That's very smart. Hilarious, but smart. Well done, sir!
How did you piece this together? Poles are easy to find, but what are you using for a base? How did you attach the pizza pan?
Yes, I've used a similar adapter for 120 -> 12V.
Road trips with multiple vehicles and outdoor activities with friends. The value of radios when out of cell range is obvious, but I'm always amused when the "just use a cell phone" crowd realizes the radios free up the cell phones for other uses. Plus, texting in a car is not easy, and who wants to set up a conference call when there are 3+ users?
The mag mount uses a pizza pan for a ground plane. I placed it in the top shelf of a closet where it worked well for RX but not TX, so I'll have to move it to the attic or outside. The rig is in the vehicle now, but when I next have it inside I'll try those options.
If 265 DPL is the input tone of the repeater he wants to hit, wouldn't he put that in the TX DCS?
I'm having a similar problem in that I can't find "DCS" as a tone option on Chirp for my UV-5R.
EDIT: Okay, I found DTCS, which appears similar. I'll give it a try.
I've nearly talked the HOA into putting up a repeater to be used post-hurricane, but some aren't convinced it would be worth the money. This is perfect for a dirt-cheap proof-of-concept demonstration. And I already have a pool-cleaning pole.
Yeah, 16 is the hailing frequency. If you linger there a grumpy person wearing a uniform will bark at you. 22a is the USCG channel for announcements. Never TX on 22a.
I've noticed channel 9 is being used for hailing. Must be a policy change because when I took the CG Auxiliary class (centuries ago) it was reserved for emergencies.
It's about time. What's the harm in standing on the end of the dock with a marine HT discussing with the vessel's captain how they want the dock lines rigged?
I haven't tried it yet. It's my mobile antenna and the idea of running cable with adapters for something that will eventually go back in the vehicle makes little sense. Presently looking for an antenna I can park in the attic as a permanent base antenna.
Any recommendations? 5' - 6' max height.
I returned one to Amazon because the unit would go through a power-down-power-up cycle when keyed. Happened about 25% of the time. Replacement works fine.
Yup, that's simplex. I usually figure range in a wooded area to be 1/2 - 2 miles with a handheld. Anything beyond that is icing on the cake. The more elevation and antenna the better.
Congrats on getting it running.
Similar here. I assumed my 25W mobile and 3dbi mag mount would work great with a pizza pan in the closet. I was very wrong. Time to get a base antenna, some LMR400 and drill a hole.
Welcome! You're in the right place. There are some very smart and helpful members here, many amateur + GMRS combos like yourself. And a few lightweights like me.
LOL. Yeah, that one could be a problem. Odd they would call it "Open" yet not provide the tones. You could always brute force it; try all the tones and see which one works.
I've had multiple requests pending for over a year. If the repeater is listed as open, and I've had no response to a request for access, I just use it. If the owner doesn't want me on it they'll let me know.
I'd do the same if it were my repeater; i.e. just turn it on and let it go.
I bought one this summer when Amazon had it on sale for $89.99, which made it cheaper than the DB20-G. I returned it immediately because about half the time it would go through an off-on cycle when the PTT was pushed. The replacement has worked fine.
Connected to a Nagoya UT-72G I'm all in at ~$125.
Ordered a pack of the Baofengs mentioned in the OP. Tried one this morning on an HT and hit a repeater ~5 miles away through the woods. I'm sure the signal is poor compared with longer antennae, but still surprised it connected. Could be a nice option for campsites or road trips. At $9.66 for a four pack, may as well throw some in the bag.
