Having the antenna right next to that roof rack is not ideal but should still work. Try moving the antenna onto the middle of the rack and see if that makes any difference.
PS: those Baofeng hand mic's aren't the best. One trick to help is to take them apart and open up the microphone hole.
I watched that video and decided not to even try that repair. I work with small N scale digital command control boards, but that is mostly just soldering 28-32 gauge wires to the boards.
Most of the local departments and state highway patrol have all gone digital around me. One sheriff's department still uses analog and all the small towns go through county dispatch.
I agree that it is worth checking the squelch and narrow/wide band setting on both radios before sending it back. I don't remember how the XS20G was setup from the factory since I always go in and set everything to wide band anyway.
I would contact the vendor that you bought your radio from. The XS20G should have good reception when is using a good properly tuned antenna.
Now I do have to ask. How and where is your MXTA26 antenna installed? Does the antenna have a good enough ground plain?
I run a KG-XS20G in my SxS with a Comet 2x4SR antenna on a mag mount. The antenna is on the metal rack on my SxS. I get great reception When talking to others on simplex and when talking on the repeater 21.5 miles away.
Here is the Comet 2x4SR on the back of my SxS
It is the USB port for CAT control. I am using a Yaesu SCU-17 currently for CAT control for WSJTX/FT8. The SCU-17 was a whole lot cheaper than sending the radio in for repair.
I have a Yaesu FTDX10 with a bad USB port. But Yaesu quoted $900 to repair the radio even though it is still under warranty. They WILL deny warranty claims if you do not have the original receipt, which I do not.
The problem is that there is no standard format for the exchange of GPS information between the different manufacturers. Wouxun has their own version in their KG-Q10G too. It's kind of like the digital modes for amateur radio. You have DMR, Fusion, and D-Star. None of them work with the others.
Most of the time each repeater that is on the same channel will use different tones. It would be a real mess if all repeaters on the same channel used the same tones or no tones at all.
Yes it is. Now most people can get by just fine running two 50 mobile radios on one 30 amp (peak) power supply simply because most will never be transmitting on both radios at the exact same time.
Now if people were to transmit on two 50 watt mobiles at the same time say like during a field day/demonstration, then some 30 amp power supplies might not be enough. It will depend on the continuous amp rating.
Remember that most manufacturers advertise their power supplies at the peak amp rating. You want to double check to see what the continues amp rating is. Most power supplies advertised as 30 amps are normally between 24 and 26 amps continuous.
Wouxun does make some good hand held radios. The KG-935G has been a solid radio for me and others. I know a few guys that really like the KG-UV9D Mate and KG-UV8H. I've been considering the new KG-Q10H quad band radio myself.
This is a commonly talked about topic here and on other radio related forums. Do a search on this forum.
The majority are against any type of digital mode on GMRS.
