16
Everything posted by kidphc
One Portable mobile radio setup for multiple vehicles?
kidphc replied to WRUM285's topic in General Discussion
Not really any issues but wear and tear and the cost of the installs on each vehicle. For the battery charger issue, might want to contact midland to see if there would be an issue. Really wasn't designed for the way you want to work it. I thought something similar using an xts5000 hand held, several XTVA units (dock for the ht) in different cars. Problem was the amplifier, it just got expensive. It would of been cheaper to have a anytone 779/radioitty 20g in each car. So there are several ways to skin the cat. Sent from my SM-S901U using Tapatalk -
Normally, you do need 2sdrs. One for control and 1 for scan. Always thought the duo was built for contesters. Kinda gave it a glancing thought for trunking work. But then you are getting into sds100/g5 prices. Frugal radio on YouTube setup trunk tracking and scanning with 1 rtlsdr (cheapest option I know of). Sent from my SM-S901U using Tapatalk
Have you unitrunker? How is it? I recommended giving it a try to someone whom was trying to listen to p25 and dmr trunked systems. Out of of a lot of the software that was kinda free it had something that had something like a GUI vs dsd+ (I think that is what it was called). Sent from my SM-S901U using Tapatalk
Sounds like you will be upgrading the jeep again. Maybe the new one with the fully floating rear axle and a diesel.. lol Sent from my SM-S901U using Tapatalk
Actually, Marc ever thought about a small trailer with a motorized trailer dolly? Only since you do the events so often? Sent from my SM-S901U using Tapatalk
I get you. Too bad setup and breakdown probably took as long as the event. Looks more like a welcome tent then aide tent. Lol.. Love it though. Sent from my SM-S901U using Tapatalk
Wow. If it was me it would be a military load bearing backpack, a radio, golf umbrella strapped to the backpack. Cooler in one hand and a small generator in the other. I would of looked like a hobo pervert watching the runners go by. Sent from my SM-S901U using Tapatalk
Looks like it isn't trailer accessible. Do you guys lug out all the gear in a wagon or pack mule like a bernard? Sent from my SM-S901U using Tapatalk
I have had several head mri's. Couldn't tell you what they sound like. Was wearing ear plugs, still defeaning. When people ask I don't know, like putting you head next to a jet engine with rocks in it?! Sent from my SM-S901U using Tapatalk
Try unplugging the mic and make sure it seats properly. I have had problems with rj11 and rj45 connectors with boots. Where they aren't fully seated and the mic acts funny. Sent from my SM-S901U using Tapatalk
Awesome. I don't see the fridge. Hydration is important! Sent from my SM-S901U using Tapatalk
You could build a low power repeater. Problem will be you will need an indoor and outdoor antenna. When the repeater transmitting. You will lose half of the power to each antenna. Plus a mess of other things that could go wrong. I had looked at passive repeaters/antennas. But the usefulness of them are low. In your case. I would investigate this an option. Don't expect much, but to spend money. You could try to build a dipole indoors connected to a yagi outside pointed at the area of intrest. But again passive repeaters aren't in high use for a reason. Another option is to get a kg100g, or any radio with a Bluetooth option. With a Bluetooth mic and connect the kg to an external antenna. For hams, I have contemplated buy a uv578 with Bluetooth head control mic. But always just walk over to one of my digital radios and use the hotspot. Haven't seen a gmrs (tuned) hotspot yet. Guess that will be on a to do list. Sent from my SM-S901U using Tapatalk
Bring the mic closer to your mouth. Some radios have crap mics or the hole needs to be drilled out. Some just need a gain adjustment to get the ideal deviation. How far is the mic from your mouth? What radio/hand mic. Sent from my SM-S901U using Tapatalk
Most can't be passed through without leaving a big hole and requiring a grommet to seal said hole. I have used a coax that had an fme connector (barely larger then rg58). Came with a fme to pl259 adapter. It was pretty slick if you ask me. Most of the time you need to snip off the connector to get it through tight spaces and crimp on a new connector. Contact the vendor to see if it can be disassembled for installation with instructions. Sent from my SM-S901U using Tapatalk
I had a fender mount that was introducing a lot of rfi in the middle of the gmrs band. 2m/70cm cap modded radio. Installed a dedicated gmrs radio and antenna (back 1/3rd of roof). Noise was manageable with just a hair of squelch. Turns out the rfi noise was caused by a failing brake accumulator, and hydraulic leak into the abs computer. My generation landcruiser and some 4runners use a electric motor to build brake pedal pressure. God awful expensive part. The rfi went away when the brake module was replaced. When I find leds that make rfi noise that is noticeable, in the trash it goes. It's the driver, lots of leds you can't replace the driver. A neighbor of mine has decent inverters on his solar panels. Only really made noise when at peek power, sunlight going full tilt on the panels. My noise floor goes from s3 to almost s6-s8, usually not home at those times. His plasma screen was terrible also, thank God he upgrade the tv. A lot of rfi comes from cheap electronics and poor shielding, sigh. Sent from my SM-S901U using Tapatalk
Rfi, or installation issue from the electronics running on the car. Seems like the shielding is kinda crappy on alot of Chrysler products. Turn off the car and rfi is gone. Some times the delayed accesories can still introduce noise till about 5minutes after shut off. Your coax can act as a big antenna, routing can make a difference. Generally, a good practice in mobile installs is to keep the coax ad far away from power and canbus lines as possible. Cross those lines if possible at 90 degrees with the coax. Sent from my SM-S901U using Tapatalk
Try the 4505. The 5/8 over 5/8, other then the size it is a very, very impressive antenna. Did I say impressive. I am running a 4503 right now. It's not bad, just a bit more deaf than the 4505. Crap i might be selling mine. Even uncut it was about 1.2 to 1.3 in gmrs repeater frequencies. Still have not cut the 4505 or the 4503 just really no need to. Sent from my SM-S901U using Tapatalk
Personally, I am all over the place. From ¹/4, 1/2, 3/4, 5/8 over 5/8. Also using a ham base antenna in the attic. I'll be using a diy yagi made by a local named Roland next. Sent from my SM-S901U using Tapatalk
Personally, depending on location. Ie mountains and repeater availability. Usually, 20 watts or so are nice and adequate. Most will let you trim the power back some even enough to get on the frs interants and still be close to inbounds according to some rules. Plus most are economical compared to a 50 watt model. Most 40/50 watt radios can't turn the power down enough to play with the entire allocation. Hence some channels are blocked etc. But it is always nice to bump up the power when at the fringes of a repeater or in the woods. With uhf and vhf. Gmrs is uhf. Focus on the antenna setup more then the radio. 15w with a properly setup 5/8 antenna gets you out further and cleaner then a 50w with unity gain antenna with no groundplane and crap coax. Sent from my SM-S901U using Tapatalk
Wasn't trying to be down on the op. Maybe bad wording. Was wondering if there was any reason they were asking. Mostly, to see if there are any other paths to get them where they want to go. Sorry if it was taken that way. Sent from my SM-S901U using Tapatalk
Yes, but mainly for hand helds. Btech makes one. The input voltage is usually set to 1 watt or less. For mobiles, yes they sell amplifiers. But the radio needs to put out about the same wattage as handheld and most radios that put out more then 20watts can't be lowered enough Normally, it is easier to get a more powerful mobile. Gmrs is already limited to 50 watts, which really is enough. Hell with a good antenna system you could get away with about 20 watts 80-90% of the time. The question I want answered is why are you asking?
You mean like an amplifier? Sent from my SM-S901U using Tapatalk
Wiring and Accessories Canbus Terminator Unlike the Motorola Canbus like on the XTL series and newer. The Harris radio wasn't self terminating. Think old fire ring/token ring networks where you had to terminate connections or the ring would fail. So we need a couple of terminators. Original Part# CD-014027-0001 These were supplied with the radio when new. Most are long gone, or in a box somewhere in a radio shop. Substitute Part# MACDOS0010 These were originally XG-75m, 7300m, and 5300m series radios About $11 a piece Generally, most radio setups will need 1-2, but if you add multiple heads then you may need several extras Microphones DTMF MC-103334-040 MC-103334-041 Included with MAMW-NMC9C Standard MC-101616-040 MC-101616-041 Included with MAMW0NMC72 Noise cancelling MC 103334-050 MC 103334-051 Included with MAMW-NMCSD Avg $20-100 depending on stock and condition Speaker and cable Speaker Cable Part # 1000005812-0001-REVB I plan on using my speaker from the XTL. The speaker cable is basically that 4 prong box connector that Motorola uses. Originally part of the installation kit. Avg $18-23 Again carry over from XG-75m, 7300m, and 5300m series radios. SEE A TREND YET? Speaker If you have to have your speaker have Harris on it. Part# LS102824V10 Avg $20 new Again carry over from XG-75m, 7300m, and 5300m series radios. SEE A TREND YET? Canbus Cable Part# ca-009562-030 Supplied with original installation kit I am using a new/old stock Macom cable. Again carry over from XG-75m, 7300m, and 5300m series radios. SEE A TREND YET? Abg $25 ebay $98 new Power Cable Part# CA-012616-001 Unable to Find Used cut Pigtails About $15 THIS Ebay seller- they will make custom cables with ignition sense https://www.ebay.com/itm/385499758239?hash=item59c1937e9f:g:gfYAAOSw22Jj~3Wg&amdata=enc%3AAQAIAAAAwI9bS6n%2BKCoIgtM0yfEty4%2F7s34lwkfTrxn7j2xMwrwTVzXos7yJkiZ73gVXNkFLLoY0x6Jfl9AVqdZ44BFx9KSmA%2BtZsPmvIV2lJ%2BOt50xEk00xYx0ADHSRPTunwh1V6QvejTSdKKub3GG2go2xjEmRNxkLATRXnp3iNMPWlzAzWDd7pkEhV%2BR0j1U1SZZmX%2BI3oxj%2Fza%2FS3yFRCW8%2FsntVeSTKwWVa6Ph9oc8Qxqh2nFL1w6FDn1%2Fbkx6kAif%2BgA%3D%3D|tkp%3ABk9SR8KWp6DzYQ About $35 Programming cable It is a Rs232 9pin Straight serial cable. I opted for an FTDI usb to rs232 NO rib box necessary Rs232 female on the head and back of the radio. Avg $20-40 Antenna connectors VHF HIgh, UHF and 7/800 TNC female on the radio brick. So you will need a Male TNC to your chosen antenna connector. VHF Low BNC female on the radio brick Again adapter if necessary. GPS port... I am not utilizing the GPS From my understanding the radio will provide NMEA formatted data. this will be on several pins on the 44 pin serial port. Reference photo of back of radio on page 18 Figure 3-2
