466
Successful Handy Based Repeater? (ie. Baofeng/Retevis)
SteveShannon replied to WRUH396's topic in General Discussion
I’ve got one of those 18”x18”x18” all-weather equipment boxes with an extending handle and wheels. I wish it had larger tires so I could tow it behind me while hiking up a hill at our rocket launch site. I also have lots of SLA 7Ah batteries I’d like to use. They’re heavy-ish but that would be mitigated by being able to roll the case behind me. I haven’t done the calculations but I think I’d only need a couple for a Retevis RT97S. Most of the time it will simply be receiving with maybe 5 or 10 minutes of transmitting max. I’ve toyed with doing something like you did using the two Radioddity DB20G mobiles I bought last month, but it would probably end up costing nearly as much as a Retevis RT97S. -
CTCSS are analog tones. DPL are digital codes. There is no conversion. Nor are they interchangeable. You will have to learn how and where to select the DPL, also known as DCS, DTCSS, or possibly something else, but all meaning the same thing. It’s usually a different menu item than the CTCSS tone. I don’t have a 935, but someone will probably chime in and tell you which menu choice it is. Under the correct menu there will be a long list of choices. There will also be a column telling whether the codes are normal or inverse.
Probably similar gain, but you can take a Signal Stick and wind it into a loop and put it in your pocket, or use two of them to make a dipole, or multiple ones of different lengths to make a fan dipole. They’re part of a system. The most important thing they do is make Ham Study available for people who want to study.
Maybe this will help: ” The origin of the Super-Elastic Signal Stick Approximately 15 years ago I made my first antenna following this general design. These are based on the traditional “1/4 wave piano wire antenna” design; it turns out that 1/4 wave on 2m is roughly 3/4 wave on 70cm, and a 3/4 wave antenna performs roughly the same as a 1/4 wave antenna, which makes these work equally well on both 70cm and 2m. These antennas were originally made with stainless steel wire as a fundraiser for a ham radio youth group (the one I met my wife in, actually). Over the years we’ve improved the design dramatically, most notably by changing to use nitinol superelastic wire. When the youth group shut down I was assistant advisor to it and due to continued demand I took over the project and have continued selling them as a fundraiser for HamStudy.org, a site which I am also connected with.”
Cool, thanks! That's good enough; you don't need to dig for a BOM. -
Both of the statement above, by @KAF6045 and @OffRoaderX are correct. The rest of my post is useless except as a geeky point of interest. There is a calculation that can be done to determine theoretical loss at given distance, but it assumes perfect conditions, i.e. "Free Space." That could useful for establishing an absolute outer limit for distance. Great for space travel. The equation looks like this: d is the distance between the receiving antenna and transmitting antenna. f is the frequency in Hertz c is the speed of light in the same units your distance is in. Gt is the gain of the transmitting antenna Gr is the gain of the receiving antenna Here's a calculator built to use it: https://www.pasternack.com/t-calculator-fspl.aspx
I’d love to see pictures and an actual parts list. -
I’m gonna put up a repeater and make it a requirement that everyone must use a roger beep and the more annoying the better. We’ll hold contests! And it’ll be on channel 19. ?
SteveShannon replied to Lscott's topic in Amateur Radio (Ham)
I think the disagreement is on the definition of being cheap. A person that I think of as being cheap buys the cheapest of everything. There’s a consistency to the cheapness. He (or she) would buy a cheap radio and pair it with cheap feedline, a cheap antenna, and a cheap microphone. Based on that definition a person who buys an expensive radio isn’t cheap, even if they pair it with a cheap microphone or questionable feedline. They may be working with a finite budget. They might have really poor judgment. They might just be stupid. But by the act of buying an expensive radio they have disqualified themselves from being called “cheap.” And I agree, when it comes to hobbies, I see a lot of people who try to do as much as they can to save money in some ways that prove to be questionable. Ham radio is no different. A lot of retirees with a budget try to build their ham shack by budgeting one expensive item each year, but they need something to get them by in the short term, so there are lots of $1300 radios paired with $60 antenna kits (using my own example). -
How effective are antennas in attics?
SteveShannon replied to WRQC301's question in Technical Discussion
Some hams have had to get very creative. Dipoles or end fed half waves hide along fascia boards or are disguised as Christmas lights. J-poles can be hidden behind hanging plants or in flagpoles. Tall trees can help hide many kinds of vertical wires. Fences help hide horizontal wires. If you can make an antenna, you can make an antenna that looks like something else! -
Baofeng UV9G - Unable to turn off Flashlight
SteveShannon replied to WRJZ295's topic in General Discussion
It’s six weeks old. Send it in for warranty replacement. -
Sure, and I’ve seen people who want to impress others match a great audio system with crappy lightweight speakers. Some people spend money on the stuff they have to look at and neglect it on the parts that are out of view. People are funny sometimes. But nobody should be shamed for refusing to pay $150 for a Bluetooth microphone with crappy reviews. ? -
It's not a double or triple key press. Just press the bottom button, on the side below the PTT, which is the SK2 button. You press it once and the flashlight turns on. You press it again and the flashlight starts strobing. You push it again and the flashlight turns off. Push it again and the flashlight turns on again, starting the whole cycle over again. Here's the description in the manual - page 21: 6.7 This function is very useful for night illumination. To turn it on press MON; push it again, the flash light will be strobe; push it again: it will turn off. I don't know if there is a way to restore to factory defaults. -
Antenna Separation for a Repeater
SteveShannon replied to WRVD955's question in Technical Discussion
Vertically or horizontally? It’s easiest to separate them vertically, in which case they don’t need horizontal separation. -
Okay, I went back and reread his post. It almost sounds like he thought he turned on the flashlight using SP. Maybe he’s just trying to use the wrong button instead of the MON button. -
He did mention the SP button. It seems he programmed it to turn on the flashlight in addition to the MON button. But then he couldn’t program a button to turn off the flashlight (which would presumably be in addition to the MON button.) I also presume that additional presses on the SP button don’t toggle the flashlight through its three states, but maybe I am wrong about that. Steve -
If it's not possible to reprogram the MON button, then he should be able to simply turn off the flashlight by using the MON button. -
So, did you reprogram the MON button so it doesn't toggle through the three modes of the flashlight? (On, strobe, off). -
Maybe I didn’t understand what you were asking when I answered earlier. I thought you were asking why hams also use GMRS. That’s the question I answered, thinking in terms of different services used differently. Or are you saying that they’re taking over GMRS and bringing with them traditional ham activities in an effort to make it ham-light, such as calling CQ, using Q codes, and ragchewing on GMRS? Steve
Midland’s new-ish Mobile/portable repeater
SteveShannon replied to giantfuton's topic in General Discussion
It’s manufactured by the same manufacturer as the Retevis RT97s and appears to have the same specs. Notarubicon’s measurements reflect a power output of about 6 watts after the duplexer, which was within half a watt of the Retevis. -
They’re included to attract first time buyers.
My first thought was that it might be an Ed Fong antenna inside that tube. ? Even if you wouldn’t choose one for use as a repeater antenna based on durability, Comet antennas have an excellent reputation for accuracy in their published specifications. It makes sense that @markskjervewould use their data.
