466
Although I don’t know him personally, Marc isn’t the type to act that way. I think his question was because cable loss is usually described in dB, not percent and hearing it referred to as a percentage was slightly confusing.
First thing I would check is the incoming voltage; see if it sags when you power up.
No - it really couldn’t. A repeater works by transmitting while it receives. If you disconnect the receiver while it’s transmitting you prevent the repeater from repeating; it has nothing to transmit. Repeaters are only able to work because transmitters transmit on a completely different frequency from the receiver AND duplexers (or antenna locations) filter out the high power RF that is being transmitted to prevent it from entering the receiver and causing feedback or actual damage. The input stage of a receivers must be very sensitive to “hear” a signal at any distance. Being connected to the same feedline as a transmitter is like having a gun go off right next to your ear. Turning off a receiver after the transmitter has completed transmitting does nothing but prevent future use of the repeater.
Looks like it’s made for Ozark Trail by Gocom: https://fccid.io/2ARRE2019LT001/User-Manual/user-manual-4481388
You can always listen to the 467 frequencies. There are limitations to transmitting. Here’s what the regulations say about that: 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz.
It’s also very useful in diagnosing tone problems. Once, after resetting my radio, I forgot to put in the repeater input tone. I could hear everyone else on the repeater but none of them could hear me. Another person got on the repeater and said that he could hear me fine on the reverse so I should check the tone. Bingo!
SteveShannon replied to Lscott's topic in Amateur Radio (Ham)
@tweiss3 Thank you! That’s exactly the level of detail I hoped to hear. -
Alex, I think you read way too much into his previous posts. He wasn’t arguing against licensing. I felt that he was pointing out the same thing I was: that only a small minority of GMRS users get licensed and that it’s a waste of time and energy to lose sleep over it, I.e. Let it Go. It was a comment on the status quo, not a post advocating anarchy. And I like Frozen as well, and the song. Watching my grandkids enjoy it and sing the song is great. ? Happy New Year, my friend! Steve
I never thought about using Fixed Stations to connect two different Repeaters. If that's correct (I don't recall anything in the regulations that prohibits it) then you might as well use full duplex. Fixed Stations may transmit on both 462 MHz main channels and 467 MHz main channels, thus they could communicate in full-duplex. They are limited to lower power, but that helps with the technical challenges anyway, as you pointed out. The technical challenges you mention are the biggest challenges. [Repeater] <--- wired connection ---> [Fixed Station] ((((((RF)))))) [Fixed Station] <--- wired connection ---> [Repeater]
It probably wouldn’t be wise to put it on a window that you open and close often, but other than that I cannot think of any reason it wouldn’t have a long life. The pass through portion is metal and seems quite durable. The losses are published. I haven’t experienced any degradation to the SO-239 on the external wall. Both SO-239 connectors are permanently attached to the wall. I suppose you could paint the exposed metal to enhance weather resistance. There are other alternatives: a very long barrel connector that goes through the exterior wall. All of the online radio stores carry them. They’re not very expensive, but you need to do some drilling and sealing. Or the MFJ panels that slide in next to your window and provide multiple types of connections. That’s the most expensive option, but provides a lot of flexibility. A panel box with a pass-through conduit. That’s actually the best way because it usually includes a copper ground plate and lightning protection, but it requires the most physical changes to your house.
That’s true, but doesn’t answer either of my questions. Similar to DMR, nothing prevents using NXDN or P25 on amateur radio. -
Of all those, which has the most pleasant voice reproduction? Both DMR and C4FM make people sound like they’ve been drinking, sort of slurred. Those are the only ones I’m familiar with. How do you use NXDN and P25? Are those for amateur radio or commercial applications? -
I have used DMR in simplex. There are actually several calling frequencies established for DMR and I’ve used thos as well. DMR in simplex sounds just like over a good repeater and a little better than over a hotspot. -
I bet it did. Some discussions are just lightning rods for uncivil behavior. It’s really a shame, too, because our civilization needs civil discussions of politics.
I have an Alinco MD-5 DMR VHF/UHF Radio. Under the plastic it would appear to be an Anytone, but I prefer the Alinco implementation. I use it with the local UHF DMR repeater and I use it with the local analog 2m repeater our ham club provides. I also use it with my hotspot. i also have a Yaesu FT5DR, which does VHF and UHF. There are no local C4FM repeaters, so I use it with my hotspot. I also use it for analog 2m on the club repeater I mentioned above. -
It’s a violation of part 97 requirements to interfere with transmissions of another, so the jammers are in the wrong. Nothing else that I say should be interpreted as justification for their actions. Freedom of speech is limited with ham radio. There are authorized transmissions (97.111), prohibited transmissions (97.113) and there are rules set by the repeater owners/control operators. Many repeater owners/operators/clubs prohibit political discussions. That’s their right. Each repeater has a single channel and it’s the only channel available to anyone using that repeater (some digital repeaters might have two channels). Monopolizing that one channel to discuss politics could be seen as inconsiderate by other users; political discussions force everyone waiting for the repeater to listen to political views which could be very divisive. Rag chewing on simplex channels is another matter. But it’s still a violation of part 97 requirements to interfere with transmissions of another, so the jammers are in the wrong, regardless of their motives.
I have one of the Comet window pass-thru jumpers. It’s well built and works very well. I use it for an HF transceiver. Note that it’s only rated for 40 watts for UHF.
Here’s the regulations regarding frequencies. Note that repeaters are only permitted to transmit in the “a) 462 MHz Main Channels”: a) 462 MHz main channels. Only mobile, hand-held portable, repeater, base and fixed stations may transmit on these 8 channels. The channel center frequencies are: 462.5500, 462.5750, 462.6000, 462.6250, 462.6500, 462.6750, 462.7000, and 462.7250 MHz. (b) 462 MHz interstitial channels. Only mobile, hand-held portable and base stations may transmit on these 7 channels. The channel center frequencies are: 462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, and 462.7125 MHz. (c) 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz. (d) 467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz.
Programming KG935G w/My Public Safety Freqs?
SteveShannon replied to edspilot's question in Technical Discussion
Don’t worry about the tones. Just set the frequencies. As long as you don’t use a tone to control squelch you’ll hear everything on the frequency. -
As I recall, from a regulatory perspective, repeaters are not explicitly permitted to transmit on the 467 MHz channels.
I’m not arguing against your logic or your ideals. I’m just pointing out the reality of the situation. Most people don’t get licensed for GMRS and for the most part their activities don’t affect those who do.
Now you’ve got it. Most people do ignore the license requirement and GMRS accountability is a myth that even the FCC disregards the unless someone does something really bad.
I didn’t make it very clearly. My point is that 90% of the GMRS users with whom I’m personally acquainted use it simply as a communications medium when they’re many miles away from civilization. They don’t know about or care about repeaters; they’re using simplex in the 462 MHz frequencies. They use it because cell phones don’t work where they’re recreating. For them it’s not a hobby or a vocation. It’s simply a tool that enhances, and in some ways enables, the enjoyment of their hobbies. For most of them the Garmin Rino is the only GMRS radio they’ve ever owned. They chose GMRS strictly because of the ability to see where the others are and to mark locations to share with each other. I cannot disagree with you about why we should be licensed, but the fact is that most outdoor recreational GMRS users never will unless they get deeper into it like those of us on this forum. We on this forum are not an example of the average outdoor recreation user of GMRS and probably never will be.
You kind of missed the whole point…
