28
what power level are you running at? i know mine takes a good 45 seconds on high before the fan kicks on, and the power starts dropping almost immediately, from 48 watts and settling at 25 watts. is it only on high power? or does it work correctly at lower levels? i think the duty cycle is something like 30%, iirc.
(had a post half-typed earlier, but lost it to a page refresh) I was thinking a similar estimate to @Lscott, at around 5 amp draw for a 25 watt radio, based on what i've seen from 15-20 watt rated (around 3.5 amps) and the 45-50 watt stuff (in the 10-11 amp range). Looking at what your PSU is rated for, you're probably right on the border between 'enough' and 'not quite enough', with 5 amps continuous rating. that said, running it at the limit all the time isn't usually a recipe for long life. Alinco is a good suggestion on upgrade as well; I've been running my 'shack' off of a Alinco DM-30TR for a little over 2 years, though i don't leave it on continuously. It's a bit less expensive ($135, currently, vs $190), and has a correspondingly lower power rating (20 amp continuous, 30 amp peak), along with powerpoles rather than the bare wire connectors (i made my own powerpole to 12v socket connector from a couple other pieces). Still has a switch to set it to 13.8v, or adjustable voltage, and the noise offset knob. Currently have 3 radios connected, sometimes use a 4th with that 12v socket/powerpole for testing, and it's holding up fine.
yeah, i think all of my 45/50 watt radios have shown between 10 and 11 amp draw transmitting on high, i wouldn't want to test the 12v socket with that...if i want to run one off the power bank, i'd go the same route; use the AC outlets with a PSU.
You may be thinking the 771...the 770 looks to be a mobile, with a pl259 base. The description also mentions needing a separate base, which if you peek at, it's a mobile mount. https://www.buytwowayradios.com/nagoya-nl-770g.html
Can it be done? Sure. Besides voltage, the other big factor is what it can handle for draw and what the radio wants for current. IIRC, my mxt115 showed a 3.5a draw on high power, and I wouldn't expect a lot more draw for 25 watts. Ive done some limited testing running the anytone 779uv off of a small jumper pack that has a 12v socket accessory (I'd have to look at the brand and rating, I want to say 8a) for a short time, and it worked fine. Also been meaning to test it with the big power bank (ecoflow river max) that has a 10a rated 12v socket, and also rated for something like 600 watt draw on the ac outlets (or 1200 in "boost" mode).
WOXUN KG-1000G not transmitting to repeater using CTCSS codes
wayoverthere replied to Wildzebra's question in Technical Discussion
agreed, if the HT Is hearing the mobile transmit, desense is the most likely explanation. checking the coax and SWR isn't a bad suggestion, but given the same setup was working fine with the midland (if i'm understanding the original post correctly), that's less likely to be the issue. -
You're reading it correctly, but it's one of those "doesn't hurt for testing" kind of things...getting the "filter" (tone) out of the way to confirm things are working. Keeping "tone" is what you need to still get into the repeater (assuming it's transmitting as it should) -
Haven't noticed with mine, but I haven't taken it apart right after rain. I'd say I'll check after the next rain, but it could be awhile here I know I have a few rubber gaskets/rings that go on the nmo mount, though at this point I've forgotten which ones they came with. It seems the comet stuff (also have a sbb1), some of the tram, and the signal stuff use those in place of the oring in the base like Larsen do. The Browning uhf i have (1713bs) and the base loaded midlands (1/4 wave and 5/8 wave) use the oring like Larsen as well.
So...I'm expect some of the other members with experience with that model may have some better suggestions in the morning. That said, a couple things come to mind: First, can you set the retevis (or another radio) to listen on 467.550 to see if the wouxun is indeed transmitting? That would help narrow if it's a transmit issue or tone issue. Second, the only thing in that config screen that stands out to me is the "ptt-id" field. can that be set to 'off' just to rule out the possibility of that interfering with the tone, since it appears to currently set for "beginning of transmission"? (I think my 805g has "bot", "eot", "both", and "off" as options) -
Hadn't seen it yet, actually....I don't get their emails even though I've bought from them before, evidently. I'll give them credit for getting with the program, though. They were a really compelling option when they were basically the only thing in the gap between Midland and the LMR gear, but they were falling behind with a lot more flexibility in Radioddity, Anytone, Wouxun, and Retevis gear that's on the market now. Curious to see if there'll be changes coming to the 50x1 as well to open that up too.
Radiodditty DB20-G Programming Issue
wayoverthere replied to WROG611's question in Technical Discussion
Good catch, both. Thank you for filling in the details...I clearly haven't used mine under gmrs mode enough. -
I'm inclined to think firmware bug, honestly, but I'm open to other ideas. I took a look at the dat file (I have the Anytone cousin, but use the Radioddity software to program mine too, and nothing stood out as the culprit in the configuration. I do notice that the option in the channel settings window to disable TX is greyed out, which I suspect is part of the GMRS configuration. I have one of mine opened up for ham use, and that option is definitely available in that configuration..if I have a chance later, I'll grab the radio out of the car and try it in GMRS guise and see if that option shows up. If it's still there, that would make me lean even further toward a firmware issue. Perhaps @MichaelLAXmay have some ideas? You may also reach out to Radioddity to see if there's an update needed to the firmware...from what I've read, they're reasonably open to fixing such things, and solid on support. -
Good point...I'm probably overgeneralizing a bit much (for illustration, mostly). I have the spring kit on mine, but mounted on the roof of my truck, it'd probably still be kind of hard on the antenna even if that "ring" in the middle didn't hang up on a beam. On the trunk of a car (mag or lip mount) or hood/fender/jeep door hinge, it'd probably be fine with the spring (maybe without, too).
I would also ask about level of comfort with radio programming. Adding a couple tones and a repeater or two to an already well set wouxun is a different proposition than tracking down software and programming a part 95 lmr radio from scratch. On the antenna side, what restrictions are in play, and what's the terrain like in your area? If it's a base radio, are there hoa restrictions? For a mobile, what kind of height restrictions are in play, and what mounting options are under consideration? Willing to drill the body/roof? Need to park in a low garage regularly? Or are there minimal height restrictions? A 1/4 wave "hatpin" antenna (~6") on a drilled in roof mount will fit nearly anywhere, but something like a comet 2x4sr ~36") is going to require folding for most garages.
One factor may be equipment; split tones are no go for all except for the most recent iterations of the Midland mxt115 and mxt275 radios, and required software programming to get the mxt400's on split tones. Depending on your user base (and their choice of equipment), that may be one barrier. That aside, what is the activity level like on simplex? Are there just not a lot of active users?
Apologies for the off-topic, but is that an ex 'long lines' site?
Handheld definitely has convenience on it's side...power can help too, though line of sight is even better. If using a smaller antenna let's you use a better/higher mounting location, it's likely worth it. A 1/4 wave for gmrs is just a little 6" hatpin. depending on your choice of radios, it's nice when you can just make one common code plug (term for the file of programming) to use on both radios (base and mobile).
Power wise, there's lots of options at various price points, the key is making sure what you get can provide enough current to support what you want to run. Less expensive power supplies may scrimp on filtering (read, interference) or features. Dx engineering has a few options here link while se of the Tekpower on Amazon are well regarded as well. Antenna wise, indoors or outside below roofline are varying levels of less than ideal, but that doesn't mean they won't work to some extent. Haven't tested simplex, but I get into the local repeater fine with a small 5/8 wave whip indoors on a bookcase, mag mounted on a piece of sheet metal.
The owners manuals have a table near the back that lists what code numbers equate to which DCS codes they have programmed. (I think they may be missing a couple, I know there's 2 or 3 ctcss codes missing)
Yes, that should let you set the DCS rx code separate from the DCS code used for tx.
https://chirp.danplanet.com/projects/chirp/wiki/MemoryEditorColumns This page may help clarify, when Tone Mode is DCS (the correct entry for a repeater that uses DPL), the radio will use the same DCS tone for both tx and rx, based on the DCS Tone column. On the DCS Pol column, that refers to Polarity, either Normal or Inverted; if not specified in the listing, it's usually assumed to be normal polarity.
It's not a bad term to differentiate between a data connection and an analog connection. I won't disagree with it being a bit of a grey area though, in the same ballpark as dsl. I wouldn't chance a phone as a hotspot, for sure.
