16
Everything posted by kidphc
What is the best base station antenna?
kidphc replied to Walker77's question in Technical Discussion
Not really, but height would. No real magic in antennas, especially from manafacturer to manafacturer. Hence, why you see similar bandwidth and gain values. But if you can get the antenna above the ridgeline, then you will see improvements. Maybe even huge gains in reception and transmission distances. Once up there you can look at yagia (trade more gain for losing omni direction pattern) etc and all the usualy yada yada. Your antenna can only really get out to places it can "see". Sounds also like your antenna is very obstructed by the house. Usual recommendations are try to get ²/3 of the antenna above any near field obstructions at least. Sent from my SM-S901U using Tapatalk -
Not bad really for 9:1 swr. Sent from my SM-S901U using Tapatalk
What's the power fold back like on the swr meter? Sent from my SM-S901U using Tapatalk
Sounds right. Could also just set output to csq/none. Sent from my SM-S901U using Tapatalk
Yeah heard the weather was just about perfect. They did say that the infield was a mess. But it was just the design of it. Sent from my SM-S901U using Tapatalk
Bluetooth works fabolous for programming. Haven't had an error yet during programming. But the radio is close and fully charged. Only negative with this style of programming is you plow through the battery life. Bluetooth works well with the headset. There is no separate bluetooth profile for PTT buttons, so that is kinda out. I believe there is a bluetooth hand mic that will work but its from Harris (might be a Pyrme retag) and it is expensive as well as rare. Radio has been working great. Its my go to radio, was a BF8HP then a Anytone 878uvii +, now it is the Harris. The biggest cons are no APRS, duh. No Bluetooth PTT profile. Cost and Weight. I was told a guy at Dayton had a cache from a police department of the XG100P. They were full feature set, new in box, with the charger, battery and antenna. One of my friends said the serial numbers and feature set matched the invoice which was in box. He was letting people buy "1" for around $450. He said the line was incredibly long (of course it was) God I wish i could of gotten one. But I didn't even go.
2m / 70cm Dual band antenna suggestions
kidphc replied to back4more70's topic in Amateur Radio (Ham)
It is rough... since yes it's 2x the cost of a tram/browning of similar design. But built at a different level. So might as well throw it out there, especially with "best" being at the top of the list. He will have to decide his budget. I think the Diamond is a better antenna. But I WANTED survivability, which influenced my choice heavily. Sent from my SM-S901U using Tapatalk -
Unfortunately ³/4 wave on 70cm. My testing showed.. meh. Going to buy another to mount as 1/4 vhf, cut down to fit a ⁵/8 gmrs coil. I need the flexibility. Plus a lot cheaper then 2x sti flexi. Sent from my SM-S901U using Tapatalk -
If you can run a 1/2, 5/8 over 5/8. You can get both bands nicely. 31" sounds like a lot but if it is a flexible type then it won't matter. Can't tell you how much abuse my larsen 2/70b took when it was on the roof of my suburban. Most parking garaged by me are 6' to max 7' clearances. Now try to add gmrs into the antenna mix. Slim pickings and most are incredibly stiff to get the coverage from 2m-70cm-gmrs. They end up being chunky inflexible antennas with barely acceptable performance. Nowadays I try to avoid tri-band antennas. They sacrifice too much, especially in performance. Sent from my SM-S901U using Tapatalk -
Should mention 18-20" 2m antenna is going to be 1/4 wave and 3/4 on 70cm. They will almost always require a groundplane. Sent from my SM-S901U using Tapatalk -
Really kinda tough like Marc says. Mainly because 1/2 wave 2m ⁵/8 over ⁵/8 uhf is going to be about 31". Really, any 1/4 wave 2m , 3/4 70cm antenna will work. ³/4 wave is just terrible from my real world testing but mostly on the transmit side, it received well. So any of the company's that build it will work equally (about) as well. Tram browning larsen etc. They are all going to about 18-20 inches. Sent from my SM-S901U using Tapatalk -
Yes lscott. Those are additional benefits. Another one is most large retailers have cheap frs radios on the shelf. Alot of the are gmrs capable. Sent from my SM-S901U using Tapatalk
Covid. Combination of people stuck at home and lowering of gmrs license cost. Are big factors. Some migrated from cb, which really is a shit storm 80-90% of the time now adays. I know of 6-7 people whom left cb and went gmrs. Sent from my SM-S901U using Tapatalk
Let me see if I have this straight...
kidphc replied to TheSidewinder's question in Technical Discussion
We actually are doing that here because of multiple repeaters on the same frequency with different tones. Lots of cross repeater chat going on now. Just gotta let the repeaters all drop before next person keys. Sent from my SM-S901U using Tapatalk -
Could be why i was told to disable it. Sent from my SM-S901U using Tapatalk
Impressive aren't they? Warming popcorn for your install of the ftm500. Sent from my SM-S901U using Tapatalk
Base Station Versus Handheld with Aplifier
kidphc replied to pwindsor's question in Technical Discussion
True not true. The bnc relieves the stress created by installing and uninstalling a cable. The type of cable, how it is comming out of the connector and the angle of said cable all apply stress. Those Abree 48" long tactical antennas put a lot of stress on the sma. Sent from my SM-S901U using Tapatalk -
Make sure the keypad isn't locked before you try to reset the radio. Sent from my SM-S901U using Tapatalk
Outside of some of additional (small) loses from connectors, it might not look as clean as a base install. I can not think of anything but potential damage to the sma connector on a handheld from either connects and disconnects or strain from a heavy coax on the connector. I can not think of many downsides. Sent from my SM-S901U using Tapatalk -
You will need the accesory cable and connector use the remote on wire and tap into a 12v switchable powered source (car am/fm radio wire/fuse is the favorite). Then go into cps and configure the ignition sense under radio information/accessory configuration/ignition sense type. Then, when ever the ignition energizes the wire (in example above car radio). It will auto turn the radio on. Turn off the car and it should go off. Unless the remote wire is connected to a power delay accessory. Then it will turn off when the wire is not powered, usually at driver door open or some pre-configured time out. EDITIED to clarify things because I suck at explaining things the first time around. Sent from my SM-S901U using Tapatalk
Any Tips For Someone Thinking of Getting A H.A.M. License?
kidphc replied to OffRoaderX's topic in Amateur Radio (Ham)
Same could kinda be said for any degree/certification. Sent from my SM-S901U using Tapatalk -
I know you are messing/joking with him. [emoji14] We should just be as informative as politely possible and encouraging as we can be. Especially, when someone is asking for help. Could turn them off, more so if they take it the wrong way. /rant Overall impression, I get from non-amateur radio people is that we can be condescending, know it alls that bitch too much about everything. Some of it true, especially since we do most of the self policing. Can't tell you how much of the public safety/lmr groups think we amateurs are a joke and don't want to invite us out for events. With our relay forms and other politics and attitudes. Then those same guys praise people like Marc, can't tell you how many times I hear " I trust Marc and his small group". Because why? They do everything possible to get the objective done, then cross the tees and dot the I's later, with minimum fuss or bs. We should aspire to be the best spoke person for the hobby /rant Still love your comment [emoji14] but I get it. Not everyone will. Sent from my SM-S901U using Tapatalk -
Think he is referring to the gmrs radios capable of data burst, they can not have removable antennas. My reasoning is that the fcc didn't allow it to limit range. Can you imagine somebody strapping an 11 element yagi. They want that type of shanigns on the amateur service. Sent from my SM-S901U using Tapatalk
If you can take the practice 3x and pass each time with about 85%. Your are way over ready to take the test. Remember, you just need to pass. No one will ever know the score. Study for the general and technician at the same time. They crossover informatuon for both the test is like 75%. If you pass the technician, they will let you test for general on the same day. Sent from my SM-S901U using Tapatalk -
VHF/UHF (incl. GMRS range) Mobile 1/2 Antenna
kidphc replied to ytechie's topic in General Discussion
Yes, mobile installs are all comprimises. You want about 1/2 wave length of the longest minimal separation, if you can. But that is not always possible. I have about 8 feet from my 2m/70cm antenna and gmrs/70cm antenna. I noted the other night even when transmitting at 5watts on the 2m/70cm antenna (I was using 70cm fusion at the time). It was tripping out the xtl5k (gmrs/70cm) really badly. Like opening squelch on a frequency, i was scanning gmrs repeaters on the xtl5k. From my calculations, it was about 30MHz difference. The physical radios are some 6 feet apart. One in the glove box. The other on the third row molle panel. Sent from my SM-S901U using Tapatalk
