Destro reacted to a post in a topic: Solar stuff...
WRZR615 joined the community
Maybe your tune is a bit off. Doesn't take much.
Destro reacted to a post in a topic: Radios in my Jeep
Noted, I may need to visit that facet
I have the similar XLT 100 watt duplexer, DP-GMRS-100R and it has less than a 1.3dB loss through the duplexer. I think the difference is it's in a rack case and has N connectors instead of 239s. I saw almost no difference between the 3 duplexers I have from the output of my repeater.
My kids likes the ducks and my oldest likes to trade ducks so they stay.
Soooo... I might have a duplexer for sale, Justa sayin....
FYI, the Duplexer I am/was using which gave me 24W from a 47W input is the DP-GMRS-100 by XLT.
Update: I contacted Radioddity about the TYT TH-9800. explained my issue. I have had this gear for over a month but they replied that they would replace it. I am not surprised due to the reputation of this particular machine BUT they did act fast with no pushback, as least for now. Thank you again for all of your input to lead me to not keeping a piece of gear that doesn't work. As a newby, I would have kept it and eventually trashed the $ amount paid.
Get those stupid ducks off the dash! That's an embarrassment to real Jeepers!
WSCN925 started following SteveShannon
How to Update DMR-1701 to Open GD77 on Windows 10 pro
WSCN925 replied to WSCN925's question in Technical Discussion
Can you remote in to program it? -
TNFrank reacted to a post in a topic: Solar stuff...
WRZN509 joined the community
I've done a lot of solar power station/panel reviews on my YouTube channel. I "preach" solar to anyone who'll listen. We get a lot of sunny days here in Arizona so it only makes sense to use solar power.
Picked up a Jeep a few months ago finally got the radios installed. Icom-2730a (Black) for the ham stuff. Antenna is a Larsen 2/70B Motorola XTL5000 with W3 head for the GMRS, Ham P25 and FD stuff. Antenna is a PCTEL (B)MWU4002S I used the fender mounts by Topsy.
Well, I'm not doing show and tell. You are wrong about the equipment. It does not have to be a desktop type rig, i.e. a true base radio; mobiles and handhelds in a house, garage, radio shack, office, etc. with an external antenna on a pole, roof, chimney or in a tree are base stations. That's what they mean by fixed location, and notice they always refer to base station not base radio. My DB20G can be setup as base station, mobile station and portable station. Even my UV5G can be a base station.
WSDX725 joined the community
AdmiralCochrane reacted to a post in a topic: New to 5W Handheld
AdmiralCochrane reacted to a post in a topic: Net Control = Control Station?
WSCK943 joined the community
I just wanted to make sure I don’t end up on some restricted use channel on accident… or is that impossible with a 5W handheld?
Show me a GMRS base station. One that is manufactured to fit the qualifications of a true base station, not cobbled together from a portable or mobile transceiver and power supply. The only units I can see that approximate the requirements of being in a fixed location are repeaters however, they fail the "communicates only with other fixed stations" prong of the FCC definition.
WhiskeySierra joined the community
WSJV727 joined the community
That doesn't match what FCC said. (I put that in another thread.) They specifically said "any station..." without qualifying it except for the specific fixed station limitations. So IMO a base setup definitely fits when it follows the fixed station rules. [And that's not what this topic/thread is about anyway.]
You really have that mixed up. Fixed station has nothing to do with this.
WSCG548 joined the community
Love my anytone 778, in fact i have 2, have one in the car, and the other was my base unit until i came across a 50w anytone 5888 for $50 in "unknown" condition (translation... replace the fuse in the lead and it works) which is now the base radio...
I'm thinking about getting a Radioddity DB25-G GMRS Mobile Radio 25 watt.
WSFB377 replied to WSBX980's topic in Guest Forum
The DB-25G has a lot of potential, but unfortunately seems to have quality issues (see Amazon note about frequently returned), a number of little firmware quirks, and in my experience output was a good bit below the advertised watts. I went through several (thank goodness for Amazon's easy returns/replacement) to end up with a unit that has a few quirks I can live with. At least one of the units I received had trouble with reading/writing with both the factory CPS and CHIRP. While not a GMRS radio, I have often wondered if the BTECH UV-25X2 (similar radio, but with BTECH custom firmware) solves a lot of the issues. -
hcubed joined the community
That’s a great example. Another example would be dedicated intercoms between two or three buildings.
I'm seeing that after reading what Boxcar posted.
GMRS channels/frequencies are shared with FRS and channels 8-14 are restricted to 0.5 watts. Make sure your radio doesn't have any "privacy" (they aren't private) tones set. If tones are set, you won't be able to hear anything that doesn't come from a radio using the same tone. You'll need to set tones to use repeaters, but first clear them all out and listen to see who's talking and what channel(s) they're using.
Yes. It's best to think of fixed stations as transmitters permanently attached to a fixed pad firmly attached to the ground under them. They are used to send information from one permanent location to another station meeting the same mounting requirements. The best example for the simpletons is a radio transmitter connected to a gauge monitoring liquid levels or pressure at one location sending to a receiver at another permanent location that receives only the information from the sending unit of the pair.
WSJW708 joined the community
Don’t confuse Fixed Station with fixed location. A Fixed Station is not the same as a Control Station. Nor is a Fixed Station the same as a Base Station. All three are located in “fixed locations” but all three serve different purposes and have different limitations. A Fixed Station is limited to 15 watts and is required to only communicate with other Fixed Stations. Base Stations and Control Stations may have 50 watts and are used to communicate with other types of stations.
Look at this: The FCC defines "Control Station" in the context of radio services, particularly under Part 95 of Title 47 of the Code of Federal Regulations. While the term isn't always explicitly defined in every radio service, here's how it's generally understood: FCC Definition (Part 95 Context) A Control Station typically refers to: l l A fixed location station that communicates directly with mobile stations and other base stations. It may also serve as the central point of control for a system of cooperating stations, such as in repeater or auxiliary setups. In amateur radio (Part 97), related terms include: Control Operator: The person responsible for ensuring the station complies with FCC rules. Control Point: The location at which the control operator exercises control over the station. Remote Control: Operation of a station from a distance via a control link, still under the supervision of a control operator. You can explore the full regulatory definitions in 47 CFR § 97.3.
