SteveShannon
    466
  1. So the two plug connector used by Baofeng is a K-1 connector, as in K for Kenwood. There are better radios than the Baofeng. I would look at Wouxun KG-UV9G and KG-UV9D or P. https://bettersaferadio.com/wouxun-kg-uv9g-pro-gmrs-two-way-radio-shtf-scanner/
  2. Have you found anyplace(s) where it doesn't happen?
  3. It's also important to remember that the power output will have less effect than you might expect. That's not to say it'll have no effect, otherwise we would all have 100 mw handhelds and be delighted, but the effect on range is certainly not proportional to power. Using the Free Space Path Loss calculator at Pasternak, the loss increases by 6 dB for every doubling of distance. If you're down to 15 watts, from 25 watts, you have lost 2.2 dB. https://www.pasternack.com/t-calculator-fspl.aspx?utm_campaign=Power_Combiners&keyword=&gclid=CjwKCAiArY2fBhB9EiwAWqHK6m1sMnUKdXjKlSefQDa1mTL4ALA32Cg53fVUHsRkay7AEJN_aHBRqRoCsIAQAvD_BwE
  4. Sure - if I had a son-in-law who was a citizen of Canada, he would still be able to use my GMRS radio when he's visiting the states. Canada wouldn't have any say in the matter and the US government has no regulation prohibiting it. In fact, if my son-in-law were to come to Montana annually for skiiing or hunting and wanted to get his own US GMRS license, he could do that. It's only useful in the US, but that's all he would need. Now if he lived close to the border and used his call sign to communicate to someone in the US the Canadian government might be upset, but that's just common sense.
  5. There are services that exist just for that sake.
  6. All meter ranges are calibrated at two separate points with the expectation that everything in between is linear. It’s very possible, perhaps even probable, that the low points would be quite close. It’s also very possible (perhaps even probable) that the radio puts out less power than advertised. It’s a dilemma, for sure.
  7. It is classic RFI and if it exists everywhere in the area when you are outside the vehicle and the vehicle is completely turned off (no fancy LED lights - they’re a common source) then it’s probably more than we can diagnose. That leaves two obvious choices: Contact a local ham club and ask for help tracking it down, or avoid those frequencies. Personally, I would simply avoid the frequencies.
  8. I’ve been on both sides of this issue. This is a quote from the FCC GMRS site: But, it’s important to note that the actual regulations are phrased differently: . https://www.fcc.gov/wireless/bureau-divisions/mobility-division/general-mobile-radio-service-gmrs
  9. A Canadian citizen* can apply for a GMRS license for use within the borders of the United States. Since location data is prohibited from being sent through a GMRS repeater, you would have no real way of knowing whether they’re in the US or across the border. *As long as they are not a representative of their government.
  10. It’s important to note that there have been a lot of Surecom SW-102 meters reported within this forum that have really lousy accuracy. How can you be sure it’s not the meter. Measuring a cheap radio with an equally cheap meter could be an exercise in frustration. Do you have a friend with a more expensive wattmeter that can verify your results?
  11. So scanning range is pretty wide (first picture) and the instructions for setting the Btech GMRS Pro to scan vhf or uhf are on page 32 of the manual (second picture):
  12. No different antenna needed. It’s receive only for the vhf/uhf bands other than GMRS. At least that’s what’s advertised. I’ll see if I can find the manual, but I would expect that all you have to do is tune it from the front panel or program receive frequencies using the CPS.
  13. Your GMRS Pro radios can monitor the VHF and UHF ham bands as well, without worrying about accidentally transmitting in the ham bands.
  14. Interesting question. I’m tempted to just say let your conscience be your guide, but understand that if we don’t want GMRS to be treated like ham radio, we need to adhere to the rules that separate it from ham radio.
  15. It really depends on what you hope to accomplish with your emergency communications. What kind of emergencies are you planning for? Who do you need to communicate with in such an emergency? Just between you and your spouse or do you want to hear what’s going on in the rest of the world? What’s the worst case? 10-15 miles can be done between two radios if you’re both above any intervening terrain, but if you’re both at street level in a typical city you might be lucky to get a mile or two. My advice is that the technology is just a small part of it. You will need to develop a comprehensive plan that includes communications with the outside world as well as communications between you and others in your immediate party. You’ll need to plan for backup power, field expedient antennas, and places to go to ensure that your signal can get through.
  16. I have two Baofeng radios, one an older UV5R from before the crackdown by the FCC, the other a GT5R, which I left locked down. Both work as expected. i also have more than my share of Yaesu handhelds and one Alinco DMR handheld that are just better radios. If you ever ask how many radios are enough I’ll say “Just a few more.” When unlocking a radio, a person should fully expect all existing memory channels to be wiped clear. That’s just part of the trade off, and in fact for some radios that’s what’s necessary to get them to open up because the frequency limits are baked in somewhere in the memory configuration. For other radios, like the Yaesu handhelds I have, it was less disruptive. My friend Jack has a new UV5R that he just picked up a few months ago. He bought it for ham radio, not GMRS, so there was no need to open it up. His radio had been cutting out on some signals coming into the receiver lately and we figured out that it was the squelch. I sent him the Miklor article on fixing the squelch in that radio and I talked with him on the phone while he worked in Chirp. When he was done we tested the radio through the local 2 meter repeater. Everything worked just fine. That was Saturday or Sunday. Then, on Monday night, during the local 2 meter net, we heard someone trying to get into the repeater. We would hear white noise when they pushed their PTT, and then a roger beep, followed by the repeater courtesy beep. Another ham recognized that it was Jack because of Jack’s roger beep. Jack tried a few more times while we waited, but all we could hear was the white noise and then the roger beep. It was obvious that his transmitter was working, but his voice wasn’t being picked up and transmitted. I called Jack on the phone and told him what we were hearing. Having a recognizable roger beep helped! ? Yesterday, I spent some time with him while he and I looked through all the Chirp settings, looking for anything that might disable the microphone. We found nothing. I said that I thought it sounded like the internal mike just failed, possibly because the external mike jack’s bypass switch was stuck open. Inserting and removing the programming cable might have caused it and Jack tried inserting it a few times, but no luck. Finally, Jack tried the external microphone that came with it and then I could hear his voice. I’m not a Baofeng UV5R basher, but it’s important to realize just what they are — very low cost and surprisingly fun little radios that can fail at any moment. Baofengs are often an expendable component along the path of learning radio. But, if you get serious about playing radio, an SWR/power meter, a dummy load, and an antenna analyzer are great to have. Then a spectrum analyzer and oscilloscope. ♾
  17. Having these tools might be fun, but I wouldn’t buy hundreds of dollars in tools just to diagnose a problem with a $25 radio. Just buy a different radio that you don’t have to diagnose.
  18. So, those loud buzzing sounds are not CTCSS. They're way too loud for that. I don't know what they are. Does it happen only when you're in your car? Does it happen when you're in you house? If you go to the other side of town do you still hear it? You might have to put a directional antenna on the UV5R to triangulate the source.
  19. Yeah, it’s kind of bizarre, but I see lots of hams posting on Facebook that they’re on a particular frequency, either phone or ft8.
  20. This! When I’m hamming I’m hamming and I’ll do it on amateur radio frequencies. If I’m GMRSing, I’ll follow practices that make GMRS work well for others as well as me.
  21. There’s an interface kit. It’s sold in the shopping area of this site, but unfortunately it’s based on the Raspberry Pi boards which are currently nearly unobtainable.
  22. Welcome to mygmrs!
  23. You may communicate using simplex; you don’t need to use a repeater, but as others have pointed out you should adhere to the band plan established in your area. A local amateur radio club can help you find out what that is. If one hasn’t been established locally, then you should use this one from the ARRL site. Notice that Simplex appears in three or four different portions of this band plan, not the full 144-148:
  24. We should always be considerate of other users. Rag-chewing on GMRS doesn’t fit that model. It makes no sense to limit the length of a transmission, but allow a conversation to totally monopolize a channel. Yes, it does specifically mention “transmissions” because conversation is built on transmissions. It’s clearly intended to promote brevity, which include the conversation as a whole, in order to share the limited number of channels. That spirit is reinforced by the very next requirement: § 95.359 Sharing of channels. Unless otherwise provided in the subparts governing the individual services, all channels designated for use in the Personal Radio Services are available for use on a shared basis, and are not assigned by the FCC for the exclusive use of any person or station. Operators of Personal Radio Service stations must cooperate in the selection and use of channels in order to avoid interference and make efficient use of these shared channels. And for the record, I don’t think very many people believe hams should be barred from GMRS. They just want to be able to use GMRS as a personal radio service, rather than have it taken over by a small number of inconsiderate jerks who monopolize the limited number of channels with long winded conversations. It’s a matter of politely fitting in to the purposes for which the service has been established.
  25. You can’t make Fords better by sabotaging GM.
