464
There is also a UT72G that’s tuned for GMRS.
root@alarmpiNBothell ~]# Sudo asterisk -rx "opt fun 25312*3177" Response: Usage: apt fun <nodename> <command> Send a DTMF function to a nod root@alarmpiNBothell ~]# One is “opt fun” and the other is “apt fun”. I suspect they both should be one or the other and a typo happened. opt is an optimizer and apt is advanced package tool. I suspect “apt” is the correct spelling
Does it sound like feedback?
The guy is a recent licensee so the historical background is not relevant. The guy should pay attention to what Rich suggested and review what he entered. If he entered the same thing he used in his Guest name it’s a mistake. Sometimes the difference between a lowercase L and the first ordinal number isn’t always obvious (especially for us old farts that learned on manual typewriters where a single character represented both).
What do you mean by "I get more power?" How are you measuring the "power" you're getting? Or do you simply mean that others receive you better? Clearer? Louder? Or are you actually measuring the power output where it feeds into the antenna? So: GMRS Radio -> U25 -> UT-72 gives you less power than GMRS Radio -> UT-72? Or GMRS Radio -> U25 -> UT-72 gives you less power than GMRS Radio -> Unknown stubby antenna Have you tried using GMRS Radio -> U25 -> Unknown stubby antenna? How does that compare? What's the SWR of the UT-72 at the frequency you're transmitting? What does the amp's SWR look like to the radio? If you're truly measuring power (watts) using the U25 and UT-72 combination, and it's less than measured power going into the stubby antenna, where are you measuring? Assuming they're both the same measurement point (right at the antenna) then it could be bad feedline, bad amp, or bad antenna: high SWR on antenna (reflected power subtracts from forward power).
Right next to their profile picture is a link to Message them. I'll send you a message saying the same thing. Steve
Check and remake all of your connections. If that still doesn’t help (it’s just a last gasp effort) then I would call customer support. It could be any number of things from a cold solder joint to a cracked trace on a PCB or something completely different. I’m sorry, but I don’t have any more suggestions. Please let us know what they say.
Measuring at the radio, does the voltage stay at 14.1 when you key up on high power? I think your next step would be to call customer support.
Zip files can also be broken up into manageable sized files that can be reassembled: https://kb.corel.com/en/125884?_gl=1*195znwd*_ga*MjAzNTA3MzA3NS4xNjcxNDU4NTY4*_ga_73J027E48R*MTY3MTQ1ODU2Ny4xLjEuMTY3MTQ1ODgyMC4wLjAuMA..
The two things I would check for are High SWR or Insufficient power supply. Some radios have protection built in that will temporarily shut down rather than transmitting into a high SWR. But it may simply be that your power supply simply cannot provide the power your radio needs when it’s transmitting at high power, resulting in the voltage sagging and the radio resetting itself.
GMRS Repeaters for Emergency Communications Use
SteveShannon replied to KG5UWF's topic in FCC Rules Discussion
Perhaps the terms of a grandfathered license allow multiple people to operate under a business’s license, but that’s no longer possible for new licenses. Nor is there an exception for community emergency volunteer groups. Unless it’s covered as part of a grandfathered license it’s just not allowed. -
DB20G / AT-779UV microphone pin out for use with SM01 desk microphone
SteveShannon replied to WRPH745's question in Technical Discussion
And possibly useful if anyone everwishes to put two of these radios together for full duplex communications, either repeater or fixed station, or possibly for ISS communications. -
I think, based on his putting the word “up” in all caps, that he Michael was emphasizing the direction of the split, more than that the shift would be exactly 5 MHz. That’s important because repeaters on some ham bands can be offset in either direction.
Based on the markings on the PCB in the microphone housing it would appear that the hardware Anytone is the OEM. -
No, he said he couldn’t tell the difference between the Wouxun XS20G or 935G SOC radios and superheterodyne radios, but he could tell a big difference between the Wouxun SOC radios and cheaper SOC radios. Therefore he would also be able to tell a big difference between superheterodyne radios and the cheaper SOC radios.
The requirement for repeater identification is one that many people have argued about quite passionately, even here on MyGMRS, but the requirement is clearly written. It’s just as KAF6045 says, a GMRS repeater must be identified and the only exception is when the only people using the repeater are family members authorized to identify themselves using the call sign of the repeater’s owner (and who do so). It’s every person’s personal decision whether they comply or not.
GMRS repeater without duplexer, antenna distance
SteveShannon replied to m4f1050's question in Technical Discussion
So far I’ve only read the article “Duplexers and Repeaters” but it was a good article, written at a level that anyone hoping to establish a repeater should be able to understand. -
It’s usually only the last foot or two that are ruined on the cable. You really can just re-terminate the cable. Another thing that helps is to liberally apply Vaseline onto the PL-259 and SO-239 before connecting them together. Still use the self vulcanizing tape.
I have both DMR and Yaesu C4FM radios. DMR is harder to learn at first and harder to configure from the front panel because of the codeplug. Yaesu is easier to just pick up and talk, if there’s already a repeater. But if you want to establish your own node to the YSF network, it gets pretty complicated. I’m envious of the fact that you have some active C4FM repeaters in your area. There’s only DMR here, but it works well. I haven’t used D-STAR yet.
Neither Yaesu nor Icom have DMR modes. Yaesu has their own proprietary digital mode C4FM. No other brands use it. Icom uses D-STAR, a digital mode created by the Japanese Amateur Radio Society. Kenwood also makes radios for D-STAR. DMR is a different digital mode based on a format that was developed in Europe. Several companies make radios for DMR, including some of the inexpensive radios from China.
But I’d like to try and explain it in my words as well. The human ear has the ability to hear over a spread of frequencies from about 10-20 Hz on up to 15,000 Hz or even up to almost 20,000 Hz. High frequencies become more difficult to hear as you get older or suffer hearing loss. So that’s a bandwidth of say 20 Hz to 15,000 Hz or 14980 Hz. Speech can be pretty accurately reproduced in a much narrower bandwidth, but there’s still some information at the higher frequencies that help you discern different sounds, such as an ‘f’ sound from a “th” sound or even an ‘s’ sound. Now imagine if someone applied a band pass filter that starts at 300 Hz and ends at 6000 Hz. That’s narrowband. Compare that to a filter that allows 300-12500 Hz bandwidth. More sound information that can be encoded in that bandwidth. A wideband signal received by a narrowband receiver has to throw some of the information away, making the sound quality less, even though there’s more signal than it knows how to handle. A narrowband radio encodes less information but a wideband receiver receiving that information ends up a partially empty channel, which can sound weaker. But narrowband sounds okay when both ends are set to narrowband and wideband sounds incrementally better when both ends are set to wideband.
No problem. Here’s a video that addresses your question:
Shortwave? I don’t know what you mean by that. Are you talking about narrowband versus wideband?
