wrci350
6
Everything posted by wrci350
Looks like I should have stated it differently. If the radio is capable of transmitting on the GMRS frequencies while opened up, that does not comply with GMRS rules. The fact that you are transmitting on 462.5500 instead of on "Channel 15" makes absolutely no difference.
If it can still transmit on GMRS channels while also being able to transmit on 2m/70cm, then using it on GMRS falls outside what is "legal" per FCC rules.
Radios are not "licensed", they are type-accepted. FRS type-acceptance is here: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-B/section-95.561 GMRS, here: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E/section-95.1761 There is no type-acceptance required or even available for amateur radio (Part 97). If a vendor claims they have a radio that is "licensed" (sic) for amateur radio they are either very confused or flat-out lying, since there is no such thing. If you read those sections you will see that a rule will be granted type-acceptance for FRS only if it meets all the FRS rules, and that no radio that can operate under FRS rules and "any other paragraph (except 15)" are not allowed. So a legal FRS radio is FRS-only, but definition. GMRS *does* allow certification under Part 95E and another paragraph (i.e. Part 90) but specifically forbids certification of a radio that can operate under Part 97 (Amateur Radio). So again, under current FCC rules, you cannot have a 'legal' GMRS radio that can also operate on 2m/70cm. As far as the writing being on the wall, it sounds like The Big Three aren't interested in putting out radios that can be used under Part 95 illegally. The last point seems reasonable ... but that's not how the rules are written. Feel free to petition the FCC to change them.
There is no ambiguity. Part 97 does not require type acceptance so using a Part 90 radio is perfectly fine, and there are many hams who use older Motorola or Harris commercial radios. One needs to be aware of a couple things when using a Part 90 radio: 1) As @Sshannon shows above, many Part 90 radios will do 136-174 and 400-480 MHz. Obviously most of that range is NOT amateur radio (or even MURS or GMRS) so you need to make certain you are only transmitting where you are authorized to do so. 2) Unlike amateur radio, the FCC regulations for MURS and GMRS *do* require radios to have type acceptance, and a Part 90 radio like these does not have that type acceptance and as such is not authorized for use on those services.
What MARS/CAP mod? It's a Part 90 radio so it will cover 2m/70cm as well as MURS and GMRS. Not type-accepted on MURS or GMRS, of course.
Baofang transcievers and issue with local repeaters
wrci350 replied to WRXM214's question in Technical Discussion
How close together are the two radios? If you are holding one in your hand and the other is on the table in front of you, you are more than likely desensing the receiving radio so it cannot "hear" the repeater. Try having someone take the second radio to the other end of your house, or outside a couple 100 feet away, and try again. -
VHF/UHF (incl. GMRS range) Mobile 1/2 Antenna
wrci350 replied to ytechie's topic in General Discussion
I have a diplexer and a triplexer and they are both good to 500 MHz or above. I checked The Antenna Farm's website and all the ones they carry that are VHF/UHF split (no HF or 220) go to at least 470 MHz, with most going to 540. Cost is around $50 or so -
Worked fine for me.
Well, like it or not, FRS users have just as much right to those 22 channels as GMRS users. Unless the FCC can go back in time and not ever allow those FRS/GMRS bubblepack radios, we're stuck with sharing. As far as repeaters go, if you run with both transmit and receive tones on a repeater you'll never hear someone using an FRS radio unless they happen to pick the same tone as what you are using on the output, correct? You are right about the "everyone can hear you" part, and it's not just kids who don't understand that.
Search & Rescue Group Adopts GMRS/FRS Channel 3
wrci350 replied to Over2U's topic in General Discussion
I think you're misreading the post. ? This is how I'd paraprase it: "If you are lost and have FRS/GMRS radios, call for help on channel 3.0. SAR teams can use that channel to talk to you if there is no other means. Others are encouraged to monitor 3.0 (and NOT use it for routine communications) and call 911 if they hear the lost party." I see no indication that SAR teams use FRS/GMRS to communicate internally. -
Good GMRS or Ham HT for railroad scanning?
wrci350 replied to NotaSAAB's question in Technical Discussion
No, because a "site" in a simulcast system isn't a tower, it's a group of towers, all transmitting the same information at the same time on the same frequencies. So there is no way to lock out all but the closest tower, since all the others are using the same frequencies. That's the whole simulcast issue. The signals come in slightly out of phase due to the varying distance between the transmitters and receiver, which totally 'confuses' a conventional receiver. The SDS scanners are SDR-based and able to deal with the out-of-phase signals. There are other solutions (which are also SDR-based) but none of them are scanners in the conventional sense. Subscriber radios can also handle the simulcast (of course) but that's not an option for most people. In your particular case, you have "won the simulcast lottery" since you are close to one of the towers, and the transmissions coming from that tower effectively drown out the others and the receiver can decode the digital stream. My luck is not that good, and my BCD352P2 is lucky to even lock onto a control channel of the local P25 system, and even if it can, I get at best snippets of voice traffic. In the OP's case, it looks like there are 11 towers in his county that make up one simulcast site. Again, if one lived very close to one tower then a non-SDS scanner would probably work OK. Otherwise? Not so much. This is a very frequent topic over on RadioReference. There are a vocal few that proclaim, "Well, it works for me so it should work for everyone" and that's simply not the case. I would LOVE IT if the BCD325P2 worked on the local TRS. I would never have purchased an SDS scanner if that was true! -
NXDN too, although it and DMR require a key to unlock them (which cost $). I have a BCD325P2 scanner and I love it. It's the one I take when I go for a walk outside or on the treadmill at the Y. BUT ... if one is trying to listen to a simulcast P25 system (which the Minnesota statewide system is) the odds are very much against you. Chances are it will work very poorly or not at all, unless you happen to be very close to one of the towers in the site you want to monitor. The only scanners available that are designed to monitor simulcast systems are the Uniden SDS100 and SDS200, which go for $650 or $700 new. I *wish* the BCD325P2 could handle simulcast. But it doesn't. -
A lot of them come with "extra channels" (cough cough) as already discussed; they are just the same frequencies with a pre-programmed (and perhaps fixed?) tone. Pretty sure the Motorola and Midland FRS radios (many of which were classified as GMRS/FRS before 2017) don't have any tones on 1-22 out of the box. Contrast that to some of the CCR GMRS radios that come with tones on every channel, rendering them unable to interoperate with other brands unless the tones are removed (or added to other radios).
Nor amateur radios. There is some use of P25 (simplex) in the ham world, but folks who are into that use commercial radios (normally old used ones). You won't find an off-the-shelf amateur radio that does P25. Keep in mind too, that we're talking simplex, not trunked. P25 trunking systems are a whole 'nother animal. While there *are* other options, a scanner is by far the most straightforward. -
Thanks. I don't think I've ever checked a county in Minnesota in the RadioReference DB before. Looks like most public safety (and other services) is on a state-wide 800 MHz P25 Phase I trunked system. Not much encryption (knock on virtual wood), but none of those HTs will pick up traffic on that system. The one thing I do see for your county is a couple analog Fire channels, which are probably patches from the TRS. But if you're not interested in monitoring public safety then no big deal. @NotaSAABGood luck with your hunt and keep us posted! -
Understood. My personal philsophy is the opposite: I only program frequencies into a transceiver that I have a license to transmit on. Anything else goes into a scanner. You are correct about FCC regulations forbidding Part 95 E (GMRS) and Part 97 (Amateur Radio) in one device. Yes, there are plenty of Part 90 radios available to buy new that will do both, and using them for ham radio is perfectly fine, but they are not type-accepted for GMRS. (There are also older Part 90 devices that have a grandfathered GMRS type-acceptance that can be purchased used, but that's not a path I've gone down personally.) Just out of curiosity, what county are you in? I'm wondering if there is any analog public safety where you live and how much encryption is in use. Rail, air, and marine are all analog ... but air is AM, so if you want to listen with an HT you will need one that does AM. I think those exist, but they are the exception, not the rule. As @Lscott mentioned, there is a long-term plan to move rail traffic to NXDN. I have heard that some yard operations have moved to NXDN but I am unaware of any widespread adoption yet. NXDN is doable on a scanner too but you are looking at probably 4x the cost of a BC125AT unless you buy used. -
From an FCC standpoint that is true. BUT ... there ARE states where listening to a scanner while mobile is not legal ... unless you have a ham radio license. -
Based on the fact that you've told us that you have two GMRS HT and one dual-band HT, and that you aren't planning to transmit much (if at all) and if so it will be on GMRS, my advice would be: get another scanner. You mentioned rail. Is that the only thing you want to listen to? If so, then a Uniden BC125AT will be cheaper than any of those other HTs you list and work much better as a scanner than any of them. If you are interested in public safety, then depending on where you live a scanner may be your only option. None of those HTs will pick up P25 (for starters). -
One notable exception is OP25 (which runs on Linux, not Windows). It acts like a scanner ... SDR sits on the control channel then tunes to the voice channel then goes back to the control channel. I believe in a P25 system there is limited channel grant information on the voice channels too, so it's possible to set different priority for talk groups and if there is traffic on a higher priority TG it will switch mid-stream. Some of the other programs only need two if the frequencies in use by the system cover more bandwidth than the SDR can "see". OP25 is great, BTW.
Another MURS option. I have one and it seems decent. https://www.amazon.com/Radioddity-License-Rechargeable-Industrial-Business/dp/B0B2CV7YMN/
The 1990s rules are no longer in effect, so not relevant. As far as the first paragraph, Part 95A defines a control station as: A station at a fixed location that communicates with mobile stations and other control stations through repeater stations, and may also be used to control the operation of repeater stations. "Fixed location". So no, a mobile or HT (which is defined as a sub-category of mobile) isn't a control station, since it's not at a fixed location. The definition also makes it clear that communicating through a repeater is enough to make it a "control station". Controlling the repeater is a "may", not a "must".
It's not the 1960's. ? The first statement above is flat-out wrong, at least as far as GMRS is concerned. A fixed station and a control station are two different things according to Part 95 E
Is it time for this debate again?? What you state is true, but what the OP is describing IS forbidden. No one seems to know what a "fixed station" is ... but we DO know what it is NOT. HTs, mobile radios in a vehicle, or mobile radios installed in a house (or sitting on a picnic table plugged into a battery and an antenna on a tripod) are NOT fixed stations. Apparently I should have said, "The GMRS regulations explicitly prohibit the use of the 467 inputs as simplex channels except in one situation which does not apply to you." Better?
That is not correct. The receive frequencies on 23-30 are the same as on 15-22. If a nearby FRS user is on 15-22 you will hear them. The difference between 15-22 and 23-30 is that on 23-30 you are transmitting 5MHz up from the receive frequency so you can go through a repeater. The GMRS regulations explicitly prohibit the use of the 467 inputs as simplex channels: 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz.
467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz. These are the .5 watt FRS/GMRS channels (8-14). Note that GMRS mobiles are not allowed to use them at any power level. You can listen, of course, but not transmit. But as @Sshannon said, you can use 5 watts on channels 1-7 (and FRS can use 2 watts).
