wayoverthere
    28
  1. wayoverthere
    WRPK996
    Glad to help...I haven't been able to find the member list on mobile, but a little searching does find some references to members bing in an around the area, so hopefully they'll chime in with some suggestions.
  2. some googling turned up this: https://www.radiohaus.com.br/produtos/downloads/dl.php?cod=78 (same link, ungooglefied) (under the downloads on this page: https://www.radiohaus.com.br/produto/962/gp-6-antena-dual-band-fixa ) which should link to this pdf: gp-6.pdf
  3. wayoverthere
    WRPK996
    Did a search in ULS right now, and your call does show up. One thing I notice is that the other 2 you reference were granted on the 18th, with effective dates of the 18th, while yours was granted on the 18th with an effective date of the 19th. There's usually a business day or two delay between grant and the updates FCC pushes out being ingested by the site database, so with the holiday taken into account, the site may see it on Tuesday or Wednesday at the latest.
  4. other than a little dent in the wallet, room to grow is never a bad thing ? on top of the obvious, not running the gear at full capacity all the time can be a good thing for longevity.
  5. I've toyed with a cheap 12v receptacle switcher on a cb, and the ac noise was awful. I've been happy with the current alinco dm30 switcher that supports my "shack"; tested back to back with battery, no antenna connected and no difference in noise, though as far as I know AC noise is more of an issue in HF than up in UHF, so if you have an eye that direction, it may be better to make the investment up front in a good linear. My alinco switcher, and some tekpower, have a "noise offset" to move switching noise if it becomes an issue. Alternately, a lower power linear to support the ~4amp draw of the db20g shouldn't be too expensive if gmrs is all you're after.
  6. Same here...from the forum page I get the same "no subscriptions" page/message. From the map page, I get a slightly different sidebar
  7. If you bring up the sidebar on the main pages (either the "repeaters" or"map" pages will work), rather than the forums, and click on "my subscriptions", you'll get the page @Sshannonlinked.
  8. As best I can, sure, though I didn't measure every channel...it was kind of spur of the moment on my 'break'...I can grab more numbers soon if needed. What testing I did showed "low" as 5.x watts, 9.x on "medium", and "high" around 20.x watts (small variance of a tenth or two around the bands). Voltage was 13.8 per both the PSU and the display on the radio, though I didn't go get a multimeter to verify. References to"low", "medium" or "high" power refer to the software and/or menu options. 1-7 and 15-22 are set wideband, as are most of the other things I have programmed, while 8-14 are set narrow, tx disabled, and a few others are set narrow accordingly. Power wise, 1-7 are on the "low" setting, I'll have to double check 15-22; I want to say I used "medium" for most of those, with the exception of one specific repeater I programmed that's ~60 miles out, which is set "high"
  9. Noted; I set mine up the ssame with 8-14 tx disabled, 1-7 for low power. And 15-22 as usual, plus simplex and repeater 20 with a 141.3 tone and the 3 local repeaters in range.
  10. The GXTs don't say anything about 9lpart 95 either, just model number and fcc id. I wonder if it locks down the power in gmrs mode. I'm using 136-174/400-470 mode, and it showed 20.x watts on high everywhere I tested high. 5ish on low, 9.9 on medium. I have it almost entirely uhf only, as the only good gain antenna I have to pair it with is a wideband browning uhf. Will have to double check the signal stalk for gmrs.
  11. Afaik, daily (unless it's changed), though there's usually a day or two delay with fcc releasing the updates, and the scripts running to import it. If it goes beyond that, it may be getting hung up on a bad bit of data (has happened before).
  12. I'll have to double check the midlands in a bit, but; my kg805g doesn't mention part 95 on the label, though it does have a line for "bands:" where it indicates GMRS.
  13. That's been my experience with them as well, barring once when an item was out of stock, which they were quick to communicate (ordered over the weekend, they called on Monday).
  14. So...double checked the mxt115 (Midland is probably the closest thing to a gold standard of part 95e compliance) and the btech 50x1, and neither of those indicate anything about part 95 on the labels. I can see the "as shipped" condition being an issue if someone was expecting a gmrs radio and not willing to take the time to program it properly, and with it not shipping in compliance with what they're advertising it as (wasn't advertising part of what got Rugged Radios in trouble?). Perhaps someone in the supply chain is getting careless.
  15. I recently took delivery of one as well; it displays a 95e certified FCC ID on the case, but mine very definitely showed up in ham mode. Given that's the main use I have in mind for it, no issue here; in the future if I throw it in the truck (which already has a dual band ham radio in it), I'll flip it to GMRS mode...the option of wideband and split tones put it a step up on the MXT115 that's back in that. I mentioned it in another thread, but when I downloaded the software from Anytone's website and ran it through Virustotal, it kicked out 5 flags for various things. Tried the db20G software instead (downloaded from Radioddity's site), and no flags there. It also read and programmed my radio just fine (looking in the 'About' menu, it even shows the model as AT-779UV, but Radioddity). I also snagged a couple side by side shots with the MXT115 for size comparison...really close in size. Curious how it's going to work out as well, but not too much of a gamble for the price.
  16. from poking at it, i suspect those "vfo" slots are related to the last setting of the VFO, but the instructions are...a bit lacking. picked mine up today, and working on programming this evening. first impression is wow, it's small, only a little wider and a little thicker than the mxt115. definitely seeing the 500 memory slots, both programming manually (which was a bit hit and miss) and in software. second note, @MichaelLAX wasn't lying about the sensitivity...had it powered up on the desk with no antenna, and it was picking up stuff from a 70cm ham repeater around 30 miles out. currently have it programmed almost entirely for UHF, with the exception of some receive-only VHF stuff, as that's the antenna i have handy that covers what i want to. on a side note, i grabbed the software from Anytone's website, and ran it through virustotal...got 5 hits for various things. remembering the 'twin' factor, i went and grabbed the db20-g software from radioddity, and scanned that...no hits. installed, and it even reports the model number in the 'about' menu as at-779uv. read and programmed the anytone just fine. i'm keeping my expectations in line with price. mainly i wanted something cheap to throw in the beater car with antennas i already have, that i can also pair it with one of the mag mounts to use in a rental car when travelling. already ordered another antenna, though, as the signal stalk on the truck is just a hair too high for the parking garage at work...found a dual band comet that's a few inches shorter, which should be just enough.
  17. Don't know about the other versions of wouxun's software, but I've used the CPS for the 805g in Linux mint mate via Wine successfully.
  18. I will say that vertex has done a pretty good job of having the help file give some explanation of what the settings do...not always in plain English, but if not, it's in technical terms that will give you a start on reading up what they mean. On the wide vs narrow thing, narrow will get along better with midland's radios that are stuck with narrow only, and other radios will be fine if you also set them to narrow. On being forced by the software, some versions (like the one for the vx handhelds and mobile), I can set my system time to something well before 2013 (when the narrowband directive went into effect), and open the cps and it will let me program wideband no problem. I use dates in the filename since the date in the file properties looks way old due to changing the system time.
  19. Ditto. The only way I was thinking a lip mount was if there was a convenient existing bolt to use.
  20. Will second skipping the btech. Cannot program more tx channels in mine, and it's started losing power on high, at around 2 years old and minimal transmit time (maybe 2-3 hours total tx time spread over that timeframe, it mostly just monitors). Starts at 45 watts, and starts dropping almost immediately, and doesn't stabilize till 25 watts...another member mentioned going through 2 with similar issues. It was a good proposition compared to Midland, but the market had grown noticeable since then. Will second bluemax49ers, he's had all of my vertex handhelds (vx, vx-p, and evx) covered with no issues, though he was out of stock on the cable for the vx4207 mobile, which antenna farm had (along with the appropriate software). Imo, a ham coming over to gmrs to get the family involved will probably be fine grabbing something commercial and not being TOO out of their depth. I'm 100% on board with starting with something simpler for someone new to radio, though. Can speak from experience that the wouxun kg805g is dead simple, to where you could hand it to grandma that's never used a radio and she'd be fine. I'll probably have some thoughts on the anytone 779uv in the future...finally gave in and grabbed one, though I'm in between throwing it in the truck for something gmrs approved with more flexibility than the mxt115, or unlocking it for a cheap ham unit for the beater car/throwing in rentals when traveling. Should be here Saturday.
  21. I know there's a divider under there between engine and passenger compartment..was thinking mounting bracket along the edge, with the antenna just outside, but that doesn't leave a lot of options on cable routing I guess. Pairing something to one of those big suction cup GoPro mounts comes to mind, but I don't know how secure that would be.
  22. I was poking at photos online for ideas...are there any bolts inside the rear hatch that could work to hold an antenna bracket, either on the frame, or on the hatch itself? Thinking a custom version of the semi common premade fender mounts brackets they sell for common pickups, and carrying a no-ground-plane antenna; the one @tweiss linked is a good option, and the antenna farm lists a few 1/2 wave whips for the 450-470 range.
  23. ? My apologies...corrected my post above as well. Hard to get a feel from a call sign, but I shouldn't assume. Agreed, the btech isnt the value proposition it used to be. Also agreed on advocating for following the rules, I'll provide the information i can to help people make informed choices...from there, we're all adults and can decide which way we go..I stick with part 95 equipment as well. On the part 90 market, part 90 in itself isn't strictly approved, but there are some out there certified for both (90/95a). It's not as easy as grabbing one of the off the shelf radio, the fcc id is key here to check to be sure. Kenwood and Motorola have a few, though I'm not as familiar with model numbers as some other members. Mine is a Vertex Standard, and it's the one model of theirs I've found that had 95a certification. Fcc id is K6610354640 (link to the grant)
  24. I don't know how dependent it is on a ground plane, as I have it mag mounted in the center of the roof, but I've been happy with my ca-2x4sr (in nmo flavor).
  25. I did a little searching, and didn't find many options for that mount; one dual band option on DXE, though it's tuned a little lower than you want. https://www.dxengineering.com/parts/mfj-1414 Based on that, I'd lean toward dropping a few extra bucks on a nmo adapter for that mount (this one looks like it would fit, and it's only $10) for the much wider variety of options on antennas. Lots of no ground plane required NMO mount options around $50, spring or no spring, small (10") to large (30+ inches). There's still apparently a few of midland's old 5/8 wave whips floating around (sportsman's warehouse) for a good price ($15) too.
