kidphc
    16
Everything posted by kidphc
  1. Thought it was a rumor on reddit. They have been trying to sell. I really thought dxenginnering was going to pick them up. Sent from my SM-S901U using Tapatalk
  2. If the repeate comes up and you still can't make it. Might be worth finding a high peak closer to the repeater. Especially, with a ht. Not all repeaters are created equal. Sent from my SM-S901U using Tapatalk
  3. You do not have to have a tone on receive. Since the tones block incomming messages that don't have matching tones. You would hear it if no tones are set on your radio, even if they have tones enabled. If you don't have tones on receive you will hear all transmissions on that frequency. No tones on encode shouldn't not be done (most repeaters have tones on input). So that it will ignore and not repeat any transmission that don't have matching tones. To complicate things more, there is cross repeater talk as well as repeaters with multiple tones. Sent from my SM-S901U using Tapatalk
  4. Simple answer yes. You encode a transmission and decode on reception. Is a simple way of thinking of it. Sent from my SM-S901U using Tapatalk
  5. Shouldn't 2 different frequency segments. Guess you are going to have to send it and find out. But not 100% since non adjacent frequencies can still wipe each other out with enough power, suppression of harmonics. Especially, with antennas less then 1/2 wave length away (longest wavelength/ frequency). Sent from my SM-S901U using Tapatalk
  6. For my 70cm gmrs hts. I usually use what is supplied with them. Aka my motorola xts5ks. For my ham radios (2m/70cm/aprs and gmrs) I have found stocks antennas are ok. But the stock rubber duck antennas did the best job trying go across such a wide bandwidth. Even the signal stick was barely an improvement on the 878uv, caused intermod issued with the Feng bf8hp for me at least. For my gmrs hts I usually swap them for Nagoya 701c and they perform admirably. The harris xg100m. The long high gain antenna works the best. It's tri band and is adequate. Real short, stock rubber ducks work fine. If it is a gmrs specific ht. I found the Nagoya 701c a good antenna. Sent from my SM-S901U using Tapatalk
  7. Usually, the seller has the feature sets or options that the radio has. Sometimes they will have a screen capture of what the programming software read or you can inquire to the seller about said information. Sent from my SM-S901U using Tapatalk
  8. There are some videos on youtube. Which are really good at teaching things like programming p25 in astro25. You are going to want to narrow down your radio choices first. Each software is different and has different quirks. Generally, they program similarly to any other radio. Just with different terms for the same thing. Unfortunately some software like Harris rpm. There aren't videos, they kinda expect you to already know or attend harris training. Then it's a matter of playing with the software and figuring it out. For Kenwood, you have Lscott [emoji14] I for the most part think the Motorola software is one of the easiest, since it's straight forward, well for me at least. F harris.. nac code says its hex in software , but it isn't actually using hex its decimal...lol Sent from my SM-S901U using Tapatalk
  9. Stand corrected then. I don't load encryption keys on my radios. All my hexedits and feature additions are done by handful of friends. They are the ones that actually know the intricacies. Sent from my SM-S901U using Tapatalk
  10. Real high level. Dmr = mototurbo timeslot digital (one of the better option for businesses requiring encryption. No encryption for amateur usage but encryption is ok for lmr usage Ysf = yeasu fusion proprietary c4fm digital. Negative it is only available to yeasu radios in native format. No encryption allowed. Wirex = ysf with internet connectivity Apco p25= c4fm (not the same as ysf and not compatible, but same technology) standardized for public safety. This can be analog. It can also be conventional p25 (used in simplex/with a repeater). Trunked you have a control frequency that tells the radios what frequency and talkgroup that can be used. It usually requires multiple frequencies. Benefit with digital with encryption. Is even if someone has the equipment, and the frequency and all the settings. That theu can't listen onto encrypted channels without the keys. It does require additional cost with a xtl5k/xts5k you will need a key loader like a motorola kvl, the cables and keys and entitlement enabled. Analog is always easier to work on then digital and usually cheaper. Pic of a buddies kvl3000 I was working. Attached below.http://files.mygmrs.com/forums/monthly_2024_04/FB_IMG_1713707770436.thumb.jpg.10a150798755507a315db1f20c958a8a.jpg Sent from my SM-S901U using Tapatalk
  11. It's single banded. Vhf, uhf r1, uhf r2.. etc. If you want to do say vhf and uhf. To stay motorola you will need to dual brick or pay for a relatively rare apx7500 vhf/uhf (only rare because a majority are set to 700/800 and r2/r1.) Or even an apx8500. Hence why I ended up buying a xg100m. 2m,70cm, 7/800 and vhf low (not really usable though). Sent from my SM-S901U using Tapatalk
  12. You don't really pay all that much to the fcc. Now the local frequency coordinator. He's going to rob,rape and pillage you. Sent from my SM-S901U using Tapatalk
  13. You won't unless they have the same tone. Locally we suggest all people enable/program a monitor button if out radio has that feature... Then monitor for about 30sec to a minute before transmitting. On repeater pairs a lot of have no receive ton on the receive side. I don't do this because I don't want to hear all the kids and lawn mor companies stopping my repeater scan. So generally, before transmitting on a repeater pair I hit the monitor button on my xtl5k or xg100m and I removes the tones for the receive side. It's helpful for some one whom might be close on simplex but can be heard by the repeater for one reason or another (usually wrong tone or dont even have one set) but can hear our conversation on the repeater output. Sent from my SM-S901U using Tapatalk
  14. It can help and hurt. Most springs are calculate into the length of the radiating (active) length of the antenna. For instance, the comet 2x4sr (think this post is the one you are referring to) is about the same length as the section that is removed to install it. It would not affect anything. You can actually tune the antenna by unlocking the allen grub screws and increase or decrease the length of the antenna smidgen. But because of it being a collimeter design it can be a bit tricky to do right. Which is unlike cb antenna steel whips. Which are technically too short, most commercial whips are about 102". By adding the 6" spring to the base it brings it closer to the natural resonance length. Give or take with spring it's 108". Resonance is about 108-112" (true 1/4 length) for 11mhz/cb. Sent from my SM-S901U using Tapatalk
  15. kidphc
    WSCL633
    It will work just not well. It's just a really kinda compromised antenna. 2m-70cm and gmrs is a real big stretch, bandwidth wise. So the swr values I got it was close to 2.1-2.5 give or take swr on the gmrs repeater. Some got lower swr, but my ditch light mount where the antenna is located is a compromise location. So take it with a grain of salt. It heard gmrs better then my Larson 270. But the Larsen is up on the car. Why? Well the Larsen is extremely flexible and can/has taken a beating. Some con with the 2x4sr. One it is thick (how it gets its bandwidth), tall and stiff. The other con is the hinge (mine started to loosen up in about a months time) as well as I found water starting to go through to the coil. If you do get it expensive. The spring (Highly recommend it) adds cost and isn't included. Mine at least whacked everything. The thickness a benefit to bandwidth, made my antenna move way to much. It rocked the mount violently with every bump, one of the main reasons I went back to the Larsen. In short if you don't need to have 2m/70cm you are better off with a dedicated gmrs 5/8th over 5/8th antenna. Sorry for the long winded post. Sent from my SM-S901U using Tapatalk
  16. Sadly. Don't use the repeater is the answer. The only way to stop a tone decoder is to not have transmissions with the tone encoded. Hell we have one local guy, sits in a tow truck between calls and tries to find repeaters. He is proud of finding hidden repeaters. He has every tone programmed on every repeater pair. Basically tried to brute force method to find repeaters. He gets a repeater tail and he is happy. Just be prepared to change tones if someone starts interfering. Sent from my SM-S901U using Tapatalk
  17. Yes, you are over thinking it. The mag mount should provide enough capacitance. Provided there is enough sheet below it. Even in hf, you would be better served by grounding chassis component of the car over going through the antenna mount. Mainly due to the wavelength in hf. Think meters to tens of meters to hundreds of meters for one full sine of rf wave. Gmrs is only going to need a disk roughly 9 inches in diameter. To accomplish the same. Stick the magnet on the center of the roof and enjoy. Sent from my SM-S901U using Tapatalk
  18. Not sure if that is possible. I haven't seen any network talkgroup ids that are linked. Plus it's not in the same service, so what are the legal ramifications? Would this be a violation (maybe multi violation)? I mean cross repeating two separate radio services? You know gmrs radio transmissions to an ip network over to an amateur ip network, then over to potentially retransmitted to amateur frequencies on a hotspot? God my head hurts thinking about it. Sent from my SM-S901U using Tapatalk
  19. Agreed. But it's expensive for a mobile antenna Sent from my SM-S901U using Tapatalk
  20. I have done a little research. Not a huge amount. Mainly because I thought I could do ham, lmr and gmrs on the same antenna. Which you can't i would have to buy ham antenna, lmr/gmrs antenna. Which would have been $$$. It uses what looks foil like flaps arranged in a circular pattern with dielectric material between the flaps. So it looks like it creates a circular polarization pattern, great for fm radio and satellite comms. Although I am really skeptical about some of his claims. Josh from ham radio crash course did a comparison of it to some tried and true dual-band mobile antennas. It in fact did seem to reach out and hear better than most of the whip style. I have no experience with it. Why didn't I plunk monet down on it? 1. I needed flexible antennas. Parking garages and trees. That antenna is a rigid tube. 2. Couldn't tune the damn thing. Not a deal breaker if done properly from the factory. But i like tuning mine and being able to get replacement parts cheaply. Guess if you really want to know you will have to whack the crap out of your credit card. Personally, that is almost as much money as used Motorola mobile or mid tier to high-end radio. Sent from my SM-S901U using Tapatalk
  21. Yeasu's hf mobile motorized screwdriver. Works directly with the likes of a ft891,817,ft991a without the need for a controller. Gets shit on a lot due to weather seal issues, motor issues and missing features of its competitors. Frankly, you cant compare it to the competitors. Simply because even a baby tarheel is going to start at 350 or so, then if you want memory for the different bands, almost as much as the antenna a quality controller. Then there are the scorpions, easily 3x the atas cost for the screwdriver alone. Sent from my SM-S901U using Tapatalk
  22. Barely tunes 2m. So I would venture no. But you can try, would have to cut the antenna pretty fierce. I figure the internal coil is too long. In fact I haven't seen a screwdriver antenna (commercial) built even go to 70cm. Sent from my SM-S901U using Tapatalk
  23. Do you hear a repeater tail after you key up? Sent from my SM-S901U using Tapatalk
  24. Legally/technically.. you would need a FCC approved device for each service. 1 radio for gmrs/frs 1 radio for amateur uhf/vhf 1 radio for amateur hf ( they have base stations that do 2m/70cm and hf) 1 radio for cb 1 radio for public safety 700-800 Yada yada and so on. Fun part most antennas can't do multi services well either. Sent from my SM-S901U using Tapatalk
  25. No. Sent from my SM-S901U using Tapatalk
