465
Local Repeater Uses DPL Tone, Unsure If I Can Program It
SteveShannon replied to Webslinger's question in Technical Discussion
You bet! -
DN is normal. DI is inverted. Unless it says inverted use the normal. DPL is just Motorola marketing language for what others call DCS or DTCSS. PL is just CTCSS. Again marketing crap. -
Probably the dumbest question you’ve ever seen.
SteveShannon replied to WSAV277's question in Technical Discussion
Amen! -
As others have already commented, the only frequencies that GMRS operators are licensed to use are the 30 listed in the regulations. All of the in-between frequencies are off limits to us for GMRS. That’s unlike most of ham radio where ranges of frequencies are available. For the authoritative reference, here are the official regulations: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E -
It sure makes it easier to replace.
I don’t know that it makes any difference to battery life, but there is no appreciable benefit. Now if you filtered on different tones for the two different channels it would make a difference. For instance, if you know that the repeater uses 100 Hz as it’s CTCSS output tone you might want to program that tone into 26. If you discovered that there were people transmitting on 18 using 143.3 Hz and you set that tone for 18 then you could tell which is which, usually.
I suspect your receiver is listening on both channels (18 and 26). If it’s a dual VFO receiver the two VFO’s are sequentially polled at a brisk rate. If your radio is on 18 when the signal is detected it identifies the signal as being on 18. If it’s on the other VFO at the time it identifies it as 26, but in reality unless you know two different transmitters use different tones or transmit signals with different characteristics, like a Roger beep on one or ANI on one, it’s probably not possible to distinguish.
What do you guys think of linked repeater systems?
SteveShannon replied to SvenMarbles's topic in General Discussion
After flip-flopping on this like a very lively fish, I have to agree with the logic and concern about poorly written rules expressed by 73Blazer. 95.349 covers all of the personal radio services. It prohibits connecting to the telephone network but allows exceptions in the rules for each service.. It doesn’t mention other types of networks. 95.1749 is the exception baked into the GMRS rules, but as 73Blazer says the exception listed there is poorly written. The phrase basically allows us to connect to the telephone network or any other network only for the purpose of remote operation. But connecting to any other network was never prohibited in 95.349 or the first clause of 1749, so I think the FCC’s interpretation under the Operations Tab on that other page is wrong. That might be what they want it to say, but wishes don’t make rules. -
Welcome to the forums!
Wouxun KG-UVD1P "Suicide Chip"????
SteveShannon replied to WSAA635's question in Technical Discussion
No -
That’s just fine. And don’t worry about desense on your RT97. Nobody has ever reported desensing the RT97 at factory power levels in this forum. Now if you started running an amplifier between the transmitter and the duplexer I could see it happening, but the RT97 actually consists of a completely separate transmitter and receiver. For your purposes it should be fine. Take your repeater and handhelds someplace clear and flat and see how much range you get.
Absolutely 100% agreed. Here’s the actual paragraph: You can expect a communications range of one to twenty-five miles depending on station class, terrain and repeater use. You cannot directly interconnect a GMRS station with the telephone network or any other network for the purpose of carrying GMRS communications, but these networks can be used for remote control of repeater stations. It must be pointed out that that is the FCC’s interpretation (which counts! ) of 95.1749. I don’t have a dog in this fight. I don’t have a GMRS repeater and if I did I doubt that I would link it. I think it boils down to this, based on the definition of remote control, I can connect to a repeater and remotely control it via the Internet. But connecting one repeater to another repeater to carry traffic between them over the Internet goes too far for the FCC. But my understanding should not be taken as any kind of authoritative source.
On the Airspy groups.io, there’s a post that includes the following advice: DO NOT use the local NOAA transmitter. While it may be on frequency, it could be off frequency by several kHz. DO NOT use the local FM Broadcast rock station transmitter. The frequency will deviate far off frequency. A talk station might be usable if you can hit it during a "silent period", but they are overall not recommended. There are better alternatives. https://groups.io/g/airspy/topic/69841361
In Windows, you can either do the three key chord shift-window-s keys to bring up the snipping tool or you can use alt-prtscr or ctrl-keys.
Now you’re off on a bit of a tangent, but I agree that a 10 dB increase is very significant.
Referring back to what you said earlier: You talked about how a 5 watt radio with a 6 dB gain antenna puts out 20 watts ERP and a 10 watt radio with that same 6 dB antenna puts out 40 watts ERP. You talked about how that gain compounded. You’re exactly right, but just as the difference between a 5 watt radio and a 10 watt radio is only 1/2 S-unit, the difference between 20 watts ERP and 40 watts ERP is still only a half S-meter unit. But adding the antenna made a full S-unit difference for both radios, if you’re in the direction of the 6dB gain. That’s an audible difference. Half of an S-unit may or may not be subjectively distinguishable to a human ear. One S-unit is audibly different, even though it’s four times the power. But I wouldn’t consider it very significant. Two S-units would be very significant, in my personal scale of significance. S-units provide us something that is objectively quantifiable, but whether something is significant or very significant is subjective. You may feel that one S-unit is very significant.
What makes you think that your VFO is more accurate than theirs? Maybe you’re off by 257 Hertz. I think all upper end HF receivers have a “Clarifier” adjustment to adjust for the many radios that don’t exactly match their frequency. I tune to an integer kHz and then adjust the clarifier, with the assumption that my VFO is perfect. Transmissions from satellites require a Doppler shift that varies based on orbital velocity and whether they’re approaching or moving away. Are FM transmissions modulated symmetrically about a center frequency, or do they modulate in one direction from the carrier? I don’t know.
I’m sorry you’re confused. I don’t think my statement (quoted above) is confusing, but maybe I made it too terse. Doubling power, with no other changes, results in a difference of 1/2 S unit. That’s by definition - one S-unit represents a difference of 6 dB, which is 4 times the power. That’s substantial but when you’re sitting in front of a radio it’s sometimes difficult to quantify. Making other changes (such as antennas) are more likely to result in changes as measured by the S-meter.
