WSEZ864
Everything posted by WSEZ864
TX'ing on channels 15 through 22 on simplex ok?
WSEZ864 replied to GrouserPad's topic in General Discussion
An additional consideration is that the simplex channels 15-22 are sharing their frequency with repeater outputs. If you plan to use simplex on any of these channels, check for repeater activity so you don't create interference. I have two active repeaters in range, one uses 17 and the other uses 19, so I avoid these channels when operating simplex. -
I bought my TS-590 based on Sherwood's receive sensitivity ratings, but gave up ground on noise suppression technology.
I have had a Yaesu FT-8900 in three trucks over a period of 9 years and it has seen everything from sitting in a field all day in central VA summers (100f+) to western MD winters (<0f) and everything works as it should. We just had single digit nighttime temps for about a week. Display is still crisp, controls are OK.
Not yet, but am about 2 paydays from buying one. They really are great radios. I bought a Kenwood TS-590 (pre-G) when I first got my license and while it has been a very nice radio, I am drawn to the bandscope/SDR style screen of the IC-7300. I have been using an SDRPlay dual channel SDR for receive only and would love to have a radio with similar display function.
Part 95 accepted radio for blind user?
WSEZ864 replied to WSEZ864's question in Technical Discussion
@WRUU653, @brasda91, @nokones & @WSFL951: Thank you for your comments and suggestions! I appreciate you taking the time to post and I will look into the other radios mentioned. -
Permanent antenna mount on my car ruined my SWR. Ideas?
WSEZ864 replied to WRTC928's topic in Amateur Radio (Ham)
Sounds like the new mount is defective, maybe a bad connection at one end or the other. Can you check it with an ohm meter and ensure it is not shorted (check resistance between the center conductor and shield) or open (check continuity from end to end on the center conductor and then on the shield). You might also inspect the NMO mount and make sure it is clean and making good contact. -
Thank you Steve. I'm apparently out of 'likes' for the day or you'd have one. My buddy actually knew exactly who I was talking about when I gave him Maurice's name and has already emailed him. We're more or less in the area - my buddy lives up near Baltimore and I'm a little further south. -
Excellent, THANK YOU! That's probably good enough to get him by. I'll let him know this. He is also going to contact Maurice at the NFB and get his opinions. -
Thank you for checking that, I very much appreciate it! I could set him up initially, with our local repeater tones, etc.. I 'need' a dedicated GMRS HT myself and might get one like his and add the RTSystems software/cable to my end of it and program it for him. Does either radio (Wouxon or Baofeng) voice acknowledge 'scan'? That's the only other function I can think of that he would want constant access to. Thank you guys again!! It would be great to be able to help this guy get going. -
Thank you VERY MUCH for checking that. I've passed that info along. Maybe that much is enough, he may have someone who can set the menu items for him and all he'll need is channels, volume and power. -
Thank you for your suggestion and comments, sorry I missed them before. -
Thank you WSFL951! Amazon is out of stock at the link, but has it under another listing that might be workable. Opinions?: Is the Wouxon worth more than double this cost? I'm thinking I'll just donate this radio, but balk at $80 - $29 is more more platable -
Thank you for your help with this Steve, it is very much appreciated! I'll look into the KG-805G. -
Good morning haneysa.
I was linked to your thread about GMRS equipment for a blind operator. I too am trying to help a blind operator and would like to find a GMRS radio, almost ANY radio (5 watts would be enough), that would work for him.
Did you ever get an answer or find a reasonable solution?
Thank you,
Ed -
Thank you for the link WSFL951! I appreciate you taking the time to do that. I searched before posting, but that didn't come up. The info at the link is primarily about amplifiers and commercial radios, but he could get by with an HT accepted for Part 95 operation that he can use. We are fairly close to each other and to several repeaters, so 5 watts +/- should be plenty. If there is a mobile radio that offers audible setting status, etc., that would probably work fine too if it's not too expensive. -
I've been helping a blind radio enthusiast with his FCC licensing and he recently got his GMRS license. We are working on getting him through his Technician exam, but it's not going quickly and he would like to use GMRS to talk with local friends while working on his other license. I would need to find a Part 95 certified/accepted transceiver that will work for visually impaired for him to use. He has a Kenwood ham HT that audibly tells him its status and he does well monitoring with it, but cannot legally transmit with it at this time. I realize we could probably find a ham HT to adapt, but I really don't want to put him into non-compliance and I'm not at all interested in debating enforcement/risk. I've been around radio for 50 years and understand the debate, but this is not for my own use. Whatever I suggest to him must be perfectly legal for him to use for GMRS. Does anyone know of a decent Part 95 radio usable by a blind person? Thank you for any suggestions!!
Low SWR is desirable but does not always indicate or guarantee best radiation. Don't get caught up in that trap. A good dummy load has a very low SWR (1:1), but radiation is abysmal.
I see your point of view, but I look at it from another metric beyond radio value: How much of my own time and aggravation does it save? Usual answer: "A lot!" It is SO much easier to program radios using external software than it is to input all of the minutia via a keypad and multi-layer menu. I buy RTSystems stuff for every radio I own that allows software programming and consider it a very worthwhile investment. Not only do I get RTS capability, but the cable facilitates use of CHIRP, VX7 Commander and other aftermarket programming software. For most of my radios each software provides slightly differing ability to make changes. Your comment about having multiple radios IS spot on. I have a few duplicate radios and it's nice to be able to make changes in the computer, save the file and then just dump the changes into the radios at 30 seconds each.
Suggestions for antennas for Baofeng UV5G and Tidradio TD-H3 please.
WSEZ864 replied to WSAL750's topic in General Discussion
Nice. I made one exactly like this for 2 meters and it too works great. I used doubled up #12 solid wire and it's a little flexible for outside use, but works fine indoors. -
I hit a repeater, but only one person on the net could hear me.
WSEZ864 replied to WSGL997's question in Technical Discussion
This makes it sound like the OP might be transmitting on the repeater output frequency, which would explain why some users cannot hear him and why his signal would be weak when the repeater should have carried him as well as any other user. I cannot explain how he could still kerchunk the repeater though...unless he happened to hit it with someone else. We did have a 2 meter long-distance check-in last night that our net control operator could not fully copy his call, while I was able to hear him clearly, so that does happen sometimes. -
It IS odd that the squelch is so often buried in the menu. Frequency/Volume/Squelch - what else is necessary to fiddle with during operation? As complicated/convoluted as my FT-8900 is to operate in other ways, the squelch is a ring around the volume knob and super-easy to tweak underway.
Thanks for the corrections guys! We run two nets a week on our 2 meter repeater and all of us let the carrier drop. We have a Time-Out-Timer on the repeater and if we don't let the carrier drop, the repeater will eventually time out.
Can also be due to light/intermittent contact if the plug/adapter are not securely connected.
Agreed. The proper way to use the repeater (ham and GMRS) is to let the repeater carrier drop between transmissions, both to keep the duty cycle lower and to allow time for someone to break in.
