permission to Use Your Repeater - Change My Mind This isn't an attack on anyone... just meant to stimulate conversation. I am 100% open to hearing dissenting opinions. Lets chat. So, this happened to a friend of mine recently. He used a repeater that the owner did not expressly say he was approved to use. The repeater owner/manager sought him out off the air, told him that he isn't authorized and to not use it again. Here are some facts, that are not open for debate... In some states, a person is not criminally trespassing on realty unless a person has been notified by the realty owner either verbally, with signs, etc., followed by a complaint filed with the courts, a judge agrees with the realty owner and issues a court order for that person to stay off the property, AND THEN that person returns to the property. There is no other private trespass beyond unauthorized access to private real property. Also, the FCC has already published an opinion that they will not modify the rules requiring operators to gain permission to use another licensee's repeater. Literally every license holder has equal right to use every frequency, every tone, every code, etc. If your repeater receives my signal and re-transmits my signal, that is not my problem. As the repeater owner and licensee, by FCC rule, YOU are responsible for what is transmitted by your radio. It is up to you to manage things accordingly, including intentional or unintentional transmitting of another radio's signal. Here is the opinion... if I need a judge to agree with me that someone shouldn't be on my property and issue a court order to keep them out of my house, and the FCC said they aren't requiring permission, why should I ask for permission to use a repeater? Maybe as a courtesy? Why else? I mean, as a repeater owner, part of me thinks it would be nice to be able to have some teeth behind efforts to stop a troublemaker from using my repeater. Another part of me thinks, I sure as heck don't want to try to track and manage potentially hundreds or even thousands of operators on my repeater. I am way too busy for that. Not to mention I am not spending thousands and thousands of dollars to have the systems sit there and not be used. That would be such as waste. If the FCC says I don't need permission and it's up to the owner to use technology to manage access, and state laws have set precedent on what trespass is through State Code and Tort Law (which is limited to real property), then I don't need permission to use your repeater... change my mind!
WRUU653 reacted to an answer to a question: Shack Grounding/Bonding
TerriKennedy reacted to an answer to a question: Shack Grounding/Bonding
If you do that there’s a very good chance that your radio chassis will be at a different potential than your power supply chassis. Code requires the two grounds to be bonded.
SteveShannon reacted to a post in a topic: Some DMR questions.
SteveShannon reacted to a post in a topic: Connected to a Repeater over 75 miles Away! How?
SteveShannon reacted to a post in a topic: Welcome!
WSFN233 replied to 3cRadio's topic in General Discussion
I can open the Blue Mountain repeater from my home in VA thats roughly 62 miles away using a 5 watt Baofeng UV-5RTP with the OEM rubber ducky antenna. This is from inside my home. The height/quality of the repeater seems more important than whatever hardware I'm running. -
AlRock joined the community
Dept. of Public Safety(aka Highway Patrol)still uses FM Narrow band. I have 4 channels locally I can listen to, East, West, South, and Central. EMS and Rural Metro Fire are also NFM. Not everyone has gone P25. I got my radio today so, let the fun begin.
DES256, AES256/128, RC4? Do you need to use a special “key loader” for the keys?
I haven’t noticed much of a change in Kenwood equipment availability. If nothing else I think used radio prices have dropped a bit. There a a lot of analog radios available. About Hytera radios, I’m on the lookout for a PT850 in the 405-475 band split. This is a digital radio for TETRA. https://hytera-europe.com/media/Hytera_PT580P_EN_004T_110117_v3-min.pdf Yeah, it sort of looks like an Anytone D878 with a hard-on. Oh well, many of their other HT’s have the same antenna placement. Designer I’ll bet got a bone-ous for the idea. I’ve seen a few for other band spilts. The radios are usually from the EU or China. TETRA is basically not used in North America. With the tariff on most imports it makes these expensive, or just unobtainable.
WSHX645 joined the community
It is the responsibility of the repeater-owner to keep their repeater info up to date.. That said, many forget or die and their repeater entries never get updated again. When viewing the repeater list(s) you can omit "stale" entries so the old/never been touched ones dont show.
How do you add a repeater to the database?
CentralFloridaGMRS replied to WRTC928's topic in myGMRS.com
Does anyone check to see if the repeaters are actually operating? I've seen some listed yet they have never been online. -
@jfelter welcome to GMRS. Lots of fun and good info here. A little drama once in a while but don't let that run you off. There's a lot of good people here.
Yup, this ^.
I don't know whereabouts you are in Arizona, but the majority of major metropolitan police forces are encrypting their radio traffic. I'd check before I spent any money on a radio to scan.
Arlie joined the community
I had the same issue. AFAIK the feature just does not function. Hopefully this and the squelch tail will be addressed in a firmware update.
You only add repeaters you own! Use Favorites for marking existing ones you're interested in. (This is a common newbie mistake, so putting it here for others that may see it.)
WSHV293 joined the community
WSHH887 started following Connected to a Repeater over 75 miles Away! How? and Shack Grounding/Bonding
On grounding in general. When water pipes were either galvanized or copper, it wasn't uncommon to ground your houses electrical system to that. In a lot of cases here the meter is located in the parkway an the pipes ran underground for a fair distance. So grounding wasn't an issue. But, the use of plastic/non conductive materials has resulted in some older homes being repiped and loosing their earth ground. Regardless of what material you use for grounding it's simply wiser to use copper grounds rods driven to the depth required by local codes. Another thought, it's probably better to ground your radio equipment separately from your 120 VAC system.
WSHH887 replied to 3cRadio's topic in General Discussion
I have to concur that line of sight makes a huge difference. I live on a peninsula that sticks out far enough into the pacific ocean that I can pick up a repeater in Chula Vista, Ca. That's pretty close to 200 miles. It isn't always happening, but some times. It actually took me a bit of detective work to figure out where it was. I was flat amazed. But, I sit on top of a hill and there are no obstructions between me and the repeater. I have that repeater programmed just the novelty of it.
