Deregulation; here’s your opportunity to make a difference!
bscabl replied to SteveShannon's topic in FCC Rules Discussion
i have a camp at the lake a half mile down the road on 4 and 5. sooooo tempting to chat them up -
bscabl reacted to a post in a topic: Deregulation; here’s your opportunity to make a difference!
WRXB215 reacted to a post in a topic: Over use of call sign announcements on GMRS
Davichko5650 replied to SvenMarbles's topic in General Discussion
But it is vitally important, if not imperative that they first discuss their recent Bunnionectomy and the status of Myrna Mae's Hernia prior to getting into the nuts an bolts of antennae... -
Davichko5650 reacted to a post in a topic: Over use of call sign announcements on GMRS
WRTC928 replied to SvenMarbles's topic in General Discussion
To the best of my knowledge, there is no way to do that. -
bscabl reacted to a post in a topic: GMRS Expanded Personal Business Use
These antennas are sensitive to the mount type and location. I ran an SWR scan on mine when on a roof rack type mount. https://forums.mygmrs.com/gallery/image/615-ca-2x4srjpg/?context=new There is also a Diamond antenna very similar in design. https://forums.mygmrs.com/gallery/image/613-nr240ca-roof-rack-mount-swr-and-photojpg/
Some sellers are actually selling unlocked versions on Ebay.. I saw a few couple weeks ago on Ebay. I messaged the seller and they said they would ship me an unlocked uv5r on request.
WRUE951 reacted to a post in a topic: Unlocked UV-5G?
I believe bubble-gum is the standard...
bscabl reacted to an answer to a question: Amature bands VS. GMRS Range
I have the CA-2x4SR mounted on my Jeep. It's on a corner mount just above the taillight. My SWR in GMRS is less than ideal, but 2m is near perfect. I'm looking to try out the Laird B4505CNS next for GMRS. I don't think there is a flat enough ground plane to help out my GMRS numbers. SWR: 462 - 2.03 467 - 1.8 146 - 1.08
makes sense. I contemplated the uv5r plus ones but i cant find anything reliable that says they come unlocked. im not trying to "use them in an unauthorized manner," and i am smart enough to use chirp to code out tx on emergency bands and such to prevent accidental transmitting, but i want the freedon to tinker how i see fit with gmrs simplex and such while using my uv5g plus's for actual communication. yes I picked the lowest possible barrier to entry in case I get bored with the entire thing and throw them in a drawer... I can always upgrade as I grow more if i keep with it. I plan on studying for HAM as well and if I stick with it, getting that license as well.
Password for Baofeng UV-5RM Pro GPS Software.
None of those passwords worked. I reached out to Baofeng to see if they could provide the passwords needed. Thanks for trying. -
You only need to post the query once. Having the same question in multiple places makes it difficult for you to learn of good suggestions/answers to you issue.
I've been hearing that more and more.. Either they are not locking the new ones or they are "accidentally" shipping the non-U.S. models into the U.S.
Caryt started following Antenna guidance needed.
I have a Jeep Gladaitor with a AluCab canopy Camper with 2ea 200w solar panels. They are mounted on 3 rails, rails are Alumnum as is the camper and frame work of the ridged panels. I have a Midland MXT 575 and will be using this to talk to others on overlanding trips from desert to mountains. I would like a antenna no taller than 18" and would like it mounted if possible on the middle rail or the rail closest to the cab. Note the Jeep tops are fiberglass so not mounting their.. I also will be runing a Kenwood TM-V71A so if anyone has knowledge on it ..same location for its antenna. I won't be using both at the same time and don't want just 1 antenia for both. I would rather not mount anywhere else. Antennias will be permanently mounted. Thanks!
Caryt joined the community
73blazer replied to SvenMarbles's topic in General Discussion
I've never heard the likes of such behavior. No ID. Well. How uncivilized. I bet they use DCS tones too. What has this world come to?!?!?!?! -
So it'd be the radio password IF I'd have created one otherwise it's be a more generic one. I'll give it a try, thanks. -
I must have gotten lucky. the two UV5Rs i received yesterday came full unlocked. [I own straight GMRS equipment too.. I bought the 5r's on the cheep for educational reasons]
bscabl reacted to a post in a topic: Over use of call sign announcements on GMRS
MURS Multi User Radio Surfer
PRadio replied to WSAA635's question in Technical Discussion
Try 000000. If that doesn't work, try 123456. Another I saw online was, 059500. That is unless you have created a password for the radio already, if so use that password. Phil -
WSIE526 joined the community
But only the FrankenRepeaters have the controller dangling from the side and have a Rasperry-Pi sticker on it.
All repeaters have some kind of repeater controller. There’s an open source repeater controller built on the raspberry pi.
WSJB956 joined the community
Not necessarily.. But, usually. Generally speaking, on average, usually, statistically speaking, most of the time, a purpose-built repeater is going to perform better than a Frankenrepeater.
Ok so stay away from things like this
Only home-made/rinky-dink type repeaters come with those raspberry pi things.. It operates as the 'controller' between what is probably two radios scotch-taped together to control or coordinate the two radios and/or do things like Auto-ID. A REAL repeater, has no such rinky-dinkn'ess .
Newbe question time. Why do some repeaters come with this raspberry pi thing.
WSIU227 joined the community
Tanker joined the community
I ordered a couple of the new Baofeng UV-5RM Pro GPS radios and was looking over the Baofeng programming software. There's a couple areas(Program Password, Frequency Range, Embed Information) where they ask for a Password to unlock it. Does anyone know what it might be? I looked at the Baofeng website but there's nothing there about this issue. Thanks.
