WRYZ926
    47
Everything posted by WRYZ926
  1. Good luck getting the FCC to do anything about the military's use of the bands. The military has priority no matter what.
  2. It is possible that military radar is causing the interference. Or it could be government data transmission bursts. I do know that 70cm repeaters are restricted in certain parts of the country close to air bases because of their radar systems. I usually see large government data transmissions on the 17m band every weekday evening around 5 - 7 PM central time.
  3. Is this something that happens all of the time or did it just start since Friday? The solar storms have definitely been causing issues with all of the bands and GMRS since Friday night.
  4. WRYZ926
    SWR
    Anything under 2.0 is fine. Even with a SWR of 1.8 on 467.600, I still get great signal reports with the Comet 2x4SR hooked to my Wouxun KG-XS20G radio. The repeater is 21.5 miles away from my house. The SWR is 1.2 at 462.600 and 1.5 or less on the 2m and 70cm bands when using my 20 watt TYT TH-8600. Both radios and antenna are on my SxS.
  5. WRYZ926
    SWR
    I wouldn't worry about 1.65 SWR. I run a Comet 2x4SR and the SWR on 462 MHz is 1.2 and 1.7 on 467 MHz. The SWR is also very good for 2m and 70cm. Are you going to use the radio and antenna for 2m and 70cm? If so, then check the SWR for 2m and 70cm before making any changes to the antenna. Also you need to know where the antenna is most resonant before making any changes. This will require using an antenna analyzer.
  6. EMF will affect HF for sure and can affect VHF depending on how strong the electromagnetic field is and distance from the source. I am surrounded on three sides by utility lines in town with two transformers (one south and one north of my property. And the neighbor's above ground service connection is on the fourth side. I haven't noticed any interference on HF, VHF or UHF.
  7. As mentioned, you should be far enough away from the power lines. While high voltage power lines do put out an electromagnetic field, you have to be pretty close before they will cause interference. And they will not affect UHF/GMRS like they affect the HF frequencies. Funny story. I operated a truck mounted machine shop powered by a 25KW PTO driven generator. The generator was not electromangetically suppressed and would jam all comm equipment within 100-150 feet of the truck.
  8. Glad to hear everything is working out for you. And if you keep your repeater setup private/family use only, then you shouldn't have to worry about duty cycle or the radios getting too hot.
  9. @Sshannon we have mentioned that to them. The FRS base station was just talk since the grandson loves radios so much. Grampa is also our club's head VE so I don't see him breaking the rules. Again, gutting a legal FRS radio and putting the guts into a 3D printed body with the antenna permanently attached was just talk. I'm sure Grampa will get the boy licensed as an amateur in the near future.
  10. 20m has been in and out all day on SSB and FT8. I did find two guys rag chewing on 17m earlier this afternoon. Other than the one signal on 17m, all of the higher bands have been dead on SSB and FT8. I sat there and listened to the two guys on 17m, one had a good strong signal while the other was pretty weak. That did allow me to fine tune things on my Xiegu G90 though.
  11. Grampa doesn't want to get a GMRS license. And yes we have been trying to talk him into getting his GMRS license. This whole project will probably go nowhere anyway.
  12. And that is why this project hasn't gone beyond talking about it. Yes all involved are aware of the regulations. And this is why it was discussed using a legal FRS radio inside a 3D printed case to make it look like a mobile/base station.
  13. Yes that is an option as is using a regular GMRS mobile programed with CHIRP to keep it set on low power, etc. No one in that family has a GMRS license and they are not interested in getting one. Grampa has been licensed for amateur radio since the 60's and will get his grandson licensed when he gets a little older. I will pass on the information though.
  14. The HF bands are still dead this morning. 20m is the only band with any decent activity right now. So far VHF and UHF has not been affected. Here are a few photos I took last night. I used my iPhone 14 to take the photos. I could not see the green with naked eyes.
  15. One of our club members has been considering how to make a FRS base station for his grandson. We talked about taking the guts of a FRS radio and installing everything in a 3D printed body to keep the antenna permanently attached. His grandson is about 7 years old and loves talking on the radio with his grandpa. As far as assembling an AR. I use nothing but simple hand tool for the lower while sitting at my desk or on the couch. I only use a vice and torque wrench for attaching the barrel and muzzle device on the upper. Otherwise I hand assemble the rest of the upper at my desk too. @Davichko5650 your post made me smile remembering all the gags we would pull on each other when I was in the Army.
  16. I am using the MXTA12 and Melowave mag mounts and I haven't had any issues. The Melowave has been holding my Comet 2x4SR to the expanded metal rack on my SxS without any issues.
  17. I was on 20M FT8 when the aurora popped up over mid Missouri earlier. I could tell when I started getting a lot of noise show up on my WSJT-X waterfall. I stepped outside and got some good photos of the aurora. I haven't noticed much effect on 2m, 70cm, or GMRS tonight. But the HF bands were definitely affected. I did make a few contacts on 6m this evening. Everyones voices sounded digitized and weird.
  18. I have to agree with @WRWE456, more information is needed so we can make recommendations. If you have eight restrictions, then something like the Nagoya UT-72G or Tram 1174 will work well. The Nagoya is 19" long and the Tram is even shorter. The Comet 2x4SR is an excellent antenna if you don't have to worry about height restrictions, it is around 38" long. As mentioned, the center of the cab roof is the best spot. A lip mount on the hood or mounting on the top of the bed rails will work but not ideal or as good as the cab. I agree that going with a NMO mount is best. Go with a magnet mount if you don't want to drill any holes. The Midland and Melowave magnet mounts are pretty nice at reasonable prices.
  19. @kidphc I agree having a turn key option is a good idea. B-Tech needs to work on their duplexer setup first. They could offer a duplexer setup for a single repeater channel for now and let customers choose which channel when ordering. That would give them time to perfect the current multi channel duplexer.
  20. I wonder if B-Tech is trying to do too much with the built in duplexer by having it work on all the repeater channels. After talking to people more knowledgeable on the subject, they sure think so. Duplexers that are small enough to fit into a repeater will not work as well as separate external duplexers. And that is why we went with a separate duplexer when we set up our Bridgecom GMRS repeater.
  21. The Retevis and Midland repeaters are good for covering a smaller area or for limited use. I would personally stick with a Bridgecom repeater or a used Motorola repeater programmed for GMRS if you want something more powerful that the Retevis/Midland repeaters.
  22. I watched the video and I have to say kudos for B-Tech's customer service . I am underwhelmed about the repeater though. Too bad they can't get the repair parts in. I don't blame you for getting a refund.
  23. While the TYT hand mics for their mobile radios are fine, their hand held mics are a different story. I have an Explorer QRZ-1 with hand mic that is nothing but a TYT UV88 with custom firmware. And the two hand held Baofeng hand mics I have aren't any better. I had to open up the mic hole on all three hand mics.
  24. How long have you had your 935G and is it the Plus model? I bought my 935G Plus in November 2023 and it came with the USB-C chargeable battery.
  25. You are correct that the concepts don't change. I am use to working with electronic components for industrial machine controls which work a little different that when in radios. That has tripped me up a little.
