448
Also, at that point when you are hearing the input channel, some radios allow you to scan for tones.
The KG805 series and maybe others ANI
SteveShannon replied to WRQX963's question in Technical Discussion
Maybe a link to a previous post will help: -
So are you hearing the repeater courtesy beep and wanting to get rid of it? Courtesy beeps aren’t held in the same disdain as some hold Roger beeps. http://www.arrl.org/files/file/Technology/tis/info/pdf/9509075.pdf
No, you’ll have to import it as a CSV. You might have to massage it in excel if it’s not in the right format. I would import it and see how it looks. Don’t upload it unless it looks perfect.
@KekistaniRefugee I’m sorry, I had to go to bed. I’ve got a full day tomorrow too, but in the afternoon I’ll check to see how you are doing. Hopefully, you’ll get on the repeater by then. Don’t worry about asking questions. We were all beginners once. And I really don’t think Notarubicon picks on honest questions based on lack of experience, but rather “know it alls” or “experts” who don’t truly contribute anything. A lot of us enjoy his videos.
Can there be lower cost levels of support?
SteveShannon replied to SteveShannon's topic in myGMRS.com
I went ahead and joined at the $50 level because it’s the only way to support right now, but I still think that if there were additional, lower priced levels of support, even if they don’t receive anything for it, people would join them, just to provide some financial support. Having 200 people pay $20 is better than 20 people paying $50. $50 might not seem like much, but it’s more than twice what I spend to belong to other hobby forums. I’m not a professional. I don’t have a repeater and I don’t care about most of the features that come with premium membership. I just enjoy the forums. Although I just use GMRS radios for very simple communications, apparently forums are my hobby. -
ID Signaling nickname on Btech GMRS Pro
SteveShannon replied to WRVY822's question in Technical Discussion
Your two radios can identify themselves to each other or to others of the same type. I would put my first name in it, but you could put “WRVY822-1” and “WRVY822-2” or something. Then you and a relative have the ability to send each other your locations, etc. -
Ground plane and mounting Ghost antenna to van roof
SteveShannon replied to JimK's question in Technical Discussion
Why not just use a piece of steel running crosswise and stick the antenna base to it? The metal will serve as your ground plane. -
The radio doesn't directly accept CSV files. First you have to import the file into Chirp, then make sure you have your serial port selected. I suspect that's your problem. Here's what I suggest. First, make sure the correct serial port is selected. Until you have chosen a serial port, downloading and uploading options will be grayed out. Until you choose the correct one downloading and uploading will fail. Then, download the current configuration of the radio. Get in the habit of always doing that. Otherwise, if you screw up the upload later on you have something to revert to. It's also the best way to ensure that the correct port is selected. Save that as a backup, then tell Chirp you want to start a new file. Import your CSV file. The columns and rows of Chirp should populate. Select "Save As" and then save that under a different name than your previous backup file. Now upload that configuration. That should do it.
FM on your radio is probably the same as Wide FM or WFM. That shouldn't prevent you from connecting to the repeater though. I suspect the reason you cannot connect to the repeater, despite being close to it, is almost certainly because you are transmitting the wrong CTCSS tone or DCS digital code. With DCS (also called DPL or a few other things) you also have to say whether it's normal or inverted. Or you're transmitting on the wrong frequency. Typically you transmit to a repeater exactly 5.000 MHz higher than you receive from it. Most commercial GMRS radios will automatically add in the offset if you're on a repeater channel. That can cause problems if you're on one of the very few repeaters that have an offset that isn't exactly 5.000 MHz. However, this happens very infrequently. I would be inclined to think it's a tone problem. You don't need a tone or DCS code to receive and when people have problems receiving the first thing many of us will advise is to clear out any receive tones. But you do need the right tone when transmitting to the repeater or it will simply ignore your tranmission.
A loop just below the antenna is frequently done as a choke.
SteveShannon replied to Lscott's topic in Amateur Radio (Ham)
The Anytone/Alinco zone file is a a table of zones. Each zone has a list of joined channels, with apparently up to 255 entries. It appears to use the name of the channel, rather than a number. -
There are cable ties that are intended for exposure to the elements (UV resistant). Just use one of them, but be sure you don’t tighten it up. Coax cable is very easily damaged. A short piece of ground wire could also be used. Also, Panduit makes a lot of different cable handling accessories. I’m sure others do too, but I’m most familiar with Panduit.
I exported my zones to see what they look like. It should be possible to manipulate them in Excel also, but you have to be very careful. At least for the Anytone/Alinco codeplugs, there's a very complex array of channels for each zone in one of the columns that would be very easy to zorch. -
I have exported to a CSV format file and sorted in excel, then reimported. -
I was going to say “Jinx, padlock!”
So really, BTech should have designed all their radios to use the same cable. I’m in agreement with you there.
Look in the manual for ANI tones. Disable them if they’re turned on.
Perhaps only people who buy a single radio feel that way. People who buy four or five don’t want to pay extra for three or four unused cables.
Are you saying that your local repeaters transmit on 467.600 and 467.675 MHz? Because: 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz.
I’ve seen “YouTube reports” that both sides have adopted Baofeng radios when needed. I wouldn’t be surprised. And, yes, Ham Radio 2.0 had a YouTube video with a representative from the Polish Amateur Radio Club where they were actively soliciting support for Ukraine. I don’t remember the details, but it’s an easy video to find.
