WSIU493 joined the community
WSIU786 joined the community
TerriKennedy reacted to a post in a topic: What's a radio good for anyway?
Baofeng gm15pro shows long antenna included, but not shipped?
TerriKennedy replied to a topic in Guest Forum
Those are likely Amazon Marketplace listings (look for "Sold by" on the product listing). There are good marketplace sellers and not-so-good ones. I don't know which exact listing you were looking at, so I can't check. A 15" antenna is not going to fit in the standard Baofeng box without folding it, which will damage most antennas except for the "tacticool" tape-measure ones. So the seller would need to provide Amazon with either an oversized box with the radio box inside, along with the antenna, or securely tape the antenna to the Baofeng box and put a "Sold as a set - do not split" label over it. Both are going to drive up the seller's costs (for increased per-unit warehouse space at Amazon in the first case, or for a non-robotic handling surcharge for the second case). You may need to do an "item not as described" return through Amazon. They will likely ask you to work with the seller to resolve the issue, and the seller may try to drag things out, so start the process ASAP so you don't time-out on the Amazon 30-day return window. -
Clear your Browser cache and reload the site.
NCJeb reacted to a post in a topic: Immediate family use of gmrs callsign
We are using the Morgan High Performance band pass filters with great success. And the two IC-7300s are sitting one on top of the other in a mini rack in our e-com trailer. I'm not trying to argue or say you are right or wrong. I'm only stating my club's experiences.
NCJeb reacted to a post in a topic: Interesting comments being filed with the fcc on unused 46Mhz/49Mhz pairs
Pressman joined the community
WRZJ440 joined the community
WSFZ605 joined the community
WSIU940 joined the community
KevinBakos1 joined the community
Screw for mounting the belt clip
WRXB215 replied to RogerSpendlove's question in Technical Discussion
@RogerSpendlove I found replacement clips for the GM-15 Pro but they didn't come with screws. Went back and forth with the seller about the screws. It sounded like they didn't understand me. Of course that could have been intentional. -
SteveShannon replied to RogerSpendlove's question in Technical Discussion
No idea, but if the screw threads don’t match you’re screwed. Pun intended. -
It seems to work for everyone else. The only thing I saw was the password reset requirement. The website always resolved correctly within one refresh for me.
RogerSpendlove replied to RogerSpendlove's question in Technical Discussion
I found replacement belt clips on Amazon saying they're compatible with the Baofeng UV-5R series. Can anyone confirm whether the screw hole placement on the UV-5R is the same as on the GM-15 PRO ? My GM-15 PRO unit measures 1 inch on center. They sure look the same, but I'm just trying to be sure before I commit to spending $. Thanks! -
Here are a few sweeps of one of my band-pass filters. I'm confident the filter works fine with about -60dB of attenuation on the other bands. The assumption is that key parts of the radio are not shielded well enough. 10m 20m 40m 80m
WSHH887 started following radioddity will not read from radio
Check your com settings. Mine defaulted to com 1 but needed com 5. There's a target on or near the top left that say "set" or "settings". It let's you change the com port.
Clear your history.
Welcome to this Forum and I see this appears to be your first post since joining in January... It never hurts to provide us with too much information, such as Model Name, computer OS, etc.
WSIL468 joined the community
ive done all the drivers,cable works with other radios, software has been loaded and reloaded..it will start then stop. Does anyone know the baud rate? Ive done resets on radio, ive checked the firmware version it matches, i run it in admin mode.....IVE RUN OUT OF IDEAS.......CAN ANYONE OUT THERE HELP?????
WSHL759 joined the community
WSIS686 joined the community
They don't help with the IC-7300. If there was a radio within a half mile pushing more than 1w and they were on a frequency below me, I couldn't hear anything but that radio. I made two for 20m and ended up buying a third that was a high dollar commercially made and none of them worked. I ever skipped a patch cable and used a double male barrel connector direct to the radio and the filter did nothing. They all looked great on the analyzer, but the radio just lacks the proper shielding in the IF circuits or some other critical part of the system. Never did figure it out. Just started using mt FT-891 for contesting with the group, since it has a native amp keyer.
Band pass filters are a must when operating multiple HF radios in close proximity to each other. We use them in our trailer for field day with good results. A few of us even use them on POTA if there are 2 or more people close to each other.
WRUE951 replied to RogerSpendlove's question in Technical Discussion
Most Ace Hardwares & True Values carrie an assortment of unusually small screws. -
im on a 1 Gig fiber service with RACE and a Starlink back up. My 1 GIG is free, part of my retirement agreement with another company. I've noticed this a couple times today. Tried clearing the cache etc. I think its some HTML issues with whoever he uses to host the site..
Absolutely - Here in St Paul, we hear sirens, we rush outside to look for them!. But the guys I know are researchers not tour guides, so they like to keep other ears from getting their info and clogging up their spots!
My two favorite HF radios for newer operators and for people who aren't DX contest junkies are the Yaesu FT-991A and the iCom IC-7300. The Yaesu includes 160m through 70cm (all bands, all modes) and the IC-7300 covers 160m to 6m (all bands, all modes). My personal opinion, the IC-7300 has much better receive sensitivity, but it is more prone to interference because of it. It is almost impossible to use in a group for things like contests or Field Day, but its great if you typically use it at home or with no other operators around. The FT-991A is truly a "Shack in a Box". Good at everything, not great at anything. If you have any interest in 2m or 70cm SSB, its a good choice and one of the few "new" radios that support it. Otherwise you are paying original retail or more for used radios that have been discontinued a decade or more. For example, I have an IC-7000 that was discontinued in 2014. Last known retail price when on sale was $900 from HRO. They are for sale today for between $900 and $1,100 depending on if they have the head separation kit or not.
Alright, I passed my general, so now I can talk to anonymous men across the country instead of just anonymous men in my area. Since I don't have an HF rig yet, I hopped on someone's public KiwiSDR and started poking through the 40m/80m bands and heard... old dudes talking about soup. I can't get away from it. Apparently radios are meant for soup chat.
That's the way I do it these days.
BoxCar replied to RogerSpendlove's question in Technical Discussion
Try Ace Hardware for the screw. Lowe's has them as well, but in blister packs.4 -
OffRoaderX replied to RogerSpendlove's question in Technical Discussion
Might be faster, cheaper and easier to just buy a new radio. -
I have a pair of B-Tech GM-15 handhelds, and one of the screws fastening the belt-clip has been lost. Can anyone tell me what size and thread-count is that tiny little screw, and where I could purchase one? It's far smaller than the smallest thing I can find at Lowes Home Improvement! Or better yet, does anyone sell compatible replacement belt clips--with a stronger spring that doesn't allow the radio to come loose at the slightest jostling? Thanks for any help!
Thank you Rich for sending me the link, I'm on and Ill try to be an active member. 73 Greg
Well I'm not putting a 1/4 wave antenna up on an 80' tower. That would look silly. LOL
