While this is for repeaters the same consideration applies to radios in close proximity. Crappy coax with high RF leakage can cause issues too. https://www.repeater-builder.com/antenna/double-shielded-coax.html
Like I said in an early post, the fact that both 7300s are in a mini rack along with the Morgan High Performance band pass filters works well for us inside our trailer. I do need to double check to make sure that the common mode chokes get put in place on both HF antennas before everyone starts transmitting for field day tomorrow.
WRYZ926 reacted to a post in a topic: Passed my technician exam
That's likely helping more than you think. You can test that by taking the radios and just air spacing them.
Having the radios sitting on solid shelves helps, at least in our case. The mini rack shelves are solid without any holes in them.
WSIW237 joined the community
hxpx reacted to a post in a topic: Just passed my General class test on Saturday!!!!
SteveShannon reacted to a post in a topic: Just passed my General class test on Saturday!!!!
Congrats on passing the General This weekend is the Field Day contest - very easy exchanges (check ARRL rules) If you can get on HF I think you can have some fun working several stations all over the country. -
That's true of most electronics you buy today. Mostly gone were the old days where the radio/TV etc came in a metal box. Now all you get is a cheap plastic one and people wonder why they get garbage pickup from their LED lights and other crap. There is a section on an Anytone D878 site where there are instructions on how to spray a nickle coating inside the case to improve the shielding. You might try this with the IC-7300. AT-D868_D878_Info_and_mods_20240607.pdf
Feature: See all repeaters that hit a certain location
WSAQ296 replied to WRXR374's topic in myGMRS.com
Late to the thread, but bored and going to post anyway. Unless we're all using the same equipment, any circles like this will only cause frustration. I'd be more interested in color coding based on verified last useage. ie: You could drop in and click on it if you recently used it. Then those clicks would age, green to red. It sure would be helpful to see this, and eliminate the guess as to whether the issue with the repeater is your setup, or a now dead repeater. It's not as big an issue here as it is on repeaterbook, but I still see them here and there. (Usually repeaters imported that are older than the site itself) -
Baofeng gm15pro shows long antenna included, but not shipped?
SteveShannon replied to a topic in Guest Forum
Terri’s post nailed it. The only thing I would add is that when asking a question like this it’s helpful to include a link to the precise item ordered. There are often several listings for each model, with listings by different vendors. Yes, you ordered “from Amazon” but it’s more important knowing who the actual vendor was. That also greatly affects the return policy. Personally I try to limit my purchases to Prime, but that’s not always possible. -
thanks for all the input guys, that RF line of sight chart really helped. there is one little spike betweengst me and my target area, i wish there was a way to just attach a jpeg image so you guys could see and tell me if you really think that would impede my signals. i played around with the RF chart to get an idea of where, if i were to need to add a repeater to get the job done, the best location(s) would be. i have 3 possible locations for that. one possibility is a 250ft tower that i (as of now) have permission to access. the chart says i would only need to go up 50ft to have clear line of sight to both locations. so my next question is and i know the higher up you go the better coverage you get but realistically just how far would i extend the coverage area? 20miles, 30miles?? would i need a 50w repeater or would a 25w repeater suffice? also, on a side note, the aforementioned tower is owned by a telecom company which happens to have 3 separate tower locations. i have already spoken to the CEO of the company and told him my plans and he himself was actually interested is possibly doing something himself for the company as a possible backup form of communications during extreme weather events and what have you. so, if that works out i may not have to worry about purchasing that equipment. he also seemed to be ok with having all 3 locations open repeater sites.
SteveShannon reacted to a post in a topic: Baofeng gm15pro shows long antenna included, but not shipped?
this i can try, didn't think about it before but i have a couple of Baofeng UV-5G Plus with the 15" antennas i can try. both locations are roughly 2 story structures so i would already be about 20ft or so AGL, won't hurt to try i reckon. i really don't want to get into ham if i can help it.
Still normal for me on FF and Chrome
WSIU493 joined the community
WSIU786 joined the community
TerriKennedy reacted to a post in a topic: What's a radio good for anyway?
TerriKennedy replied to a topic in Guest Forum
Those are likely Amazon Marketplace listings (look for "Sold by" on the product listing). There are good marketplace sellers and not-so-good ones. I don't know which exact listing you were looking at, so I can't check. A 15" antenna is not going to fit in the standard Baofeng box without folding it, which will damage most antennas except for the "tacticool" tape-measure ones. So the seller would need to provide Amazon with either an oversized box with the radio box inside, along with the antenna, or securely tape the antenna to the Baofeng box and put a "Sold as a set - do not split" label over it. Both are going to drive up the seller's costs (for increased per-unit warehouse space at Amazon in the first case, or for a non-robotic handling surcharge for the second case). You may need to do an "item not as described" return through Amazon. They will likely ask you to work with the seller to resolve the issue, and the seller may try to drag things out, so start the process ASAP so you don't time-out on the Amazon 30-day return window. -
Clear your Browser cache and reload the site.
NCJeb reacted to a post in a topic: Immediate family use of gmrs callsign
We are using the Morgan High Performance band pass filters with great success. And the two IC-7300s are sitting one on top of the other in a mini rack in our e-com trailer. I'm not trying to argue or say you are right or wrong. I'm only stating my club's experiences.
Pressman joined the community
WRZJ440 joined the community
WSFZ605 joined the community
WSIU940 joined the community
KevinBakos1 joined the community
Screw for mounting the belt clip
WRXB215 replied to RogerSpendlove's question in Technical Discussion
@RogerSpendlove I found replacement clips for the GM-15 Pro but they didn't come with screws. Went back and forth with the seller about the screws. It sounded like they didn't understand me. Of course that could have been intentional. -
SteveShannon replied to RogerSpendlove's question in Technical Discussion
No idea, but if the screw threads don’t match you’re screwed. Pun intended. -
It seems to work for everyone else. The only thing I saw was the password reset requirement. The website always resolved correctly within one refresh for me.
RogerSpendlove replied to RogerSpendlove's question in Technical Discussion
I found replacement belt clips on Amazon saying they're compatible with the Baofeng UV-5R series. Can anyone confirm whether the screw hole placement on the UV-5R is the same as on the GM-15 PRO ? My GM-15 PRO unit measures 1 inch on center. They sure look the same, but I'm just trying to be sure before I commit to spending $. Thanks! -
Here are a few sweeps of one of my band-pass filters. I'm confident the filter works fine with about -60dB of attenuation on the other bands. The assumption is that key parts of the radio are not shielded well enough. 10m 20m 40m 80m
WSHH887 started following radioddity will not read from radio
Check your com settings. Mine defaulted to com 1 but needed com 5. There's a target on or near the top left that say "set" or "settings". It let's you change the com port.
Clear your history.
Welcome to this Forum and I see this appears to be your first post since joining in January... It never hurts to provide us with too much information, such as Model Name, computer OS, etc.
WSIL468 joined the community
ive done all the drivers,cable works with other radios, software has been loaded and reloaded..it will start then stop. Does anyone know the baud rate? Ive done resets on radio, ive checked the firmware version it matches, i run it in admin mode.....IVE RUN OUT OF IDEAS.......CAN ANYONE OUT THERE HELP?????
WSHL759 joined the community
They don't help with the IC-7300. If there was a radio within a half mile pushing more than 1w and they were on a frequency below me, I couldn't hear anything but that radio. I made two for 20m and ended up buying a third that was a high dollar commercially made and none of them worked. I ever skipped a patch cable and used a double male barrel connector direct to the radio and the filter did nothing. They all looked great on the analyzer, but the radio just lacks the proper shielding in the IF circuits or some other critical part of the system. Never did figure it out. Just started using mt FT-891 for contesting with the group, since it has a native amp keyer.
Band pass filters are a must when operating multiple HF radios in close proximity to each other. We use them in our trailer for field day with good results. A few of us even use them on POTA if there are 2 or more people close to each other.
