70
Everything posted by JohnE
Updated FCC rule 95.1749 now includes “or other networks” Jan 2024
JohnE replied to cozy659's topic in FCC Rules Discussion
Quick question Was there any other meetings like this anywhere else or was it just the northeast. -
How can I make my repeater allow APPROVED unit IDs only?
JohnE replied to WRYF747's question in Technical Discussion
Another option would be using an LTR controller ,w/that said all of your radios would have to be LTR capable -
best ⅝ wave GMRS high gain NMO antenna
JohnE replied to CyborgAlienWRYG738's question in Technical Discussion
have been using these for decades but single band https://d3dqzy9ky05fbv.cloudfront.net/wp-content/uploads/2020/06/ASP-Mosaic-Series.pdf also have been using a Laird B4505 for a few yrs now and I find it comparable to the Mosaic -
DC Blocker to protect SDR using Y-Cable splitter
JohnE replied to WRVS497's question in Technical Discussion
https://www.rfparts.com/relays/relays-tohtsu.html http://www.advancedreceiver.com/page22.html I' sure there is a way to make one of these for for you found one more https://www.w6pql.com/using_inexpensive_relays.htm and an article https://www.rtl-sdr.com/building-a-transmit-receive-relay-system-for-a-boat-anchor-transmitter-and-sdrplay/ -
Effort is a gross understatement back story..... not enough room for a fall zone , too much BS to put up a 125' tower. Have ~100' pine trees in strong health condition. Hire tree guy and he thinks I'm nuts but he's getting paid. Put the whole antenna ,pipe and cable attached together on the ground. strain relieved and stressed the cable before having it hoisted and mounted as one piece. My only mistake in the was cheeping out on the antenna. So far it has served me well.
a little lite reading on grounding https://www.blm.gov/sites/blm.gov/files/Lands_ROW_Motorola_R56_2005_manual.pdf as to mast- while I agree EMT is a poor choice I have used 1" aluminum for many yrs on lightweight antennas (sub 6 lbs and <8') pretty much anything that has a bending moment of less than 75 ft/lbs. Most of the antennas that are made for our purposes fit that description.
From personal experience wish I still had the pics LMR 600 long story short the outer casing on the cable becomes porous and water migrates into it. at best in the NE 5-7 yrs and it needs to be changed. As a sub for 400 I sometimes use FSJ 2. Similar size and loss
- 5 replies
- repeaters
- repeater help
(and 1 more)
Tagged with:
12 and 20dB sinad is all I care about. Where does it open and where does it close in CSQ or pl
Kenwood TK 805d , 880, 863, 8160, 8180 and NX 5800
Weather Sealing Type-N and PL-259 Connections
JohnE replied to Wrvq441's question in Technical Discussion
variation on Jeep crawler that I have used for decades is self vulcanizing silicone tape, E tape, butyl mastic and more tape. Have used heat shrink w/"glue" inside where tape was not really an option. -
like a microwave backbone
GPS would be for simulcasting to sync the transmitters timing. Also said transmitters would have to have a high stability XO to lock it on frequency. You are need a comparator or something that works like one. seeing as you are using IP everything should come back to one "computer" and select the site w/best RSSI and as it moves it goes to the next. IIRC there was a HAM that had some you tubes on it. I think it was in relation to a simulcast set up. hope this was some help
Grounding is a double edge sword. most power supplies have a grounded plug(3 prong) that means it is grounded to your AC electrical system. The radio attached to it is in turn grounded as is the antenna connector on the back a chassis ground. You see where this is going. At a minimum I would get a Polyphaser and make sure it has a proper ground that will offer some protection. The pic below is an example of a direct hit. Antenna was completely vaporized, connector too. The Polyphaser had to be removed from the ground bar w/hammer. the equipment (a city agency) was undamaged. The cable will most likely have to be changed as a precaution.
Agreed. From what I have seen they are tuned 462/467 flat there in lies your problem. It's a half Meg out at a minimum and that's not gonna cut it. I have seen some screen shots of properly tuned ones and they seem to be ok but have some power handling issues just an FYI JE
same thing in the commercial world. Difference being that anything out of the box "should" be checked before it goes out the door. I can site many examples of things like this. Big M SLR programed power 55W- reality 49.5-50 on a calibrated Bird watt meter into a calibrated service monitor. Kenwood mobiles out of the box are for the most part pretty on but do require minor tuning depending on Freq, generally the higher you go the lower the power. AT 450 you might get 48-49 but T-band 42-45 just as an example.
Agree here w/Gortex. SWR at the radio before the duplexer should be the same or slightly higher than the SWR looking at the antenna after the duplexer. Your losses "should" be ~25% depending on quality of the filter. (ie) 25w in ~19W out roughly. stay away from that CCC. JE
stay away from those CC duplexers , they are made for a 10mC split not 5. find a celwave or a micro magic here is a pc of 2 bp/br and a br/br duplexers as well as an Isolator and a receive preamp as to losses the br/br small duplexer has an insertion loss of ~1.5 dB max typical when tuned correctly is ~1.1 that would be 20%. In your case that wold be ~5W loss Jeep crawler you should have seen some of the sketchy stuff I had to make work for one reason or another. JE
It also depends on the duplexer itself. They however have to be tuned to a specific frequency. a br/br(notch/notch) will be more "forgiving" than a bp/br(pass/notch) and even that varies manufacture to manufacture. most can ~500kC's, the GMRS "band" is only 175kC's W/that being said a good br/br filter tuned to 462/467. 6375 "should" be able to handle all the GMRS channels w/o any real issues.
it will do the job. comparable to Maxrad /Pctel type antennas. no, apples, oranges. yes, new cable. At 80'-100' depends on your budget. my recommendation would be 1/2" hard line but LMR 400 will suffice and be much easier to work with. I would suggest getting a a more accurate measurement and order it w/connectors installed. JE
Handheld with a PL-259 dummy load still transmits 10+ yards
JohnE replied to WRQV528's question in Technical Discussion
remote base site @300' haat, we practically looked at it. it was an open 20W 800Mc radio. we have never had a faraday cage at the shop. I did do work for a guy who had a nice one though. converted a small walk in freezer w/ grounded coper screen on the full interior and door. mostly did beepers. -
In a word, no. funny story about that. I was tuning up a new channel for a customer on the bench (late 80's crystal TCXO) as they took some time to settle and the deviation had to be set also. radio is into a 100W dummy and was testing Dev on service monitor , boss gets a call that they are hearing everything I'm doing at the base 7 miles away. go figure. -
was thinking tk 840 mobile. TKR 850/ 851 are 40/25 agreed. get a mobile amp 5>50 and be done w/it
you will need TOR low>PTT , RX aud> Mic Hi and as long as the ground is common. That should work but not 100% on it , its been a long time since I did something like this. COR will key anything it hears that breaks squelch. Might need a pot and cap to fine tune the TX audio level. Also as a side note an 840 should do 20W-25 W unless it's turned down
