TrikeRadio reacted to a post in a topic: For those that don’t think the FCC will enforce anything.
Oh... dang typo. yes THREAD is what I meant
I'm a little late to this thread and it appears that you have already received an answer to your question but thought I might chime in anyway. I have a BTech 20v2 and use it to receive many VHF/UHF frequencies outside of the GMRS frequency range. It works great. IMHO, the receiver selectivity is not the best, but it is a good little radio for the price. I really love the form factor and that all the controls are on the mic and that I can stash the radio in an out of the way location. I wish I could find a small unlocked dual band ham radio (like the Btech UV-25X2) with a small display and all the controls on the mic! That too would be handy! Anyway, YES, you can receive ham and various public safety traffic via the radio and use the scan feature to scan thru all of it. I do it all the time. That Btech 20V2 is a compact little unit and will give you the capability you are seeking.
WSIK420 joined the community
heavyhitter37 joined the community
I keep a log of all my contacts on 6m and HF bands. I don't bother keeping a log for 2m or 70cm. And the only time I keep a long for GMRS is for our monthly net that gets turned in.
Lot of radio in one package. Your right up makes it tempting .. Thanks
His stupidity and the stupid shit he says far outweighs the tiny nuggets of correctness that he randomly shits out.. and he has never said anything that 100 others here in the forum could not also tell you. ...just sayin...
MURS is limited (by FCC regulation) to 2w, and this radio's lowest power setting in the band that encompasses MURS frequencies is 5w. Therefore you cannot set this radio to a power level that is appropriate for MURS. It will work but it will be putting out too much power. The reason for the 2w limitation imposed by the FCC for the MURS band is that there are non-MURS frequency allocations for other services interlaced between the MURS frequencies, and higher power is more likely to interfere with those other services. As for GMRS, using CHIRP you can set up channels in the radio that are configured exactly as a regular mobile GMRS radio would be set up. Once it's set up properly, you would just turn the knob to the correct channel (or input the channel on your mic), and it will work as you would want a GMRS radio to work. As I mentioned earlier, this would not be in compliance with FCC type acceptance. But it could be configured to meet the technical specifications of GMRS. Remember that no mobile GMRS radio should transmit on channels 8-14, the FCC doesn't permit those channels for mobile transmission. Here, the reason is because 8-14 use frequencies directly between each of the repeater input frequencies. Transmitting on these interstitial frequencies at 5w or at wideband has a higher than acceptable possibility of interfering with repeaters. These channels are supposed to be a half watt only, narrowband only, and fixed antenna. But for channels 1-7 and 15-22 plus repeater inputs you can configure this radio to meet the technical limits of GMRS. Bear in mind that a type approved GMRS radio like the KG1000G+ will already be configured correctly, so you can't mess it up. And it will be type approved for GMRS.
WRUE951 reacted to a post in a topic: What did I do wrong?
FishinGary reacted to a post in a topic: Wouxun KG-UV980P impressions
FishinGary reacted to a post in a topic: Log books?
WRTC928 reacted to a post in a topic: Immediate family use of gmrs callsign
WRTC928 replied to warthog74's topic in FCC Rules Discussion
I've never believed the FCC never takes action, but I think it's pretty clear you have to pretty much be "asking for it" to catch a significant enforcement action. When I see someone fined or jailed for nothing except using an unapproved radio on GMRS, then I'll start worrying. I'm pretty much a stickler for the rules regarding power and bandwidth, because ignoring them can create problems for other users, and I try to be a decent human, but I'm not going to get my undies in a wad over someone using a ham radio on GMRS frequencies. I'm 99.999% certain nobody will know what radio I'm using unless I tell them, and I'm 99.99999% certain the FCC has better things to do than try to figure it out. Don't interfere with other users, especially business and government agencies, and you'll be fine. -
You mention that you would not recommend this radio for MURS. Why is that? Also, with respect to GMRS, you said “through some simple configuration adjustments of the band ranges in CHIRP, yes, this will work for you.” I presume you mean the regular manual frequency entries…. Anything else? THANKS
If he was genuinely a moron, I'd ignore him, but he does actually know some stuff that I occasionally find useful. I just don't know why he's gotta be such a douche about it.
WRTC928 reacted to a post in a topic: What did I do wrong?
No, unfortunately, when people quote his posts they still appear, unless you ignore the people who quote him.
I’m thinking of buying this radio. The specs on the Wouxon site for vhf is up to 174MHZ and 479 on UHF. You say it’s easily unlocked. Is that just a matter of inserting the frequencies into Chirp? Or, is it required to make frequency adjustments in its proprietary software? I use some MURS frequencies (151+) and GMRS.
WSFU381 joined the community
marcspaz reacted to a post in a topic: What did I do wrong?
WSIM568 joined the community
WSHH887 started following What did I do wrong?
So I blocked the pessimist quite a while ago. But his nonsense still shows up in quotes. Anyway to hide those? Live is too short, and at my age getting shorter daily, to put up with his nonsense.
I think you mean that you would like to be able to ignore specific “threads”. If you truly meant “threat” I would urge you to report any threats by clicking on the ellipsis in the upper right corner of the post that includes the threat. I would also like the ability to ignore threads.
WRUE951 replied to warthog74's topic in FCC Rules Discussion
i wonder if this guy is the onion caper ??? https://www.huffpost.com/entry/jayme-john-leon-mcfury-onion_n_1914789 -
Socalgmrs replied to warthog74's topic in FCC Rules Discussion
To have an fcc fine force collected it would have to go before a judge and possibly a jury for trial. It would have to be proven beyond doubt that the fine was owned. Try convincing 12 jurors that you are the person that violated the fcc rule. See this is all civil not criminal. One could even argue that the rule is not constitutional. It’s cb not ham or gmrs so no rules have to be read before you buy a licence. IF they found with the fcc that you owned the money Then another judge would have to issue a judgement and issue a lien. Then the collecting party could ask for funds to be taken from pay checks or bank accounts. It’s a huge drawn out process that could take years. It’s not like the irs or credit card company collections that you already agreed to pay, that takes long enough. -
Its not actually blocking but rather 'ignoring' The idiot would still be there in the wild but his crazy post would be ignored on your feed.. You woiuld still have the chance to call him out.
I don't want to block any users... but I sure wish the site let you mark a THREAD as something you don't want to see come up in your "Unread topics" anymore regardless of how many new posts get added to it!
TrikeRadio replied to warthog74's topic in FCC Rules Discussion
I suppose that is so that the FCC does not have the idea that they are adding to their own budget if they hand out fines... kinda of a conflict of interest? But still, if the FCC is sending the letter and announcing the fine, either they are turning that over to some other department to enforce/collect it - and THAT department is failing to follow through, or the FCC is just sending the nasty-gram letter and never actually turning it over to whomever is supposed to enfoice/collect it. -
Hmm.. I was thinking maybe my question would open up a discussion beyond the "it makes the sad hams feel justified" automatic response. Why is it that when the FCC actually BOTHERS to send a letter and a fine, it seems the FINE is never actually collected or enforced in any way. If it is NOT in the hands of the FCC to process and enforce that fine, but some other enforcement or Legal department of the government... Does it just never get turned over to collections by the FCC... or Does it get turned over to collections and then collections never pursues it? -
You can still see what that guys posts? Man, you gotta jump on the "block that moron" train!
I've never logged an amateur radio or GMRS contact, but I can see why some people would want to. It could be fun to look back and see how far you had reached or remember some interesting person you had talked to. I have made a "log" of sorts of people who are active on the repeaters I use. I write down their call sign, name, and a couple of tidbits about them ("WK5DKD Bob likes to go to Boom-a-rang restaurant for fish Friday." "K3OSU John travels out of town a lot for work.") It makes it more interesting to converse with them on the air. There isn't enough consistent activity on the GMRS repeaters I can reach to make it worth doing that, but that could change.
Steve733 joined the community
Every jerk and a--hole I know defends him/herself by saying, "I'm just honest." So, here's some honesty for you -- If you find yourself saying that...you're an a--hole.
chucklesk joined the community
jlink221 joined the community
That's not true. I don't hate anyone. Although, I definitely do not have any love for Pandaland radios and radio products or other related inferior products.
