marcspaz
    183
Everything posted by marcspaz
  1. I wish we all lived closer. I would love to sit down and chat with many of you. There is a lot of knowledge and experience in this group. I would definitely bring some doughnuts.
  2. That is the most politely anyone has ever told me that I'm full of crap. LOL
  3. If I make a mistake, please let me know. I do this stuff all day as a professional and sometimes the brain gets fried. Especially at 12:00 AM.
  4. You are correct an I will correct it. Gain factor of an isotropic antenna is 1.0, not one BD... typed a lot. type-os happen. You guys are killing me, though. I specifically said I didn't want to science it up so I didn't confuse people. SMH Explain stuff like a little kid is reading it so people who have no idea what is being discussed can at least comprehend the general concept. All that stuff you guys posted is wasted on me. I already know it. The target audience is not going to have a clue what you wrote means. EDIT: That's not true... what I described about the radiation pattern and its general shape as gain increases is correct. I buggered a type-o. That doesn't make the rest explanation of incorrect.
  5. That stinks... I have been making cables for 35 years. Always do them by hand with a straight razor. Make sure its sharp so you need minimal pressure and you will never cut the shield or center lead by mistake. The only time I use a tool is when I strip very thin cables that I can hold with needle nose pliers and wire strippers like the one in the picture. And I don't bother setting the guide stop. Again, just make sure they are sharp and use light pressure to squeeze and twist and you are good to go.
  6. Good point. I dont have an NMO mount on my vehicles and I don't have a UHF 1/4 wave antenna. Otherwise I would redo the test to see the difference. That would be another point of consideration for antenna tuning as well.
  7. Actually, its a type-A to so239. Some of the wavering could have been from the cheap cable and mag mounted. My analyzer doesn't read cable impedance or capacitance on UHV, so we can't see what's happening on that side of things.
  8. That is kind of surprising. The Wilson antennas are typically really good. Any chance you have access to a 108" whip to test with? It may be worth it, if you can borrow one I went from a Firestick to a Wilson 1000 and jumped from 2-3 miles to about 8.5 miles. When I switched to a 114" whip, my range jumped to 18-20 miles reliably... 26 miles on the ragged edge and the occasional 40+ mile contact, depending on my elevation and the other station.
  9. Are you using a Firestick?
  10. This is the other video... hopefully this will help. https://www.youtube.com/watch?v=P5GiPLzVzbg
  11. Hey folks... I have been seeing a lot of antenna related posts lately. Some info I have read lead me to create this post. I want to try to help people understand design types and how antenna SWR and Gain are impacted. I am not going to get too technical, because I don't want new people to feel lost or leave with more questions than answers. As an FYI, while the concepts apply to all antenna types, I will be focusing on vertical antennas, such as what we use on our vehicles. First, lets discuss basic antenna standards and why antenna length matters. The best way to describe how basic antenna length is relevant, is by comparing an antenna to a speaker. Pretty much everyone understands that a speaker vibrates to make noise. We also understand that small speakers do a better job at making very high frequency sounds (tweeters) and really big speakers are better for making very low frequency sounds (like a sub-woofer). Antennas are the same way. The lower in frequency, the bigger (or longer) the antenna. The reason for this is because, like a speaker, antennas resonate (or vibrate) the best at one very specific frequency. As you go higher or lower in frequency, you are moving away from the antennas resonant frequency This becomes important for several reasons. One is because the closer the antenna's resonate frequency is to the frequency you want to transmit on or receive on, the more range and fidelity you get. Another reason is because the energy that gets sent to the antenna must go somewhere. If the antenna is not at the correct length to vibrate at the desired frequency, that energy gets wasted by being "reflected" back into transmitters, as well as desensitizing receivers. Any energy that gets reflected back into the radio is typically identified by the Standing Wave Ratio (SWR) or the ratio of transmitted (forward) energy vs. reflected (reverse) energy. Here is why we watch SWR. If your transmitter is putting out 50 watts, and your meter says you have an SWR of 1.7:1, that means only 45 watts of energy leaves the antenna and 5 watts goes back into the transmitter. A high SWR not only causes power loss, but it also generates heat as well as applying reverse electrical energy to the parts. If enough of a percentage gets reflected back into the transmitter, it breaks. It is very well documented that with the current technology we have, the threshold is an SWR of about 3.0:1. So, now that we understand, on a very basic level, why antennas need to be a specific length to work the best, and also have a basic understanding of what SWR is, lets discuss antenna design. So, what's the standard? An isotropic antenna. This is a theoretical antenna that radiates equally in all directions with the same intensity. Basically, a perfect sphere. The antenna is said to have a power gain of 1 in the spherical space all around it and has an efficiency of 100%. The concept of an isotropic antenna is often used as a reference antenna for the antenna gain. What is antenna gain? Glad you asked! There is a lot of science behind that... so I am not going to bore you with science. Instead, lets talk about food! Everyone loves food and its pretty easy to understand. So, the concept of gain is this... you only have 100% of your energy available. There is no such thing as an antenna magically giving you more power. You know the perfect sphere radiation pattern mentioned earlier... well in the real world, the closet we have ever come to creating that, actually looks more like a doughnut. Imagine a perfect doughnut. Sounds yummy right? Well, you only have 100% of the doughnut. What do you do if you want the doughnut to be wider, say... to fill a box better from side to side? I mean, its a whole doughnut. Easy... you squish it from the top and bottom. Then the doughnut gets shorter from top to bottom, but the food has to go somewhere. So, it spreads out wider or "gains" width in sacrifice of height. Well the more you squeeze from the top and bottom, the wider it gets, but loses height until the doughnut is perfectly flat and the 100% of the doughnut as been spread as far as possible. The squished doughnut thing makes sense, right? Antennas that have "gain" do the same thing. They squish the radio energy doughnut, forcing it to be wider to cover more distance, but at the sacrifice of signal height. This means that while you can transmit and receive further side to side, you lose elevation. Lets imagine you are at the bottom of a hill and your buddy is at the top. If you don't squish the doughnut, he can hear you because the doughnut is at its full height. But if you squish the doughnut, people further away at your level will now hear you, but your buddy who is very close at the top of the hill will not. So, gain has a trade-off. If you live in a hilly or mountainous area, you may want to avoid high gain antennas, so as your elevation changes, you are less likely to lose touch with someone. Compare that to being on the water, in flat(ish) desert or talking aircraft to aircraft, you may want a very high gain antenna, because there will be no significant elevation differences. Now, from here, we could talk about the benefits of stacked phase element antennas, takeoff angles and a bunch of other stuff. However, unless you have a more advanced understanding of antenna propagation and design, and plan on getting into some high-tech stuff, it will likely cause more confusion. Not to mention, for what we are doing... those items are almost not relevant when it comes to helping you pick the correct antenna for your application. So, let talk about how gain and SWR can really be confusing and how numbers can trick you into making a mistake. Remember when we discussed antennas needing to be a specific length to resonate at the desired frequency? Well, many high gain designs cause the antenna to properly resonate at only small segments of the frequency spectrum. Basically, what these means is (as an example) instead of being resonant and having good SWR across 100 megahertz, the antenna design may cause the antenna to only be resonant and have proper SWR at 10 small groups of frequencies inside that same 100 megahertz range. Watch the two videos linked below for a better understanding. In the first video, I have a Diamond NR7900A mobile antenna. It has 3.7db gain on VHF in the 140MHz-160MHz range, and 6.4db gain on UHF in the range of about 440MHz-500MHz. You will see that while measuring the SWR (or the antenna and cable resonance) you will see that in the VHF segment, the SWR varies somewhat quickly, but only has a single swing, from high to low and back to high inside of about 20MHz. When I switch to UHF and test the higher gain portion of the antenna, you will see the the SWR bounce up and down a few times as I sweep about 30MHz. This shows that the higher the gain, the more the antenna design may actually make it so the antenna is not usable on your desired frequency. Of course this all varies by brand and model, but the principle is still universally true. https://www.youtube.com/watch?v=Rh6w46VM_Ng Now, in this second video, we are looking at a UHF 1/4 wave antenna. This antenna is considered to have a gain factor of 1, and any number times 1 equals itself... so effectively, no gain. You can see that we sweep over 50MHz and while the SWR wavers a little, the SWR is stable compared to the high gain antenna and 100% safely usable through the whole spectrum, never going over 1.4:1 from 440MHz to 470MHz. Again, reinforcing the idea that the closer the antenna is to the desired resonant frequency and the less you squish the doughnut, the broader the usable frequency range will be, the broader the geographical coverage will be, the less risk of losing power due to poor SWR, and less risk of damaging your transmitter. https://www.youtube.com/watch?v=P5GiPLzVzbg So, to wrap this up, I want to discuss antenna tuning. Some antennas may need to be cut to the proper length to resonate on the desired frequencies. This is typically done with antennas that either have no loading coils (1/4, 5/8, 1/2, 7/8 wave length antennas for example) as well as some bottom loaded antennas. A bottom loaded antenna is an antenna that has a whip that is not the correct physical length to be resonant on a desired frequency, but the coil of wire on the bottom makes the antenna electrically the correct length. General speaking, for VHF and UHF, I recommend staying away from antennas with coils in them if they have been physically shortened for looks/clearance reasons. These antenna work, but are not very good performers. That said, there are some antennas that are "pre-tuned" at the factory to perform correctly in the indicated frequency range. These are typically gain antennas that have a collection of coils and capacitors on the antenna to help create the phasing and properly stack the elements. These are referred to as LC networked antennas. If you have an antenna that has stacked phasing and/or LC networks and you can't get a good SWR... unless the manufacturer provides directions on how to properly do so, do NOT trim the antenna to try to achieve the proper resonance, as you will only damage the antenna. The coils, capacitors and whip elements are precisely cut to work together. If you do not get a good SWR, either you need to pick a new location to install the antenna, the antenna is not properly grounded or the antenna is damage and should be replaced. If you do trim a stacked phasing and/or LC network antenna, in most occasions, the antenna never gets to the proper length regardless of how much you cut the whip and you end up tossing the antenna in the trash. If you get it tuned to a target frequency, it's usable bandwidth will be so small that the antenna will not have any real value. I have seen some people try to tune high-gain antennas, get them tuned to about 1.7:1 or even 1.9:1 and as soon as they tune 10KHz in one direction or another the SWR skyrockets. I hope this helps with some of the antenna questions.
  12. This will give you an idea about typical usable bandwidth of a stacked phase dual-band VHF/UHF antennas. I will shoot another video with a single band 5/8 wave a little later, so you can see the differences. This is a Diamond NR7900A 2m/70cm. https://www.diamondantenna.net/nr7900a.html https://youtu.be/Rh6w46VM_Ng
  13. Comet CA-2x4SR dual-band antenna has a capacitance hat to tune it for GMRS simplex frequencies. It works really well on the FRS and repeater frequencies too. I have tried a dozen or more antennas. For high gain and solid range, it can't be beat, in my opinion. 6.2 db gain, 40" tall so it works with a mag mount, and rated for 150 watts if you want to use it for other UHF and VHF applications.
  14. Honestly... 6 miles is not good, at all. You have a massive elevation advantage going everywhere but south. And you should still be able to get 6-8 miles south while barefoot. There is only about 400 feet of elevation difference going 20+ miles in every direction but south. Unless there is something I'm missing, 12.5w SSB, you should be able to talk north almost all the way to the shore line... out to Buffalo to the west and at least 20 miles or more to the east.
  15. There is a guy I know that puts "swing kits" in radios and you are right.. the SSB never works when he is done. But... I thought OP said it was turned down to 2.5 wattsto drive the amp. I have to re-read it. I'll tell you this, anyone running a de-tuned radio to accommodate their amp, likely has a home made amp done by guys who think/claim they are experts, but have no idea how to build a filter or ALC circuit. You open the box and there are heat syncs, a few Toshiba PAs and the few parts needed to make the PAs work... and that's it. Best part of the post. I LoL.
  16. Hmm nice performing radio, but I'm not sure if the AM and SSB power are separate. I would gi e the shop a call and ask if SSB is still at the factory settings... assuming you don't feel like spending money on a meter for a one-time use.
  17. Are you running a modded galaxy? Those are fantastic and have a lot of potential. If so, the AM and SSB power are adjusted separately, so the SSB side should still be at 12.5w. The DX 44 HP goes to 40w bone stock and some models go to 100w. The export guys have it made with their CBs. The FCC should just let US operators use amps, since there are no emergency services down there anymore.
  18. The MFJ-1702C could be more of a problem than anything. It has a center-off position that sends the connections to ground, for lightning protection. Forget to turn that switch all the way to one side or another just once and your radio is toast.
  19. I guess that all goes back to the layman's definition of integrity being, doing the right thing, even when no one is looking. As gentlemen and ladies, we all agreed to play by the rules. That's a huge plus I see to communities like ours. Most of us are here because we want to do the right thing. Many of us have been down the other path and don't like were it leads.
  20. I agree with BoxCar... when operating on FRS frequencies, with an FRS compliant radio, you adhere to FRS rules... no ID required. The only problem I see is, the radio is not certified for FRS use, nor can it be due to the removable antenna. So, by the legal letter of the law, you are using GMRS hardware (not FRS compliant hardware) therefore you are using GMRS privileges. You need to adhere to the requirements for GMRS use, not FRS. On the flipside of that, I would never advocate that you flat-out break the law... but the FCC doesn't walk around inspecting radios while people are doing whatever they are doing. In fact, I filed several complaints with the FCC in the past few years, about grossly illegal activity on amateur radio frequency, handing them all of the evidence and proof of who was doing it and the FCC basically ignored everything I sent. They sent me an email saying they would look into it, and nothing happened.
  21. Here's the thing, for some of us, its entertainment or emergency communications. However, my family use our radios around the house while working in the yard, while racing my car to talk to my corner spotters and crew from the track, while fishing, 4wheeling, hiking, spending time at the park, caravaning somewhere with multiple vehicles, and on and on. The list of things in our lives that we can integrate radio for the better is endless. Therefore the "image" to draw people in are endless. The best way to advertise isn't with someone specific to radio or activities you can improve with radio, but rather, find a common image that will have the most amount of impact on the heartstrings of your target demographic. The radio really has nothing to do with it. People buy toys and non-essential products based on emotions, using how they feel to justify spending the time, money and effort. That is... if that's really what the end goal is. If you're trying to sell radios, learn your target demographic. Asking folks like us is going to be a mixed bag of tricks that's just going to cloud that even more.
  22. Awesome! Congratulations! You are going to love it. I talk to people around the planet, daily. The entertainment never gets old.
  23. For me, it was a collection of conditions. My family spends a significant amount of time in rural and undeveloped areas with no cellular infrastructure. Being able to have some form of communication while on foot or mobile, without everyone getting an amateur radio license, was a must. Especially when we tend to move about in separate groups. Also, somewhat in the same category, I do things like 4-wheeling and other outdoor activities. Many of my friends use FRS and GMRS to communicate while spending time outside. It seems to be going more mainstream. Then, of course, there is always a risk of infrastructure failure. I needed a way for my wife to reach me while I am out of the house, if an emergency occurs. She had her amateur radio license, but it long expired and she is not interested in getting it again. There are several public GMRS repeaters around me that run on emergency power, if needed. So, it was just an obvious and affordable option for our needs.
  24. Yes that is normal. Tone is tone encoding to open the squelch on the repeater, but it doesn't require you to receive a tone to open your squelch, which means you can hear everyone on that frequency. TSQL is tone encoding to open the squelch on the repeater AND your radio. So you will only hear station that have the proper tone encoding. The only way both fields will allow a value is if you use cross, which allows for split tones.
