183
Everything posted by marcspaz
The best antenna for you is going to vary a bit, depending on where you are going to be using the radio and what you want to accomplish. On a vehicle, a 5/8 wave antenna is going to show at least 3dB gain over a 1/4 wave, and at least 1dB of actual gain (depending on design, it can be much higher). This antenna has the least amount of elevation tolerance. So, if you live in a hilly/mountainous area, this may not be the best option, but it would be good in large geographically flat areas. A 1/2 wave doesn't require a ground plane and has about 2.1 dB of gain over a 1/4 wave, but it has no actual gain... its straight break-even. It also has a bit more tolerance to elevation. A 1/4 wave actually has a loss of about 2/10ths of a dB. While it doesn't provide as much range, in hilly or mountainous areas, its going to be the best choice due to the very high elevation tolerance. Based on this, I actually carry a 5/8 wave antenna that is about 32" tall and about 6dB gain, and a 1/4 wave antenna. Then I just swap them on and off the vehicle depending on the terrain I am in and the range needed.
I'm pretty sure your radio/antenna is already grounded. The question you should be asking is if you should have lightning protection. ? Those answers are way more entertaining.
I have no idea what network Garmin uses, so I can't really speak to that. However, my entire radio and IT career has been as successful as it has been because emergency services and government agencies found out the hard way that the hardline internet backbone and satellite communications not only don't have 100% up-time, but also happen to fail at the least convenient times. Also, if you watch the NOAA, NASA and other private space weather agencies, you will here about the outages as well as the predictions for potential outages. Most reports are released for public consumption weekly. Once in a while, something big happens and it makes regular news, like with all the StarLink satellites being damaged a couple of days/weeks ago, due to a massive storm caused by a CME. I think, maybe I am presenting my opinion in a confrontational way. If I have been, I apologize. That is actually a great idea. These are among the best options. I only have the opinion that HF radio is better because the radios are cheaper to buy, are not subject to service blackouts and don't require a paid subscription that expires in order to get help. That said, most people don't want to carry the small lifpo4 battery and a radio if they are on foot and every pound counts. If they wont carry a radio, the ease of something like InReach or PLB is light years ahead of other options and most definitely a great idea.
Have to disagree. We have had massive satellite communications outages (especially GPS related) due to recent CME's sending some nasty space weather our way. One network I am aware of lost 40 of it's 48 satellites in the past month, seriously debilitating the network. I read an article today that there was a massive satellite blackout to systems servicing most of the African continent due to a CME event. In fact Viasat has so many interruptions to service that they have a website dedicated to showing the services current status. Even the new Starlink system has been having outages due to space weather this year. Also, earth surface SatComms is contingent on clear view of an in-network satellite. Garmin has posted on their website that you need a clear view of the entire sky with little or no tree cover, and very heavy, solid tree cover in all directions may prevent successful communications. HF radio is not impacted by things like foliage or partial sky visibility. HF radio is impacted by space weather, but it's only diminished. There is never a blackout of communications using HF. So, in my opinion, if you can... have both. if not, at least have an HF radio. Just because satellite is easier and has more portable bells and whistles, that don't mean it's 100% up-time.
So, just for grins and giggles, I took some readings on one of my antennas... MFJ Analyzer 145.520 = 1.0:1 147.000 = 1.3:1 Nano VNA 145.520 = 1.2:1 147.000 = 1.2:1 Surecom High Power 145.520 = 1.1:1 / 46.07wFwd / 0.131wRev 147.000 = 1.08:1 / 41.22wFwd / 0.061wRev Low Power 145.520 = 1:1 / 5.1wFwd / 0wRev 147.000 = 1:1 / 4.67wFwd / 0wRev If you look at the readings, they are all close enough. The truth is, they may all be correct. It takes different cables and connectors to test with these devices and those numbers will change based on the changing of hardware. Shoot, realistically, just disconnecting and reconnecting the same gear twice could give you these kinds of variations. If we look at the Surecom reading 145.520 = 1.1:1 / 46.07wFwd / 0.131wRev... the reverse power is 0.285% of the forward power. So, if we switch over to 5w of output, I am not shocked the meter is reading a 1:1 SWR, because 0.285% of 5w is too low for the meter to read. Its about 0.014w. the scale on the device doesn't have enough place holders displayed to show the SWR... so it rounds to zero (or 1:1). I still think that TDukes needs to either calibrate the Nano VNA, the Surecom, or both. But for what we do as GMRS users, I think the device is working as intended and is "close enough" to know our stuff isn't going to break. The need to fine tune that last drop of power (maybe 40 miliwatts at 5w scale "if" his VNA is correct) is pointless except as an exercise.
The problem is, tone 11 isn't the same on every FRS/GMRS radio.
I'm not sure what your experience is, but in my experience, all meters must be calibrated. I'm sure you calibrated the Nano VNA per the directions, correct? Otherwise I wouldn't put much value in those readings. Granted, there are some meters that are sold being advertised as calibrated or not user adjustable, but a quality version costs many hundreds of dollars and should still be professionally calibrated regularly. That is just how this stuff works. Don't use it with the Nano VNA at the same time. Take the reading with the VNA and document it. Then take a reading with the Surecom, make a minor adjustment, and then retest. Just repeat that process until your readings match. If you have more than 1 antenna to test with, to ensure they are at least close to the same readings once it's calibrated, that would be a good verification. Edit: I see you're using an MFJ meter, not a Nano VNA... my mistake.
I've mentioned this before... but I may not have explained it correctly. There is likely nothing wrong with the Surecom. It is a device designed to be calibrated by the end user. While many come from the factory pretty close, you likely need to calibrated yours. Just calibrated it against the Nano VNA, if that's what you have, and check it again. Even if it's not dead perfect, it will be close enough.
I got the MFJ version. It's pretty handy if your looking for a quick deployment of a wire vertical. No, the issue is the aluminum. Conductive materials and PVC impact the performance characteristics of small and wire antennas. For example, a wire antenna would short-circuit against the pole and the metal under a small, top mounted antenna could change the shape of the far field lobes, greatly reducing range, changing the resonant frequency and driving up the SWR.
@Borage257 yeah, I wouldn't use that.
Plastic, aluminum or fiberglass? Have to be honest, I like to save money, but I also what my stuff to work when I need it to. If you are using a non-conductive pole (and there is no PVC in it) you can get away with it holding a wire antenna or a small NGP antenna. I would 100% guy it about 5 feet from the bottom so the bottom doesn't kick out and at the very top. I wouldn't make it a permanent fixture, but for mobile/temporary/emcomm, you can probably get away with it.
I could be mistaken, but the person who made that video doesn't seem to understand far-field antenna radiation maps. Not to mention, if you are like me and have a nice tall high-gain antenna on the roof or on a tower, when the wind blows, the antenna is going to sway around a heck of a lot more than factions of a degree... in many cases, several degrees. It does make a difference, but mostly on the fringe of your max range. The longer the distance, the more it makes a difference. I really experience this with my mobile HF radio when I am talking several thousand miles. if I am driving, I may be able to hear someone, but they can't hear me because I'm driving 60 mph and my 86"+ antenna is waving all over the place... impacting the take-off angle. If I pull over and point the truck in the direction of the station I want to talk to (my antenna is in the back of the truck, creating a somewhat directional dipole with the whip and body), I go from the distant station not hearing me at all, to getting a perfect signal report.
I was using the Comet 2x24sr for about a year. I am not surprised to hear your feedback. The antenna sucks. It's a compromise on all bands and wasn't designed to perform well on the 467 MHz range. Comet say the top-end in 465 MHz. Its an 'ok' antenna for close range split duty between Ham and FRS/GMRS if you are actually doing some type of SAR/USAR mission in close proximity on low power, but anything over 2 miles and I just can't get good performance out of it. And I think it's the design, as 462 MHz is at the top of the design scope and 467 MHz isn't even a part of it. I started off with the NMO version. I ended up getting a second one in a UHF mount and it had the same issues.
Agreed. Many years ago I had a 5 foot fence pipe I was using as an extension, trying to avoid buying "mast" pipe. It was literally just holding the weight of the antenna and transmission line. We had a about a 10-12 mph wind gust and the pipe folded. Totaled a $250 portable mast and a $300 antenna. The $100 I saved cost me $550. I have a satellite dish mount on the roof of the house, that I have my repeater antenna mounted to. So far, I has survived sustained 60+ mph wind and a few 90+ mph gusts.
It's possible, but not cost effective. A good quality commercial UHF amp is about $1,000 on the low side, and you may need to either attenuate the the repeater output for a 1w-5w input of a 50w amp or attenuate the amp output, as most commercial amps I have seen that take 10w in, normally make 100w out. After buying an amp, power supply, attenuator, and associated cables and misc. supplies to make it work, it would definitely be way more money than just buying a Quantar repeater for ~$1,200. Also, as others mentioned, I am not aware of any type approved amplifiers... so you run the risk of a "no-no" letter from the FCC, if they were to check your repeater site.
Agreed. Most of them are good ideas, but lack of standards makes it impossible for someone to pick the right solution. I would recommend portable HF radios first, and satellite communications second. Or both, if you can.
I don't think Sad Ham means what you think it means. Alex isn't a sad ham... he's a decent guy and so is Randy. The thing is Randy @OffRoaderX has been correct with most of his statements and he has some pretty solid opinions that I haven't really been able to rebut. However, Randy (or at least his online personality) also doesn't care if your feelings are hurt by the truth or his opinions, and that upsets some people... which I find THAT ironic! LoL
Not necessarily a taller antenna, but rather an antenna with a decent amount of gain (which are typically taller than a 1/4 wave). The terrain, elevation changes and who you are talking to in relation to those conditions will determine what the best antenna for you would be. Gain antennas are not the best choice in very hilly or mountainous areas, but are a great choice for relatively flat areas.
Picket fencing is not caused by the antenna movement. It's caused by characteristics of the terrain and the speed of the vehicle, compared to where the receiver/repeater is. Weaker signals are more susceptible to it because there is not enough energy to scatter enough signal to overcome shadowing from trees and buildings. It's a power/line of sight issue.
Swing and a miss. LoL
I would say no. There may be some lopsided power and performance stopping it, even if the transmitter wattage is the same. For instance... if the repeater has a full 50w going into the antenna (say a tower mounted repeater) and it has an antenna with a 10dB gain, it will have an effective radiated output of 500w. If your mobile is only putting out 30w-35w due to installation limits and you have a no-gain antenna, like a 1/4 wave, your only putting out 30w-35w. Even with the high gain antenna at the repeater site... there is no guarantee you are going to get picked-up by the repeater. Especially if the repeater has a poor receiver or is being de-sensed by some other radio on the tower causing interference around it. If you can drive closer to the tower to confirm, that would be your best bet. If you get within 10-15 nautical miles and it still doesn't work, you may be doing something wrong or have a problem.
I'm seeing the same thing. You may need to email the owner and ask them what it is. Good point. I forgot some meters need at least 5w to give any reverse reading.
It's actually fantastic. Anything under 1.5 is great. Over time, I would keep an eye on it, is all. Make sure it doesn't creep up on you. 2:1 or less is good, less than 3:1 is safe to use but not ideal. 3:1 or higher and I would stop using it until its resolved. The attic install may be where the shift is coming from. If there is something metal within 2 or 3 feet that is larger than about 5"-6", it may be giving you a bit of resonance. Not a big deal though. As I mention, just make sure it doesn't get worse over time.
Welcome to GMRS and the forum! There shouldn't be any 'noticeable' change to RF performance. Any measurable notice will likely be for the better. Just swapping radios should not impact your SWR or antenna performance. The KG-1000G is a nicer radio with regard to features and both 50x1's I had were under powered. They ran a tad hot too. Just my opinion, the KG-1000G sounds a bit nicer on the other end, too. What repeater are you looking at? We can look at the listing for you and see if it appears differently. Keep in mind that you have to sign-in to https://mygmrs.com/ separately from https://forums.mygmrs.com/, otherwise the tones for private machines needing approval to use, will not have the tone displayed. However, after you login, they should be listed. Your SWR should not change with increase in power. If it does, something is wrong with your system. Either a bad antenna, bad cable or incorrect length of cable, bad connectors, etc. You may even have water inside the coax.
I mean.... it should work as long as the UV-9G supports split tones (I don't know if it does), but its more complicated than it needs to be. A more simple solution (more likely to work) would be to set the tone mode to Tone, and set just the Tone value to 88.5 (assuming that's the correct tone), ignoring the ToneSql field.
