47
Everything posted by WRYZ926
Midland makes one and it works quite well. I have one on the aluminum tool box on my SxS and it holds the Comet 2x4SR antenna just fine. https://midlandusa.com/collections/accessories/products/micromobilemxta38-adhesive-backed-metallic-mount
One will not notice any difference between 4, 5, or 8 watts. You basically have to quadruple the power output to notice a difference. Yes you will be able to notice a difference going from 5 watts to 25 watts. I have tested stock antennas versus the Nagoya 701 and 771. The 771 helped with receive on some hand held radios but weren't any better than the stock antennas on other radios. The wa not any improvement with the 701 compared to the stock antennas on any of my radios.
I have to agree with what everyone has said about the coax. TV/Satellite coax cable is the wrong stuff for radio antennas. You want coax rated at 50 Ohms. LMR400 or equivalent is what you want for UHF frequencies to include GMRS. Plus your antenna is not tuned for GMRS frequencies either. GMRS is 462 MHz and 467 MHz. The antenna may or may not have decent SWR for GMRS. I also see the dish causing issues with your vertical antenna. Either raise the antenna above the dish or remove the dish from the mount (if not in use).
Pine and cedar trees are the worse when it comes to absorbing UHF radio waves. Our repeater range is limited to about 30-35 miles when using a mobile radio depending on location. There are a lot of hills and valleys with old growth hard wood trees along with lots of cedar trees. Our GMRS repeater antennas are at 400 feet and our 2m and 70cm repeater antennas are at 900 feet on the same tower. I live 21.5 miles away from the tower. It is hit or miss on if I can get into the 70cm and GMRS repeaters with a hand held radio from my house, it depends on band conditions. I normally do not have any problems getting into the 2m repeater from home with a hand held. I have several hand held radios and the Wouxun KG935G Plus and KG-Q10H work the best for me. I have an Icom IC-T10 (entry level) along with an Explorer QRZ-1 (rebranded TYT UV88) along with several Baofeng radios.The IC-T10 and QRZ-1 aren't much better than the Baofeng radios when it comes to RX/TX clarity and picking up interference. I have to agree to reach out to the local GMRS repeater owners and your local ham club members. It is becoming more common for amateur radio license holders to also have their GMRS license. Most will be more than happy to help new people out. Our club put up a GMRS repeater for an extra means of communication along with using GMRS as a possible stepping stone for those interested in amateur radio. Congrats on the new 935G Plus, you will enjoy it. I will suggest using the actual Wouxun programing software that can be downloaded from Buy Two Way Radios for free. You will need a Windows computer to run the program, but it is easy to use.
You will want your radio to TX on 467.625 and RX on 462.625. You will use the correct repeater channel which will be listed on your radio as either repeater 18 or some radios list it as channel 26. Either way make sure to use the repeater channel so that your radio is transmitting on 467.625 and receiving on 462.625
The UV-5R GMRS radios for $30 is a good deal. And they are perfect for handing out to family and friends or when you are doing something that you might worry about dropping/breaking a radio. I have a set of them myself and while not the best radios, they do work as intended.
I agree that you will be happy with the KG-935G Plus. I have one that is my goto hand held for GMRS use. Best wishes on your treatment. I hope everything goes well for you.
Can Midland lip-mount and magnetic mount cable be shortened?
WRYZ926 replied to dosw's question in Technical Discussion
While you definitely have loss with RG-58 at UHF/GMRS frequencies, a good antenna with enough gain will help overcome any loss from the coax. RG-58A has a a loss of 11 dB or 92% loss at 100 feet for 467 MHz. You are actually looking at a gain of 1 watt (with a 5 watt radio) for a total of 6 watts out when using 19.5 feet of RG-58A coax with an antenna with 3 dBd ( 5.15 dBi) of gain. So if your antenna has a good ground plane and at least 5 dBi/3 dBd of gain, then I wouldn't worry about shortening the RG-58 coax. Roll any excess up in a nice circle and it will act as a 1:1 balun which helps keep RF from running down the outside of the coax and into the radio. Here is the coax loss calculator I like to use. https://kv5r.com/ham-radio/coax-loss-calculator/ -
I can't answer about the differences between the 9800D and 9800 Plus models. And yes the 9800 can be unlocked following the instructions found online. In fact the TH-9800 unlock also works for the TH7800.
Any mag mount will work. You will need a SO239 to SMA female cable. SO239 to SMA female cable
How do you have the radio connected for power?
I have not noticed anything like that with my Wouxun KG-Q10H or KG-935G when comparing them to my Baofeng,, Icom and QRZ-1/TYT HT's. In fact, I pick up more noise interference with the Baofeng, Icom and QRZ-1/TYT radios than I do with either Wouxun radio. It is hit or miss on my getting into the GMRS and 70cm repeaters with aa HT from my house since I am 22 miles from the repeater tower. I normally don't have any issues getting into the 2m repeater at that distance.
While repeaterbook.com does list GMRS repeaters, their list is a bit outdated. This website is a lot better when it comes to having an up to date repeater list for GMRS repeaters.
That is what my local club is using for our GMRS repeater. It works fine and has handled everything we have thrown at it. We tested it for about two months before opening it up to the public. The duty cycle is fine for a lot of traffic.
I have to agree with others that you might want to contact B-Tech about the issue. Sounds like there might be a problem with the duplexer. You are using good coax and a good antenna. How high is the antenna above ground and is there any obstructions such as trees or building near by?
I'm not going to argue with you. It is a well known fact that RG8 and RG8X has high loss on UHF frequencies. Here is one of the better loss calculators I have found. https://kv5r.com/ham-radio/coax-loss-calculator/ I suggest doing your own investigation. You will find that RG8 and RG8X are not good for UHF frequencies.
@WSBT338 I would definitely go with a different type of coax cable. RG8X has a lot of loss when used for GMRS frequencies. You are looking at a loss of 8.4 dB for a 100 foot run of RG8X, that equates to an 86% power loss. Let's say you are using 100 foot of RG8X, you would only be putting out 7 watts at the antenna with a 50 watt radio. Now let's say you are using 50 foot of RG8X with a 50 watt radio. You will have a loss of 4.2 dB which is a 62% loss with only getting an output power of 18.9 watts.
How many MURZ farz in the woods?
WRYZ926 replied to GreggInFL's topic in Multi-Use Radio Service (MURS)
Those type of roll up j pole antennas definitely work. The faraday clothe j pole antennas will roll up into a smaller package and are pretty easy to make. The guy that made the video I posted earlier also sells them built for 2m and 70cm. You could definitely make your own and tune it for what ever band you want. https://vfcomms.com/product-category/antenna/ I have to agree that BNC connectors will be better than using the SMA connectors. There are quite a few YouTube videos of guys using those faraday cloth j poles and they are generally using them at 20-30 feet high in trees. And there are many ways to get your string up to pull the antenna into the air. Either type of roll up j pole will serve well in an emergency situation to get your antenna as high as you can to get more farz out of a HT. -
There are instructions online for making 2m and 70cm roll up J Pole antennas using faraday clothe. It would not be that hard to modify a 2m faraday cloth j pole for MURS or modify a 70cm faraday cloth j pole for GMRS. You would need some way to get the antenna up high along with some coax cable to connect it to your HT. There is usually a solution or two for every problem. https://www.youtube.com/watch?v=X7K6DNLD9Wo&t=3s -
Nice view from your front door @GreggInFL But yes you are correct, all that will affect both VHF and UHF unless you can get an antenna above all the trees. -
I can't wait to see the reviews. I would like to see how both of those radios compare to the Wouxun KG-Q10G also.
Knowing that information would definitely help. Using the best antennas and best coax cable that you can afford is very important and makes a big difference in performance.
I would like to see a CB radio tested on FM since that would be a closer comparison to MURS and GMRS. GMRS and MURS are FM frequencies. And yes I have been looking into getting a CB radio with AM, FM, and SSB capabilities. -
I was wondering how long it was going to take before someone mentioned that the FTM500 is a amateur 2m/70cm radio. Yes the FTM500 can be MARS modded. But they would still make a poor repeater. Plenty of people have used two mobile radios as repeaters, but they never work as well as a dedicated purpose built repeater. Mobile radios just can't handle the higher duty cycle like a repeater can.
It's been asked before but I'll ask again. Good 20w mobile with....
WRYZ926 replied to Ziggidy's topic in Equipment Reviews
I know the Wouxun KG-XS20G is probably the most expensive 20 watt GMRS radio but it is an excellent radio. And most have found that they are actually putting out 25 watts on high power. I went with the XS20G since it is IP65 rated for dust and water. A radio with a good IP dust/water rating is a must when installing a radio in a SxS or other open type off road vehicle.
