185
Everything posted by marcspaz
Welcome! Where abouts are you? I am in NOVA / Prince William.
Thankfully I have not. That would be one expensive tree trim, that's for sure. LoL
I was playing out in the woods today, supporting a 12k race, and I had this monster in the truck to extend range. I know some of you have some portable setups. I figured it would be fun to share them here. Especially if it's a bit unconventional. Whatcha got?
Not until just now. LOL Seriously, when I made the cables, I looked and didn't see anything horrible. I still use all of the cables. So, I dropped two of them from the gear for a few minutes and put them on the analyzer. The complete cables are almost identical. The values are so close and near where they should be, that for what we do in GMRS, it's not worth calculating reflective coefficients. UHF Connector (@ 465MHz) / N Connector (@ 465MHz) Reactance = 19.2 ohms / 28.3 ohms Resistance = 50.5 ohms / 49.55 ohms Inductance = 45 nH / 45 nH Capacitance = 16.4 pF / 21.4 pF
@Elkhunter521, the rain finally stopped, so I was able to take some pictures. I figured I would provide details for the hood mount, both for you as well as other Jeep JL Wrangler and JT Gladiator owners... but I don't currently have access to a JL Wrangler to get pictures of the swing gate routing. This is just the hood mount. Possibly someone who has a Wrangler (2018 JL/U to current) who has run the cables through the inside of the swing gate can get some quick pictures for you. My apologies if this is a bit long. I'll try to let the pictures do the talking. NOTE: You can do this on either side. I selected the driver's side because it keeps the GMRS radio antenna away from my factory FM radio antenna, and away from the but-plate of my farm jack. First, make sure the mount is at least 7 inches away from the windshield, so the A-pillar has minimal impact on performance (if any). On our generation, that corner cap is plastic. I put mine where I did since I have metal reflective surface from the light bar mount. However, if you have trouble getting a good SWR in the same location as where mine is, push it forward so there is 7 inches of actual hood, trailing the antenna down the hood line (about 14-15 inches forward of the windshield). This will be ideal for a 1/4 wave reflection. I ran the wire so I had plenty of room to open the hood and have cable to spare. It is literally just the cables natural spring tension holding it in place. You are going to want to route the antenna cable behind the fender, following any factory cables that are there. However, I ran mine under the cosmetic cover of the windshield seal on top of the tub, instead of cutting the seal where the factory wires go inside the tub. So, on the other side of the fender, have the cable come out into the area of the door jam. Use a trim panel removal tool to remove the two push pins in the seal and the side panel of the dash, Lift the bottom of the seal out, away from the body, to expose a gap between the windshield and the tub. There is a second, main seal, and some foam rubber you want to put the cable in between. Once it is in place, lower the cosmetic flap back into position and put the two pushpins back. If the cable is in the correct location and placed correctly, the rubber should go back into place with no resistance and sit flat, as it did before you put the cable in place. Hope this helps.
You can definitely use the mount style that Randy showed on the swing gate or the lip mount on the hood, like I have. You can mount all of it on the swing gate too, but I went with the hood for GMRS and swing gate for the CB to keep them far enough apart that one radio wouldn't blow-out the front end of the other. The swing gate is a good place for the higher drag and heavier CB antenna because is more sturdy than the hood. This is my last Wrangler... I'll take some new pictures of the Gladiator in the morning so you can see the cabling option from the hood. Been raining all afternoon/night here. Randy pulled his cable through the seals, which works fine, I did that for a bit with no leaks. If you want to hide the cables (which eventually I did), you can run the antenna line inside the swing gate and inside the fabric tube at the hinge, too.
Issue resolved.
What CB antenna are you trying to use? Something like a 104" whip or a Firestick, or something more like a Willson 1000/5000? I can share some detailed images of how my Gladiator's GMRS is setup (would be the same for the Wrangler). I used a lip mount on the hood and it works fantastic. For the CB, i would recommend a 104" whip and a heavy duty stud mount that will bolt to the swing gate. It will require running a ground wire to the swing gate and the mount for best performance. Other antenna styles haven't worked for me in the past, on the Wrangler.
I can't really answer the tuning question. I'm not familiar with that antenna... though the adjustment sounds like it would be okay. I can tell you that there is nothing to be concerned about with the camera tripod mount. I used to do it all the time and performance was not impacted. If you take it outside, just make sure you hang a sandbag from it so the wind doesn't blow it over.
I have never owned one... so I did not know this. I am really surprised they have people adjusting them... unless the target customer is more technical rather than Joe Q. Homeowner.
Never mind. I'm a dumbass. ----------------------------- I have a question... why are you going to try to tuning it? It's a stacked 5 phase element high gain antenna with the center frequency being very close to GMRS frequencies. Due to being a stacked phased element antenna (5-1/2l), if you cut the top or bottom, you are only adjusting one element and throwing the phasing completely out of whack, causing massive issues with receive and transmit, regardless of what the SWR meter says. You can't even adjust all 5 elements because the LC network of the antenna is tuned for factory resonance. I would just leave it alone.
Oh, wow! Yeah, I did not see that post. That seems very sketchy, even if it's a private business. I fully agree with you in that context... I appreciate the info. No worries. I'm glad we were able to figure out the disconnect. It was a harmless mix-up on both our parts. I'm glad everything stayed civil while we discussed the topic. I know it seems like a strange thing to say, but that doesn't happen often when people are in disagreement on the internet (pretty sure I am guilty of that myself, recently) . It makes it much easier to continue to enjoy the conversation.
- 97 replies
- repeaters
- repeater build
(and 1 more)
Tagged with:
@WRKC935, I think I am missing something. You keep mentioning something the OP wrote, but I don't think I am reading something correctly. What post are you referring to? Also, you keep implying that the governments aren't allowed to integrate ARES/RACES into their emergency response plan, provide hardware, resources or access to resource. However, that is not the case. The process that is in place that allows ARES/RACES to exist and function along side the government is codified in many states Also, ARES/RACES gets its jurisdiction/authorization directly from the the FCC under the Part 97 rules. We are individually federally certified by FEMA and DHS as well. We train side by side with federal, state and local government. This isn't some setup where hams just kinda BS their way into a government Emergency Management team. As far as incidents happening, I can tell you that my team has been activated several times since I have been working with ARES/RACES. There are several states that I have worked in where we needed portable repeaters to service an affected area. We also need things like NVIS to talk from an affected area to 100+ miles away, to the State Emergency Operation Center, as part of the logistics branch of the Incident Response team. We cross technological boundaries, setting up portable networks for data, video and voice traffic for all agencies in a multi-agency response, allowing everyone to have common platforms. The stuff we do (ARES/RACES in conjunction with local, state and federal government) is 100% legal, above board, and just as accountable to the People as the government agencies we serve. In fact, the Shared Resources High Frequency Radio Program (which incorporates non-government entities into government communications operations) was approved by Ronald Reagan and other leadership in the Executive Office of the President in 1988. My team in Virginia even trains as often as 6 times a year with the US Marine Corps. Unless I am just completely misreading your posts, that's why I keep disagreeing with what you're writing.
- 97 replies
- repeaters
- repeater build
(and 1 more)
Tagged with:
Okay... I'll rephrase. The two groups that founded and drove ORI are now both defunct. I will definitely agree that there are owners who still honor the spirit of ORI, for sure, but I said it failed because the 2 groups are gone and no one is formally driving the initiative. Hopefully that makes a bit more sense.
- 97 replies
- repeaters
- repeater build
(and 1 more)
Tagged with:
It's called the Open Repeater Initiative. It failed. There was a nationwide group of repeater owners who participated with the Open Repeater Initiative to set their ch20 pair (462.675/467.675) to use tone 141.3 (known as 4a). The idea was, to make the repeater open to the traveling public through common knowledge. If you found a repeater on the rCH 20 pair with a 4a PL, the assumption was to be that you don't need special permission to use that repeater.
- 97 replies
- repeaters
- repeater build
(and 1 more)
Tagged with:
Did the vehicle need to be jump-started or did the battery deplete to below 11.8 volts? Other recommendations above are good, too.
would this work as an antenna tower? Pros & cons
marcspaz replied to WRPQ991's topic in Equipment Reviews
I actually use a wide footprint to tolerate high winds. You can bring them in and reduce the footprint, but it will reduce total tolerated wind speeds. There is some math that can be done to find the critical angle if you want to go that route. I don't have any issues with a ground plane. All of my vertical antennas have built-in ground planes in the mount or are half wave antennas that don't need a ground plane. So, the actual ground quality doesn't matter. It does play in if you try to use a dipole for HF, though. I have seen some creative engineering... and I aways ask "if it works, was it really a bad idea?" LOL Yeah, I was thinking pulling the seat and putting a short mast (5', maybe) and rotor would be good. Not to mention you can climb up there to work on it easily, which is awesome. -
That's a good looking tower. Have to be honest. I have access to a couple of commercial towers at 300'+ and at high ASL locations, too... but I still get jealous. I wish I had the land and the money to put one up behind my house. LOL Not gonna deny corruption exist, but in your previous post, you make it sound like corruption is SOP for Hams and government relationships.
- 97 replies
- repeaters
- repeater build
(and 1 more)
Tagged with:
@WRKC935 not trying to start an argument... but It will probably turn into one. I don't think any of what you wrote is even close to accurate nor good advice. Nothing says any government agency must enter into a contract or MOU or deny entering into a contract or MOU with anyone. The pricing method you listed on tower leases is completely wrong. Most governemnt agencies already charge to have Amateur Radio towers or equipment on government property unless there is an MOU or contract to support that agency and those agreements includes land/property use. I can promise you that there is ZERO chance the owner or management team (if government agency) of a water tower doesn't know what Hams are doing on their property. Public Works facilities are highly monitored and heavily restrict access. Government agencies, public works, hospitals, etc., don't just let you claim to be ARES/RACES and let you put up whatever you want. There must be proof of association, a contract or MOU to provide a specific service must be executed. Training and testing will be conducted regularly. Depending on the agency, people involved need to get cleared for a Public Trust or possibly some type of addition security clearance, etc. I think this gets to the root of your post. The reality is that when no one else can communicate, Hams can, and that is why the government commits to MOU's and contracts relating to training and support. Thankfully, Honor has its privilege. My guess based on all the rest of your post is that you're jealous?
- 97 replies
- repeaters
- repeater build
(and 1 more)
Tagged with:
Using CHIRP to enter repeater frequency?
marcspaz replied to bfn5005's question in Technical Discussion
You can't put the number in both unless you set it to cross, which really isn't needed. If you only want to hear repeater traffic, just set the type to TSQL and add the number to the ToneSQL field. If you want to be able to hear everyone on the channel, including simplex operators, set the type to Tone and put the number in the Tone field. -
If you just stick it in a tripod and don't use guys, in low/zero wind it will hold about 5 lbs max at full extension. It will not hold much weight at all. In fact, I was up on Flagpole Knob when some 40 mph winds came through and damn near folded it in half. Now, if its guyed with a good tripod, It will easily hold 25-30 lbs. I use 3 tiers of guys with one set at the top 5 inches. The guys keep the mast straight under the load for max weight capacity. I have had my 10' vertical in 80-90 mph winds. The top of the antenna was moving all over, the the mast didn't budge. The two heaviest loads I have run while fully extended is (1.) a mono-band 20m hex beam with thrust bearings and a rotor at the base, and (2.) a 10' tall 2m repeater antenna, 20m dipole and an 80m inverted V with a balun and choke. That second setup was in a massive overnight snow storm we had during Winter Field Day a few years ago. -
Wow! That's actually really neat... but I personally wouldn't spend that much. The platform is only 17' high. The shooting rail is the part that is at 20', and the rail doesn't look like it would hold much weight. You will almost double your range on flat terrain, but we are talking about going from 3.1 miles to 5.9 miles. I bought this instead.... https://mfjenterprises.com/products/mfj-1906h?_pos=25&_sid=bfd1eb1e0&_ss=r I get about a 9 to 10 mile radius (in flat/level terrain) with my antenna on this. A tripod, ground stakes and guy lines, I spent less than $280. I designed it to be portable, but it can be a permanent setup with zero concerns... in fact, right now and for the past 3-4 months, it's actually behind my house in the woods being used to hold up my 80 meter HF antenna.
