103
Everything posted by Lscott
After doing some reading I would not recommend a TYT TH-9800 radio for Ham or GMRS. While they are a neat radio they apparently suffer from various issues. One seems to be failure of the audio amp chips from an over voltage condition. I have a buddy and his just had the audio die on one side the other week. See the linked YouTube video for one such failure and how the tech fixed it and added the parts that TYT left out to save money. https://www.youtube.com/watch?v=X9HgrYCAzo8
The never-ending Part 90/95 debate, and my discussion with the FCC
Lscott replied to a topic in FCC Rules Discussion
Here’s one example of an open source codec. https://www.rowetel.com/wordpress/?page_id=452 Note that the open source mode dPMR has bits that tell the RX radio what codec is in use. The mode allows up to 4. One could be an open source version like the above. See attached file. dPMR MoU tech lib Voc Bits V1 (2019).pdf -
I’ve posted this before. You might want to download it for a good read if you haven’t seen it before. GMRS Digital Voice - 20231127.pdf
How can I make my repeater allow APPROVED unit IDs only?
Lscott replied to WRYF747's question in Technical Discussion
I'm on another forum where somebody asked about getting the frequencies used on an NXDN trunking system from just the radio handset. They wanted the frequencies used just to scan. One poster said that's impossible without access to the system key file, available only from the trunking system admin. It just so happened one used radio I purchased came programed from a trunking system. The normal radio software won't read it without the key file. Well, I had a hacked version of the software that allows me to read the radio and save the info as a service file. I posted screen shots of the frequency lists etc. just to make a point that nothing is hack proof or secure as you would assume as far as the trunking info goes. -
What is this dial inside Midland MXT275 circuit board?
Lscott replied to WRVV250's question in Technical Discussion
Yup. Many radios have been wrecked by application of the "Golden Screwdriver". -
How to attract more young people into the Amateur Radio Hobby
Lscott replied to WRUE951's topic in General Discussion
When one of the young generation tells an older person they don’t know what they are talking about and gets reminded that eating Tide-Pods is not a good example of a high IQ. My question to them is what is their favorite flavor of Tide-Pod? -
Well the national organization that represents Hams, ARRL, has its roots in just such an activity. ARRL stands for Amateur Radio Relay League. In the very early days of spark transmitting messages were passed from station to station cross country. That was just about the only way to communicate long distances in those days. Even today there are emergency Net practice sessions on the VHF/UHF Ham bands, and on some HF ones, where one of the activities is traffic passing of messages.
That’s why some expensive high gain repeater antennas have a “down tilt” specification. These antennas are specially designed to direct a bit more of the power downward closer to the antenna site. That improves close in repeater coverage. https://www.repeater-builder.com/antenna/downtilt.html https://www.kpperformance.com/Antenna-Downtilt-A-Practical-Overview.html
Reusing existing (TV?) antennas for base station and/or repeater
Lscott replied to WRZY540's question in Technical Discussion
Ok.- 11 replies
You forgot about the necessity of cutting off those crummy F-connectors, replacing them with “N” type or PL-259, if you can find any that fit that coax size, or finding the correct adapter. I think you’re better off installing the correct antenna and coax and save yourself the extra hassle.- 11 replies
If you're definitely using your GMRS radio in Canada then you should be aware of the Industry Canada, their FCC, rules. They are closely similar to the US FRS rules. Per the Annex E specifications GMRS radios in Canada are restricted to no more than 2 watts ERP, effective radiated power. That's a significant restriction. Canada GMRS-FRS Rules.pdf Canada FRS - GMRS Channels.pdf Canada Annex E - GMRS and FRS.pdf
If you’re going to do any significant driving through the west side of Canada you may run into what are called “radio controlled roads” which are on VHF. That might be more of a use to you than the Canadian version of GMRS. Canada VHF LADD Channel List .pdf
Kenwood TH-D75A Tri-Band Handheld Transceiver with D-STAR and APRS
Lscott replied to WRTT642's topic in Amateur Radio (Ham)
It would be a very good idea to wait a few months on buying a TH-D75A. Let everyone else do the beta testing. By then Kenwood should have a good idea where all the remaining software and hardware bugs are and have a fix for them. I wouldn’t be surprised to see the radio go through several hardware revisions before getting to a stable design. -
There is nothing in the rules that requires this, but it's the general practice. https://www.customsmobile.com/regulations/title47_chapterI-i4_part95_subpartE_section95.1763 A few repeater owners have selected a frequency pair from the 462 and 467 groups that are NOT an exact 5MHz offset. That was done to discourage some users, with fixed programed frequencies in their radios, from accessing the repeater. While that will "tie-up" what amounts to 2 "repeater channels" and may not be well received by other repeater owners it's not illegal under the current GMRS rules. https://wiki.radioreference.com/index.php/Offset Same with tones. A few owners have required the use of MDC to access the repeater in an attempt to limit unauthorized access. Most of the common Chinese radios can do CTCSS or DCS but not MDC, thus cutting them off from the use of the repeater. The are a number of the more expensive new/used commercial grade radios do include MDC functionality other than Motorola. See attached example brochures. https://en.wikipedia.org/wiki/MDC-1200 TK-2360-3360 Brochure.pdf TK-5220_5320 Brochure - 1.pdf NX-1200_1300 Num 1.pdf NX-220_320.pdf
Digital Data on GMRS Mobile (Midland asking FCC for rule change)
Lscott replied to WRUU653's topic in FCC Rules Discussion
Or GMRS users simply don't need the feature enough to bother commenting to the FCC about it. -
It's bad enough people are trying to poke at their vehicle's touch screens, or playing with their smartphones, while driving. Do we really need another distraction for the driver? -
has anyone used a plc to control their repeater?
Lscott replied to WRXH658's topic in General Discussion
You very likely can get a purpose built repeater controller for a lot less money unless you "happen" to have a PLC laying around someplace. Otherwise the cheapest thing you likely can use is like the example linked to below. https://www.robotshop.com/products/ardbox-plc-20-analog-modbus-industrial-arduino-module -
I think if one wanted to know your location in an urban area using an app on the smart phone seems like a better idea. At least the location data can be overlaid directly on a map using a device most people already own. Using an HT or mobile radio alone one would still require some method to plot the GPS location so more hardware would be required anyway. The above point also applies while out "in the woods" too. I guess one would have to store the maps on an external device first then interface the radio to it to plot the GPS location being sent it it. Apparently there are some devices that can do both in one box but they likely aren't cheap. https://g.factoryoutletstore.com/cat/31220/rino-.html -
What is the purpose of GMRS channels 8-14?
Lscott replied to WRZT691's topic in FCC Rules Discussion
The FCC screwed up when they allowed the sale of combination FRS/GMRS radios before the rule changes in 2017. The idea was if one wanted to use the GMRS specific, at the time, channels one would have to get a GMRS license. Well, almost nobody bothered. So, when the rules were changed in 2017 the FCC had to do something about all the existing radios out there. They simply changed the rules to make those combination FRS/GMRS radios FRS only and legal to use as is. However the channels you pointed out sit between the main GMRS repeater input channels, which use a 25KHz channel. The FRS channels, 8-14, where kept at very low power and narrow band since they partially overlap the main GMRS repeater channels. The idea was to minimize the interference they cause. At the time FRS was limited to 0.5 watts and narrow band, 12.5KHz channel, so keeping the restrictions didn't require any changes to existing radios. As you pointed out for FM use they are basically useless. Many GMRS specific radios don't even include them, noticeably on mobile radios. So practically speaking GMRS really has useful access to only 15 channels. You might ask is there something that those channels could be used for? Maybe, but that's a topic for another thread, which if you look you'll find on the forum discussing adding channels to GMRS. FRS-GMRS Channels Layout.pdf -
Have you considered using any of the license free MURS radios? While limited to 2 watts max at VHF they do a bit better in terrain that's a bit hilly and tree covered. https://en.wikipedia.org/wiki/Multi-Use_Radio_Service Some examples of MURS radios. https://www.retevis.com/murs-radios https://www.buytwowayradios.com/business/murs-radios.html There is also a mobile magnet mount antenna that is usable for both GMRS and MURS in case you decide to carry both types. https://dpdproductions.com/products/dual-band-gmrs-murs-mobile-antenna
I checked mine, V4, and the attached photo are they only frequency options shown for the TK-880 mobile radio.
I never claimed it was. The dPMR service in the EU seems to be working out OK so apparently it's very possible to do, share the spectrum. In fact they have TWO digital voice modes, dPMR and DMR. Further on 11M people have used AM and SSB for years and now FM is added to the mix. I don't see any huge crying over that either. I have to agree with those with how annoying a mode like TDMA, which is how DMR operates, with the machine gun like pulsing. I do know that the TDMA nature of the signal is known to cause false opening of the squelch, when using CTSS, on analog radios. It happens on the CCR tri-bander I have in the office I use as a cheap scanner from time to time. The two modes I mentioned in the paper are FDMA, no pulsing noise. I also am NOT advocating using digital voice on repeaters. I would keep those analog only. Analogue and Digital PMR446 Information Sheet.pdf The-effect-on-dPMR-446-of-the-new-digital-license-v3-2019.pdf
Looks like that's were we should start, get the FCC to enforce the rules. The whole point with enabling digital voice, in some limited manner, on GMRS has nothing to do with experimentation or making it a "Ham Lite" type service. It's more about improving the quality of service. As it exists now the general GMRS user really only "practically" use channels 1-7 and 15-22 due to the above restrictions on channels 8-14. The proposal I made in that paper would take the nearly useless narrow band low power interstitial channels and put them to better use. The topic of this thread was more "repeater" channels. While not exactly adding more channels by allowing using digital voice on 8-14 and at a reasonable power, 5 watts in simplex mode, we effectively gain 5 more channels without asking the FCC for more spectrum, which likely won't ever happen. Better than nothing and a kick in the butt from the FCC.
