  2. Fiber roof. That's not an option.
  3. If you are mounting an antenna that large, i would drill a hole in the top of the bed rail over the tail light and hard-mount a UHF mount. (Or NMO). The only other option would be to use a lip mount on the hood. Something like this... ot the Diamond version. https://www.cometantenna.com/product/coment-hd-5m-heavy-duty-rs-840-lip-mount-w-dlx-166-coax-gold-uhf-conns/ I'll take a couple pictures of mine in about an hour and show you what I have (both) for GMRS and Amateur Radio
  4. If you do choose a ground plane antenna, mount it to the center of the roof. That’s the single most effective place to mount an antenna, but it brings with it other challenges: is the roof metal? If not you’ll need a sheet of metal to provide the ground plane. Is the roof strong enough to withstand the vibration of the mount and antenna? Do you go through car washes? Etc.
  5. i used a cowl mount on my JK that worked well. Check out Cool-Tech, i belive that have one for the Gladiator.
  6. I used to use ARC but i lost my account access when i retired 3 years ago.. Now i use a KML version of this data base for repeater access info etc, which also works great on the mobile app.
  7. A mount on the spare tire is popular. You will want to use an antenna that does not require a ground plane with the spare mount for best performance. All antennas are a compromise, the trick is to decide which compromise you can live with and still get the performance you want.
  8. What's a good antenna mount for the 2025 Jeep Gladiator Mojave? IIRC, the hood is aluminum, so it should provide a decent ground plane, but the way the hood wraps down toward the fender makes me wonder if a regular hood lip mount will work. Does it need something special? Is a hood lip mount even the best way to go? I'm planning to put a 52" antenna on it, so it needs to be sturdy.
  9. Today
  10. I’ve used ArcGIS Earth for that (and line sight analysis)—I’m more suggesting a compass-style feature for the app for when traveling, to quickly discern if programming the tones in the mobile is worth it given mountains possible in the way.
  11. Big 'Pop' vs small 'Pop' .. Love Shooting and i love Parump, my Ammo Depot
  12. That's only 3 paragraphs! Dont worry, the 10 paragraph answer will come.
  13. And here it is. Antennas are tuned to specific frequencies. When they’re used at frequencies other than those they’re tuned for, the results are usually bad. Also, the cable used for a CB antenna is usually very lossy at GMRS frequencies. So, as Randy said, no.
  14. Short answer: NO Someone will come along shortly with the 10-paragraph longer answer but it will say basically the same thing.
  15. maximum pew vs minimum pew
  16. We run separate duplexers with all of our repeaters. The repeaters and duplexers are all mounted in a server rack so no coax going between the repeaters and duplexers are not longer than 2 feet, most are closer to 12-18 inches in length. If the cables are going to longer than 3 feet then definitely go with coax that has less loss since you are going to always lose some power after the duplexers.
  17. Google Earth works great for a heading..
  18. Yup,, pretty much what you see used for Repeaters with Duplexers built into them. . Keep the lengths as short as possible, defiantly no longer than 3'
  19. Even small coax like RG8X, RG316, and RG58 will work just fine for short cables. RG316 is popular to connect repeaters to duplexers. They are generally 3 foot or shorter so loss is not an issue.
  20. Very good explanations in this thread. Ground because lightning. Bond because potential.
  21. Okay, now it makes sense.
  22. Another one: in the app, a compass-based tool to estimate line of sight (or lack thereof) in while traveling. In the mountains I live in, that would be INVALUABLE. I’m thinking compass pointer when you select a repeater, a distance-to readout, and (perhaps) a range field from the owner’s input too.
  23. I have a gm21 baofeng handheld that I am wandering if I could install an adapter to connect to my cb antenna and cable installed in my jeep. I know the range will not be optimal but would it be better than the 8" whip that came with the radio?
  24. Seems like the site has been a bit buggy lately, I got it to show up with stale turned on. Looks like it’s been over a year since the owner updated. @Ark1 try sending the owner a message and ask him about the repeater. They might appreciate knowing that their page fell into stale and that they just need to log into their repeater account to make it update.
