kidphc
    16
Everything posted by kidphc
  1. Nope, you to change the mode with the 3 finger salute (sorry don't remember the buttons). There are different modes for the different markets the radio is sold in. Crap can't even remeber what the mode was. Mine is set to allow 2m/70cm (ham bands) and gmrs band. One mode unlocks 144-147MHz and 400-490 MHz. But if you bought the g version it should be sent to gmrs. If not then it is probably set to the ham bands. Sent from my SM-S901U using Tapatalk
  2. Yes. Since rf linking isn't possible with the limited bandwidth of Gmrs. It is possible in the Ham world by utilizing 2 different bands for the most part, I think. Think sorta cross band repeat. But even there internet connection or phone patches the preferred way. Sent from my SM-S901U using Tapatalk
  3. Generally no. If you say inverse one repeaters pair (not legal for gmrs). They would cause a loop effect. Till one repeater timed out. Best way would be to link the repeaters. There is some hardware in the mygmrs.com shop for that. Sent from my SM-S901U using Tapatalk
  4. The travel tone of 141.3 was adopted because it is what REACT uses as their tone for the most part. Kinda makes sense.. lol Sent from my SM-S901U using Tapatalk
  5. Not going to really answer your question, since really it is going to depend on you and how you want it, it really is personal preference. However, you may want to contact the repeater owners to see if other tones are enabled. Some repeaters, many, will have multiple tones on the same repeater. For various reasons, however since there is no real gmrs coordinator, this can reek havic on other repeaters if those same tones are enabled and they are close enough. In your case, i imagine the closer repeater has both tones enabled. Sent from my SM-S901U using Tapatalk
  6. Welcome. Unfortunately, the distance is pretty far. Depending on how far you are it would be cheaper to buy a house close by and live there. You didn't mention how far, unfortunately. Sorry, not trying to be a jerk apologies if it sounds that way. Most really good repeaters are going to have a coverage of about 18-22 miles in a radius. Even those repeaters are up on towers with pricey antennas and gear. Then throw linked repeaters, everyone in the footprint of all those repeaters would be hearing the conversation, as well as tying up those frequencies. Even amateur (ham) would have a tough time covering those distances reliably. Radio frequencies is subject to a lot of different things, like terrain, distance, atmospheric conditions. Have you thought about ip radio like zello? Sent from my SM-S901U using Tapatalk
  7. I thought the amateur antenna is protected if you are a mars operator. Then it is protected by the DOD. Then everyone can go pound sand. Sent from my SM-S901U using Tapatalk
  8. Funny enough neighborhood is full of "karens". Complaining about leaf blowers and lawn mowers during business hours. That can be heard in their house. Same people where if they were less financially secure with live under a glide path to an airport. Then demand they move the airport that was there 40 years prior to the houses. Lol. I will have to recheck the covenant. But it's pretty restrictive. Not sure about the op. Sent from my SM-S901U using Tapatalk
  9. For me no. My Hoa will not allow yagi style antennas in the covenant. Sent from my SM-S901U using Tapatalk
  10. The peak of the eaves. I have a giant triangle on the side of the house. Some 40 feet off the ground. Mobile verticals are going to be omni. Very few people use mobile yagis. Sent from my SM-S901U using Tapatalk
  11. That only applies to tv antennas. They do and can restrict you from putting radio antennas and towers. Sent from my SM-S901U using Tapatalk
  12. Similar problem with my hoa. For hf I resorted to a bird feeder with a "perching line". The other hf antenna, I will be putting up a 1/4 hf antenna with a flag on top. They allow flag poles up to 25 feet. For my gmrs and uhf/vhf antennas. I have resorted to in the attic. Which presents other problems. Plus, they don't work fantastic. But any antenna is better then non. Though about putting up a vertical mobile antenna, with a base ground plane made for mobile antennas on the eveaes of the house. My hoa doest allow tv antennas. Although that is in violation of the FCC OTA rules. They also only allow small satellite dishes under 16". There are ways around the rules. Most are not optimal. I wish I had trees on my lot, because, you can hide verticals reasonably well in a tree with green paint. Sent from my SM-S901U using Tapatalk
  13. I asked the owner of the repeater (owns about 6 in the D.C. area). About the 100% duty on the Motorola Quantar. His answer which is stereotypical of him was "its a 100% duty cycle till it isn't anymore". Hence, why he tuned them all down to 35 watts. He said they rarely fail at that point minus a lightning strike etc. Sent from my SM-S901U using Tapatalk
  14. Ok. The repeaters that were tuned down were Motorola Quantars. Which I view as nearly indestructible. Sent from my SM-S901U using Tapatalk
  15. Can it handle that duty cycle? Most of the repeaters in this area are 50w capable turned down to 25-30w. To increase available duty cycle and not burn the finals out. Personally, I wouldn't add an amp to a repeater. To me it is just another maitenance item and failure point. Sent from my SM-S901U using Tapatalk
  16. Again you can borrow the anytone. Jack knows a lot about 11m, so consult with him before you jump. Sent from my SM-S901U using Tapatalk
  17. Also have a 10m hamstick on a quick disconnect. It will tune 11m just fine. Sent from my SM-S901U using Tapatalk
  18. Wanna borrow mine to try? Your ft891 is capable of you mars mod it. I think. Plus Jack has a sirio on the back of his vic. Not sure what radio it is attached to. I think it is a President with fm. Sent from my SM-S901U using Tapatalk
  19. Not yet sadly. Have a radio capable. Sent from my SM-S901U using Tapatalk
  20. Let me expand. Phone = voice (Mostly fm modulation, some are going to be digital aka dstar,p25,fusion,dmr,nxdn) Ssb = am single sideband voice Am = self expantory Data = digitl packets aka ft8, ft4 for the most part Rtty = radio teletype Image = slow scan images All of this is covered in the technician amateur radio license material. If you want more ino. Sent from my SM-S901U using Tapatalk
  21. Phone mostly fm modulation. Sent from my SM-S901U using Tapatalk
  22. I resemble that remark. Sent from my SM-S901U using Tapatalk
  23. I have yet to see any state enforce it. Some states even just mark it as a secondary offense. Sent from my SM-S901U using Tapatalk
  24. Did some further research. Although the law does not spell out "you can use a radio". They tried hard to limit it to "cellular mobile devices". I think you are safe. http://www.legislature.mi.gov/(S(wdrt4cb1pq0li15ad1tplx3q))/mileg.aspx?page=GetObject&objectname=mcl-257-602b "257.602b Reading, typing, or sending text message on wireless 2-way communication device prohibited; use of hand-held mobile telephone prohibited; exceptions; "use a hand-held mobile telephone" defined; violation as civil infraction; fine; local ordinances superseded." NOTE: "use of hand-held mobile telephone prohibited" I am not of advocate of texting even with APRS devices. It's tedious even when standing still. So as long as you aren't texting, or reading on your Garmin or ham APRS rig you SHOULD be completely fine. Consult a lawyer to be safe, then put them on rerainer. Sent from my SM-S901U using Tapatalk
  25. Here in Maryland, they specifically exclude radio handsets. The logic was if they didn't, every first responder could be violating the law otherwise. Sent from my SM-S901U using Tapatalk
