28
With everything cellular being digital data anyway, and no direct way to make a telephone call on that device, could it be argued that that it IS ip networking, given a dedicated cellular hotspot? I know an actual cell phone as a hotspot is more risky, but it could be argued that cellular data is even further from the PSTN than DSL.
Overkill, perhaps, but that would be kind of a cool setup to set up one of those retevis portable repeaters as a node, connected to the network via cellular hotspot, and just use a handheld to talk into it and have the network wherever you go, including within short range of the truck.
I have a lcd monitor that throws lots of RFI on channel 3, and a lower level on channel 6. Turn off the monitor and it's gone. I'd start looking at electronics close by firstban see if I could quell the interference;failing that, I'd try setting a rx tone on ch 19 so the radio (hopefully) bypasses the offending rfi, or just excluding it from the scan.
The Btech comes with the offset already programmed on the repeater slots (REPTXX, as opposed to the simplex channels, GMRSXX), no programming needed. Outside of tones and names, those first 30 channels are hard coded, and anything else you add past those is RX only. If you have the handhelds in the same room as you're transmitting to the repeater, what's probably happening is the strong signal from the Btech causing the others to desense, effectively "going deaf". They may light up like they're receiving a signal, but not have any audio, or just not respond. You may also double check that the tones are correct, and that the repeater is using a tone on the output (if you have the handhelds set with a Rx tone), but my money is on desense.
Can the Woxsun KG-905G be configured for mobile operations in a car?
wayoverthere replied to ELVAQUERO75's question in Technical Discussion
Good deal. I ended up with another with a sma-m on the end that's a little thicker cable; it looks like they call it "3d-fb" now, but it was previously listed as lmr200. It's been invaluable with other radios as well. -
From the album: gear
Base radios and a couple of handhelds -
nice setup, too. did you get that so239 to SMA pigtail from amazon? i tried twice from there, and they got lost en route both times -
I haven't seen a Linux version; what use I've had has been almost entirely the android app.
Yes, i've used zello to do exactly that; to access repeaters that were connected to the net (and greatly appreciate the repeater owners that allow that access) that are well outside RF range. It takes searching out the channel associated with the repeater, and then being granted transmit access in the channel by the admins (usually they like to see your call sign in your username/profile in hello to verify).
Probably the closest thing used as such is Zello, which unlike echolink, doesn't require a ham license. I'm not up on all the hardware bits involved, but they'll usually have a channel set up tied to a node or repeater, with admin permission required to transmit into the channel. On a side note, I've been pondering doing something similar to your setup with Echolink, so i can access a local repeater remotely, just haven't dug into if I can make it work with what I have or need another radio (oh darn!). That said, if you can work out the interface hardware and locked down the access appropriately (probably self only), I don't see why you couldnt use echolink to access your home node.
Vertex Standard VX-2200 and CE-82 Software
wayoverthere replied to alanplarue's question in Technical Discussion
Perhaps @PACNWCommsmay have input/experience with the 2200's; I know with my 4200's, they'll go into a reboot loop when the cable is plugged into the radio, and stop and switch to "pc prog" when it gets whatever signal it wants to see from the software. I'll usually have the cable plugged into the computer, plug it into the radio right before I'm ready to read/write, and then click the menu item (which, IIRC, reminds you to turn the radio off and on). one other thing to check would be Windows Device Manager to see if it may be a driver issue (look for the little yellow triangle/exclamation point). On a side note, I found it interesting the "upload" and "download" terminology are opposite from most consumer radios/software I've used. -
I won't say direct experience with CE82, but I've had good luck fooling the CE package that covers my VX-4200's (and VX-920) by changing my system time to something well before that Jan 2013 date (I usually just leave the rest of the date alone, crank the year back to 2005, and use the actual edit date in the filename when saving) before starting up the software.. -
Not hearing any activity isn't necessarily an indicator of the repeater being offline, though not getting some kind of response from the repeater is less of a good sign (though not indicative, either, depending on repeater settings). sometimes there just isn't any traffic, though. That said, while you don't have to worry about PROGRAMMING offset, you do have to at least make sure to use the correct channel that has the offset programmed. GMRSXX are the simplex channels (no offset), while REPTXX are intended for repeaters, with the +5.0mhz offset preprogrammed...if you're already on track on this aspect, feel free to disregard.
if you're connecting an amp between the antenna port on the RT97 case and the antenna, the amp is in the receive path (which does neither the amp or your receive any favors. it COULD be sorted to bring the tx and rx out separately, amp the tx side, and either run separate antennas or add a duplexer suited for the higher power....but then do you end up with a repeater that talks further out than it can hear?
Yeah, it wasn't particularly surprising. One of those "worth a try things"...though that does bring to mind something else to try, to see if opening the dat file from the radioddity software works with the Midland software. What I tried previously was using the Midland software to try readying from the anytone radio (just to clarify).
I cut that sentence off a little too soon....should have said only one that does vhf; according to the chart (and experience with the 805) the 805 and 905 are UHF only. Also missed the zones thing...rushing to complete the post before I needed to clock in for the day.
First, welcome to the fun! Wouxun KG935g is probably the most flexible choice on the list, and according to the comparison chart on BTWR, appears to be the only one of their 3 GMRS HTs that does vhf, and I want to say I've seen something about the ability to do the zones as well will have to dig a little more on retevis and radioddity to offer suggestions there.
The only ones I know of are Garmin's Rino series. https://www.garmin.com/en-US/p/533999
Is my Radioddity DB20-G outputting any power?
wayoverthere replied to redshirtsteve's question in Technical Discussion
Back with a little further test data to share. I grabbed the other one out of the beater, since that one isn't attached (just shoved in the slot in the console) and I was in that car today. Both are programmed near-identically, really differing only in which channels show up in the scan (the one in the car is doing ham/GMRS dual duty, one in the truck is primarily for GMRS with a Icom for ham). Even unlocked, I did my best to stick as closely as possible to the part 95 configuration (save that 'able to access other services' thing). For the GMRS channels, 1-7 are set for low power, 8-14 are rx only. Hooked it up to my PSU (alinco dm30tr), hooked up the sw102 and dummy load, and keyed low power on ch 3 (462.6125). PSU shows 1.6a draw, 13.9v (radio shows 13.8v). The Surecom showed the expected 1.0 swr for a dummy load, and 5.12 watts out. Tried it again with an antenna in place of the dummy load (midland mag mount on a piece of sheet metal, 5/8 wave base loaded whip) also shows 1.0 swr, with 4.48 watts. Still curious for a meter reading on output, but like @donniefitz2 I'd like to know what's up with the programming in the radio, and could it be "CH 3" is something outside of GMRS and in lockdown mode it's just not actually transmitting? Given the number of issues we've seen with some of the brands with all kinds of funky things showing up as default programming both post reset and out of the box (and the fact that, despite being sold as part 95 gmrs-locked radios, both of mine came unlocked), verifying the programming is probably a good next step (outside of solutions Radioddity may offer). -
Took a quick look at mine in the truck (currently unlocked to full dual band to toss in the better half's car for a recent trip), and the one bar on the on screen meter and red tx light are consistent with low power transmit on mine. I found "tx inhibit" in the menu, though it may only be there in unlocked mode. In the software, you have to hit the >> at the end of the row to go into channel details, and it's toward the upper left, iirc. I want to say when I checked on my psu, it showed around 3.5a draw on high, but I can pull it inside and check low power. from here, dummy load or not, I'd want to get it on a meter and check power output directly..just give your call sign and say something about testing when you key up, if you don't have a dummy load....won't be a 100% accurate figure, but close enough to see if the output is there or not, and what the swr looks like. Touching base with Radioddity isn't a bad idea as well. -
I'll try to peek at what the meter looks like on my anytone with low power tx sometime today, and if the tx disable is in the menu. Three things come to mind to check: swr (to rule out a cable issue causing it to cut power), whether tx is disabled on that channel in the programming, and (the big one that stands out) if plugging in something else to that 12v socket displays as a draw on the meter....heater, 12v fridge, whatever. I'd expect to see some current draw on key up. -
that lines up with seeing 18 from mine into a dummy load, and 22 into an antenna, both on high...i usually use medium power.
Not that I see, so far. It'd probably be a pretty popular one. Mentioning it as a mental note to myself, but I wonder what id get if I installed the Midland software, and tried reading from the anytone. edit: downloaded and installed, but no luck reading from the anytone, and trying to mess with things in the .dat and .fre files just ended up with system errors and making the program unusable. the fact that they limit what tx frequencies you can program via the software makes me think it's not all that locked down in the firmware, similar to the Wouxun 805g, but dependent on programming limitations in the software to keep it in-band.
