PB30X
    3
PB30X last won the day on November 26 2021
PB30X had the most liked content!
1 Follower
About PB30X
    Pennsylvania
  • Interests
    Outdoorsman!
662 profile views
  1. Sure can, there are several ways to do this. 1) The linking bundle provided by myGMRS.com (https://shop.mygmrs.com/collections/repeaters-and-accessories/products/repeater-linking-bundle ) is quite capable of this with a few modifications to rpt.conf and iax.conf you’ll be on your way. 2) Allstarlink has a download page using the ASL image for the RaspberryPi. In your situation I would consider the v1.01, and follow instructions from the ASL website links etc. 3) I would suggest the myGMRS route due to the complexity of Linux, and Rich went through great lengths to keep it clean, and LEGAL! [emoji1303]
  2. Good Question! If I were to answer this, I would strongly suggest NO, only because of possible interference with cockpit and other technology onboard, just a guess. I do believe nowadays the internals of newer planes are like faraday cages anyway. Someone will be along shortly.. just my .02
  3. The Repeater will dictate what frequency and tone examples to be used. REPEATER: Transmit radio TX 462.675 with an “encode tone” of 141.3 will be your handheld, mobile or base radio receive RX “decode tone” 462.675 tone 141.3. REPEATER: Receive radio RX 467.675 with a “decode tone” of 141.3 will be your handheld, mobile or base radio transmit TX “encode tone” 467.675 tone 141.3. Breakdown Repeater Settings: Transmit Frequency: TX: 462.675 MHz Transmit Encode Tone: TX: 141.3 Hz Receive Frequency: 467.675 MHz Receive Decode Tone: 141.3 Hz _____________________________________ Base, Mobile and/or Handheld Settings: Transmit Frequency: 467.675 MHz Transmit Encode Tone: 141.3 Hz Receive Frequency: 462.675 MHz Receive Decode Tone: 141.3 Hz ***DCS/DCSS etc follow the same examples.
  4. Chris, I own RINO 755t’s also to including the older 400 series as to which are not readily available to analyze and confirm models but DO INFACT work on repeater systems providing the “repeater is the same tone in, and tone out. I can verify this as we used them for hunting, fishing, and especially hiking. The 755t is the newest and most current and rugged radios of the Rino family. Again Repeater Input, and output must be identical on the repeater side. However the peer to peer does not function on repeater channels.
  5. This was shared previously somewhere! TYT TH-9800 Mobile Two-Way Radio Programming Software & Cable Kit https://www.amazon.com/dp/B00RDQBG1Q/ref=cm_sw_r_sms_api_glc_fabc_0Vb4FbZYQ8D3S
  6. Hopefully that’s a typo on the frequency pair you describe, otherwise you may have a radio shop program the radios for you. You may be hitting a business band, or emergency services department. Clearly those frequencies are NOT GMRS[emoji15], so I can’t elaborate anymore as to what it is you are trying to do. I would suggest having someone else program your radio, before other legal consequences come upon you[emoji1303]
  7. **AKA** ANDREW DB413. The band depends on the measurement of the element end to end[emoji1303]! I’m thinking 11 1/8” is the 450-470, and the 10 3/8 is the lower 70cm band. Don’t quote me but the measurements are close! I have a few of their products but I do not own the directional antennas, just their yagis.. Minimum I would ask No less than $500 IMO, they’re good antennas[emoji1303]
  8. Again, I just read it somewhere on here, that may have been posted from a few years back. I’m not on here enough to read enough through outdated posts. So again, before ordering double check to see if this LINKED SYSTEM is accepting SIMPLEX. That’s all I really know, I just own duplexed repeaters, never played with SIMPLEX repeater systems, other than peer to peer and group communications. Don’t Quote Me on RULES lol, I’m NOT up to date yet! Good Luck[emoji1303]
  9. No particular reason, just know I have read this somewhere!
  10. No Problem! These nodes are setup for duplex repeaters, not sure on what type of project you have going but these are setup for repeaters, “Not Simplex” from my understanding.. Simplex is Not allowed on this system as far as I know.
  11. Try this link https://shop.mygmrs.com/collections/repeaters-and-accessories/products/repeater-linking-bundle
  12. REPEATER: Receive RX 467.XXXX Tone/PL/DPL XXX.X Transmit TX 462.XXXX Tone/PL/DPL XXX.X HT/BASE/MOBILE: Receive RX 462.XXXX Tone/PL/DPL XXX.X Transmit TX 467.XXXX Tone/PL/DPL XXX.X
  13. I don’t personally use chirp but remember that it is tone Squelch CTS I believe and leave everything else alone, unless you can adjust bandwidth.. Again I don’t have chirp, but if you dig here somewhere there is useful info there[emoji1303]
  14. (1) I Would still ask permission or atleast acknowledge that you will be using the repeater, regardless of Open repeaters. State your callsign, and check in if anyone is available. 462.700 both TX/RX is in Simplex mode. (2) Your output frequency should read 467.700! (3) RX 467.700Mhz (4) TX 462.700Mhz Good Luck!
  15. To All, Have a Safe, Happy, and Prosperous New Year! WQXP640
