zap
    51
zap last won the day on November 7 2017
zap had the most liked content!
1 Follower
1058 profile views
zap's Achievements
  1. I live in Round Rock. I typically keep my issued service monitor in my truck. PM me if you need help or duplexer tuning. I will say, highly recommend using a Band-Pass/Band-Reject type duplexer if your site is to be collocated with other UHF repeaters. I'd run a rtl_power plot for the repeater spectrum and see what comes out…I may do that (Brushy Creek area here) and see what I find. Sent from my iPhone using Tapatalk
  2. That would actually be ideal. Your grounds should be as short as possible and a rod should be driven at the base of the tower to ground it. Sent from my iPhone using Tapatalk
  3. So here's what you are looking at from an average shop. $50/ hr in travel charge $100/hr tech time $150/hr system tech time (things like testing repeater, checking for desense, tuning duplexer) $200/hr engineering time (this will be the whole networking of the system) Plus, material. Then there is the whole networking aspect. IP? Link radios? Remember, hiring professional services means professional solutions so you'd be looking at NXU-2s and at a very minimum Ubiquiti PtP radios (assuming ISP connections are not available and LOS between sites is). You're likely looking at $1500 to $2000 to setup the repeater at your home and another $3000-$6000 for getting everything networked. Sent from my iPhone using Tapatalk
  4. Laird FG45xx antennas. Sent from my SM-T713 using Tapatalk
  5. The thing I don't like about the antenna farm, stopped listing things as dBd or dBi. The antenna farm also resales directly off of Tessco for a good portion of their products. LMR antennas you can generally get much better pricing from Tessco or Hutton. Sent from my iPhone using Tapatalk
  6. Hard to go wrong with Laird. They've been in the LMR business for awhile. Sent from my SM-T713 using Tapatalk
  7. Mobile or base? Sent from my iPhone using Tapatalk
  8. Keep it at 25W. GR1225's are notorious for burning up PA's. Out of curiosity, when was the last time the duplexer was checked for desense? Sent from my iPhone using Tapatalk
  9. Well go with trial and error. Like for weatherproofing connections, I much prefer Cell tape to butyl (coax seal). It's also easier to find as Ace and Tractor Supply often stock it as "Magic Tape". For line grounding, butyl is the best way to go though. Sent from my iPhone using Tapatalk
  10. Try manually jumping the PTT pin to ground on be Kenwood. Sent from my iPhone using Tapatalk
  11. The problem with the Maxtrac, the PA actually backs down in power based on a timer in the logic board. The GM300 on the other hand used a thermistor to control power.
  12. The M1225 won't hold up much better. Too small of a heat sink compared to its predecessors. There was a reason the R1225 was in a GM300/Radius chassis with appropriate heat sink compared to the predecessor repeaters and even it was known for failing. As far as the hamtronics receiver goes, on average they have 40 dB better adjacent channel rejection…so yea the have a lot going for them over a $100 mobile radio. Sent from my iPhone using Tapatalk
  13. It's doable. Right now you'd need a Maxon data radio with external sink for the transmit side and either another for receiver or a hamtronics receiver (about the best receiver that can practically be purchased right now). 30 ft of vertical separation and CAT5e to provide PTT, audio and COR as well as power (you'd want 24 or 48V for all intents and purposes). Still looking at $600 cost if the Maxon's were type accepted for GMRS. Add the cost of a duplexer and subtract the extra antenna and combine enclosures, you'd have a decent TTR. That's what it would cost with current tech in a reliable package though. In retrospective, Motorola sells a P25 tactical repeater (battery, duplexer at 4W) for $22,000. Etherstack on the other hand has one they are bringing to market for (15-30W depending on configuration) for $30,000. Sent from my iPhone using Tapatalk
  14. But often not followed on the business side. Public safety and trunk systems are generally better about IDing. Sent from my iPhone using Tapatalk
  15. Same repeater IIRC as the Ritron. Sent from my iPhone using Tapatalk
