New to GMRS and looking for a better antenna..
SteveShannon replied to WSIZ258's topic in General Discussion
Having R-DCS set will block everything that isn’t transmitted with the same DCS code. Leaving R-DCS cleared out allows you to hear everything that is transmitted on that frequency. If you set T-DCS nobody will hear you except those who have a matching R-DCS or those who have no R-DCS. My recommendation for someone who isn’t hearing an expected response on a repeater is to leave the receive tone off but you must have the correct tone or code (remember there’s both CTCSS, which is a tone, and DTCSS, which is a digital code) when transmitting. You might also try getting closer to the repeater. Finally, not everyone using GMRS wants to respond to an unknown person on a repeater. Have your daughter take the other radio and walk a ways away and see if you can hear each other on the repeater. -
WSIZ258 reacted to a post in a topic: New to GMRS and looking for a better antenna..
WRUE951 replied to SvenMarbles's topic in General Discussion
Overuse of call signs are the guys that set their auto CW's on their repeaters every 15 mins of the hour regardless of traffic. Especially the ones that have to announce the date, time, temp, and city.. Crazy as hell -
SteveShannon reacted to a post in a topic: New to GMRS and looking for a better antenna..
I have heard hikers on Pacific Crest Trail refer to the 'Rock House' several times.. Maybe one of the places they can charge..
WRTC928 reacted to a post in a topic: Over use of call sign announcements on GMRS
WRTC928 reacted to a post in a topic: Is GMRS what i need
WRTC928 reacted to an answer to a question: UV-5R and UV-18 Pro Max Dual Receive?
I was not able to hit the Bushnell repeater from the Beef's parking lot Friday night for what it's worth.
H8SPVMT replied to SvenMarbles's topic in General Discussion
Using it when you sign off is all that is required, I thought. -
WSEW927 joined the community
Raybestos reacted to a post in a topic: Way to block TX on non-ham freqs 5RM/K5+
Ya, 30' isn't all that high for an antenna. Mine is at 40' and I might get 5 miles in the right direction. Lots of hills and trees in my area though.
More like Goose Pate'
marcspaz reacted to a post in a topic: Is GMRS what i need
Roughing it has gotten a lot easier. Reminds me of people claiming to go camping when they really me glamping.
They have rest stops/charging stations along the trail, one at least.. I happened across one in the Holcomb Valley above Big Bear while off-roading a few months ago. primitive bathrooms, shower, and solar panels/batteries and hookups for charging.
Does Power Output Matter? (Hint: NO!)
WRUE951 replied to OffRoaderX's question in Technical Discussion
I think the only thing that matters using high power on an HT is it will drain your battery 5 times faster then low power. -
Surprisingly a lot of hikers use GMRS. Living here in the desert with an eye site of Mt. Whitney 75 mile out, I hear hikers up there all the time. They hang out on Ch 3, 7 and 18 and obviously on HT’s. I also pick up traffic from hikers on the Pacific Crest Trail. I’m assuming they use some type of portable solar to keep their radios and cell phones charged.charged up.
WSIZ258 replied to WSIZ258's topic in General Discussion
well.. some moderate success tonight. I heard a few more folks, one on a repeater and another on Simplex. However, I couldn't get a response when I asked for a signal check. I have my R and T DCS tones set, and I'm using channel mode (not VFO), but no responses. My daughter took one of the radios to another part of the house and we tried simplex, and that worked... I'll just keep trying the repeater over the next few days. Thanks for the help all. -
WSIP969 joined the community
LeoG replied to SvenMarbles's topic in General Discussion
What -
Say What -
Troublemaker. -
OffRoaderX replied to SvenMarbles's topic in General Discussion
Someone should make a video on Youtube explaining how simple it is to do... -
Front page doesn't show it. You have to click on the linked license ID to get the address. So my bad. -
dvosko joined the community
I'm sparse with my call sign only because I'm lazy. If I'm telling my wife "I'm on the way home" I might not even say it. But usually because I said it earlier when she called me to ask when I might be heading home. And most don't know how to look up a license ID to make it into an address. I think when you go to the FCC site it doesn't give out the address only the name. I know here the lookup tells you everything. -
11.76dB 4w > 60w
SteveShannon replied to OffRoaderX's question in Technical Discussion
4 to 60 watts is nearly 11 dB. (4 to 40 is 10 dB). -
UncleYoda replied to SvenMarbles's topic in General Discussion
There are more important concerns with GMRS use. -
They have a mental/emotional defect that makes them crave power and control - often because in their life, they have none. -
amaff replied to SvenMarbles's topic in General Discussion
It kind of seems to me like so many GMRS users are eager to police what other people do on the air. Why? -
