WROA675
Everything posted by WROA675
  1. Yes, it's a Radioddity. I will reach out to them after their holiday. Thank you for the update.
  2. Thanks, I'm gonna wait awhile and do more research before resetting it. I agree it might be a quick fix and was my first thought to do initially, but that may not address the core issue, and I'm not sure I want to reset it, if it's not absolutely necessary (last option).
  3. No, it happened while I was stopped and the motor off, as well.
  4. Yeah, I got that feedback to from some of the folks on the FB forum, too. They added that it may be some kind of digital system interferences as well. Going call Bob soon and see what he thinks.
  5. Say it not so...?
  6. Okay I'm back with an update. Checked all wires, connections, everything seemed normal. Started off with the noise, as was the initial issue. However, after about 10 minutes it completely went away. I got to a good rx/tx spot and was able to convo with others with no problem. Some said they have had similar issues with their units (no only DB20) and attributed it to radar and digital systems in the area. The noise to return again but only lasted about 5 minute, that time, and return to normal. Very weird, and I'm not quite sure what or why it's happening. I choose not to reset to factory mode, at this time, considering others are experiencing this same anomaly, however I did put my squelch level at five(5) and that seemed to help. I want to get away from my area and see if that has any effect, either way. Thank you all for your input, it did help me and I got to explore different functions and get better acquainted with my unit, as a bonus. ?
  7. If anyone has a DB20-G and/or is familiar with it, please see my request for help (audio anomaly) in the technical section. Thank you in advance.
  8. Radioddity DB20-G, about a month old. This is my first issue with this radio. It was working fine up until earlier this evening and it's probably something I did to cause it. First I leave my house, turn on the radio, no chatter, I used the mic for scan mode (a two button process- FUN then 4) it starts to scan and then it stops on the RPT channel, I can barely make out the chatter because of the continuous buzzing (sounds like a old VW bug car engine idling in the distance, but coming out of the speakers). I found a spot to pull over and have no idea why it's making that noise (continuous buzzing tone), I check and it's making the noise on all channels. I turn it off and back on, same noise. Turn my rig off, still makes the sound. I look in the manual, no help. I figure I'll try to reset it to factory default, as I start the series of buttons to push, the noise stops. I drive to an area and was able to hit the repeater, spoke to another member, as seemed well. Then I go to dinner, after dinner I'm driving away, turn on the radio, and the noise is back again. It was too dark to mess around with, so I just drove home and logged in here to see if I could get some help. Has this happened to anyone else and/or anyone have some advice for me as how to fix this issue? Like I said, it all started when I initially tried setting it to scan with my mic and suspect I my have inadvertently hit some buttons I didn't mean to and through it out of whack, considering it went back to normal after I messed with the settings a little. I did have my HT with me and it was not having any issues at all. Hopefully there is a easy solution and I can learn from this experience.
  9. Using Radio Reference, it shows it "belongs" to DreamWorks - security, however the status says cancelled in 2016. I wish I had pulled over to hear more, I know studios do a lot of filming up in my area and imagine it could have been them. Very interesting...part radio enthusiast, part detective ?
  10. Hey now...hope y'all are doing well. Newbie question here: is there a convenient way to track a frequency? So, I'm scanning my mobile and picked up some chatter, kinda sounded like security or law enforcement, I jotted down the frequency it was on, but lost the signal as I got closer to home.
  11. I like the look of it, high speed-low drag, would love to hear more about it.
  12. We still have the mobile as an option. ?
  13. Thank you for your time and input. As for the Yagi, there's seem to be only one repeater, to the south of me, that I can hit, surrounded by hills and mountains on the other three side, so that's why I thought it might be a decent option. I could easily add a rotating component to it if I found I could hit other repeaters, later. Regarding number three, I'm a little sad to hear it seems to be the worse of all of them on my list. Not because it's only single band, (thanks for pointing out the narrow band too), and it may work the worse for GMRS, but that the guys at the shop told me that this was the "one" for me (after I shared everything I've shared here about this project).
  14. So much great feedback from everyone, yet I'm still not quite sure which antenna would best suit me. Here is a list of the options I am currently considering: 1) the height seems perfect for staying under the radar of the hoa (would be better with a N connector though, right?); $69.99 (BuyTwoRadios) The Tram 1477 is a Dual Band 2m/70cm Amateur High Gain Base Antenna with a 150 watt power rating. This single section antenna is 43" tall with three 7" stainless steel radials and is pretuned for outdoor or attic use. Dual band fiberglass base antenna 43" (1.09m) tall Single section 1/2 wave VHF / 5/8 wave over 5/8 wave UHF 3 stainless steel 7" (17.78cm) radials 144-148 MHz VHF / 430-460 MHz UHF Pre-tuned - no tuning needed For outdoor or attic use 3.5 dBd (5.64 dBi gain VHF / 6dBd (8.14 dBi) gain UHF Omni-directional Fiberglass construction Mast diameter accepted is 1 3/16" to 2 7/16" (30-62mm) UHF female (SO-239) connector Max power 150 watts 50 ohms Available in white or black Includes mounting bracket and hardware 2) may draw some attention, not that I'm worried since a lot of people have their Dish satellites here, and the height may give me the range I need; $169.99 (DX engineering) Base Vertical, Type-N Female, Commercial/GMRS/FRS, 153-157 MHz and 460-470 MHz ONLY, NO HAM BANDS, Fiberglass, 10.10 ft. Height Comet GP-6NC GMRS/FRS-Commercial Dual-Band VHF/UHF Base Vertical Antennas provide high-gain performance on the 153-157 MHz and 460-470 MHz bands. These superior-quality base station antennas feature a two-piece, heavy duty, UV-stabilized fiberglass radome for many years of reliable service. With a high power rating in their class, these base station antennas are ready to handle constant use your high-power VHF/UHF radios. Although light in weight, they incorporate strong, easy-to-use, extruded aluminum and stainless steel clamp-on mounting hardware for masts from 1.25 to 2.50 inches. A weather-protected Type-N Female 50 ohm connector is ready for the user supplied low-loss coaxial cable. 3) compact but not dual band (has move to the bottom of my list); $109.95 (HRO) COMET-NCG CA-F72GF 440 - 512 MHz Field Tunable Commercial Fiberglass Antenna 5.5 dBi 3.5 Feet N Conn. 440-512 MHz (tunable) fixed station antenna, 1.5:1 or less SWR: 10 MHz after tuning Gain: 5.5 dBi Max power: 150 Watts Length: 42 inches Weight: 2 lb 14oz Connector: N-female Construction: One-piece white fiberglass Max wind speed: 135 MPH 4) Received many comments and recommendations, here and other forums, about the Yagi; $115.99 (DX engineering) Moonraker Ltd YG27-35 Dual Band Hi Spec 2/70CM Yagi Antenna Moonraker Ltd YG27-35 Dual Band Hi Spec 2/70CM Yagi Antenna is a professionally built Dual Band Yagi that requires only one feedline with a Type N connector. Key features/specifications: * Type: Dual band 3/5 element Yagi * Frequency: 144-146 and 430-440MHz (does not perform on 146 to 148 MHz) * Boom length: 45.28 in. (115 cm) * Longest element: 39.37 in. (100 cm) * Gain: 9.5/11.15 dBi * VSWR: 1.5:1or better * Power: 50 watts * Connection: N-Type female * Mast Size: 1.181 to 2.165 in. O.D. (30 to 55mm O.D.) Looking forward to hearing y'alls options (pros & cons) on the above list.
  15. This is what I found: DB20-G: GM30: No clue if this is relative or what it means towards my project...
  16. This is what I found for the GM30 and the DB20-G No clue if this is relative or what it means towards my project...
  17. It'll be half in/half out. I've seen coax wrap-roll advertised, would it be a good idea to wrap the section outside that connects to the antenna? I would think it wouldn't hurt.
  18. I'm getting the idea that that antenna is the crucial piece here, height is might, is what I keep hearing. So thank you BoxCar for bringing up the SWR factor because that I haven't heard or considered, yet. I adjusted the SWR on my cb antenna and imagine it's a pretty similar process, correct me if I'm wrong. At the same time, I'm sure I can't use the same meter on a gmrs antenna, or can I, and would I need to? As far as my base unit, I pulled back on the reins a bit, considering the antenna is key, I might as well see how my GM30 and DB20-G perform on the new antenna, which I could swap in/out of my rig depending on the circumstances, first. That said, using either the mobile (20watt) or HT(5watt) with the home antenna, would it be necessary to adjust the antenna (assuming I need to when I first install it) each time? I'm guessing once the antennas dialed in(like my cb firestik) there no reason to adjust it when switching devices, but I could be wrong (surprise, not the first time ?). As to the comment below, where can I find this info for my radios?
  19. Progress update: Cable and Antenna on stand-by, the Comet-NCG (CA-F72GF @ HRO) and 18' of LMR 400 (25400F-NM-PL-18 @HRO). Now for dessert...which base(mobile) to get? I like the DB20-G in my rig, but I'm thinking something with more watts, as I am in the canyon. I know I'm new and sometimes feel like I might be getting in pretty deep, but I'm motivated and a quick learner. My goal is to have this unit in my home so I can talk to folks and I like to be able to use the unit as a scanner, too (for those dead-air moments ? ). Again, any suggests on the best unit to suit my needs, advise, recommendation, and yes, even criticism, are welcomed.
  20. Thank you for sharing your input and experience. The different perspective helped. I'm glad I posted here, gathering all these knowledge nuggets, so I can be confident that when I'm ready to order, it will be everything I need and nothing I don't.
  21. Yay, I am taking this seriously! Writing notes and doing research and I appreciate all the assistance and resources. Trying to avoid as many disappointments and do-overs as possible (a lesson I've learned my life- ask for help).
  22. Great, that's the kind of info I need, thanks, I'm a newbie and don't know much (my head almost exploded with I clicked on that chart ?). The reason for the long cable is to run it from my roof down into my office space. So would this be a better option? 1) RG8x Coaxial Cable, CB Coax Cable, 50ft RFAdapter UHF PL259 Male to Male Low Loss CB Antenna Cables, 50 Ohm for HAM Radio, Antenna Analyzer, Dummy Load, SWR Mete
  23. Considering options for a homebase antenna setup. My mag mount lets me hear loud and clear those on the nearest repeater, however, my transmission is staticky and low. Here are a couple items on my wishlist...any comments, advise, recommendations are appreciated... 1) RG58 Coaxial Cable 49.2FT UHF PL-259 Male to Male Low Loss Cable for Ham Radio CB Antenna Cable Radio WiFi Extension Coax for VHF HF 50 Ohm rg 58 Coax 2) TWAYRDIO Foldable Ham Radio Yagi Antenna UHF 400-470Mhz Long Range 7dBi Signal Booster GMRS Directional Yagi for Repeater System,HT,Fm Scanner,433mhz Device ...I live in Canyon Country and literally in a canyon, so my range is limited at best.
  24. Quick update. With some help and the GM30, I was able to hear 484.96250 (LA County Fire Dispatch), so that's good to know going forward. It was shared that many of the emergency stations may be using digital tones. Gonna play around with it some more tomorrow.
  25. Thank you WyoJoe. Sounds like I'm on the right track. The 771G is for my GM30 and I order the Bingfu Ham Radio Vehicle Car Mobile Radio Antenna Dual Band VHF UHF 136-174MHz 400-520MHz Magnetic Base PL259 Male Antenna (from Amazon) for my DB20-G in my rig. Both radios are from Radioddity.
